52840 Dongle,ble sniffer set coded phy failed
Hello, when testing the BLE sniffer with an nRF52840 dongle (utilizing the most recent official sniffer firmware), I configured Wireshark to capture the coded PHY. After initiating the sniffing process for several seconds and capturing roughly tens of broadcast packets, Wireshark ceases to update data. Upon conducting lower-level debugging, I discovered that the sniffer exclusively outputs counts rather than continuing to output broadcast packets. Could this be attributed to a misconfiguration or are there alternative explanations?
  • My setup: Sniffer rel 4.1.1 and wireshark 4.3.0 on Linux
    For my application this is not a show stopper but a nice to have for development and verification. Hopefully this can be fixed in the future but I understand there are priorities on tools like these.
    For clarification, you noted that advertising on LE Coded PHY is rare. Can you please elaborate? I would think that this would be useful for many applications that need to reach far for a connection.
    In my application, it could improve the functionality given the expected dynamic use-cases. For now, we plan to advertise w a 1M PHY and monitor the PER and adjust the PHY to improve the connection.
    Much appreciated for your response.
    David
  • Hi David,
    Do you have issue sniffing Coded PHY packets? Have you tried installing the sniffer following the link in Joakim's reply?
    This is likely referring to Joakim's personal observation. On DevZone, I could also observe that most questions on Advertising are about regular legacy advertising.
    It is true that it would be useful for many applications that want to have range.
    Hieu
  • Hi Hieu,
    I tried the path that Joakim suggested and I still get the same issue. I noticed that wireshark produces some exceptions with reference to Rust. At this point I will work without wireshark.
    Thank you for your response.
    David
  • Hi David,
    OK. Those Rust exceptions sound like a different issue, so should you need the tool in the future, please feel free to open a new DevZone thread about it.
    Hieu
  • I agree Hieu,
    The symptoms experienced were exactly the same as what Zadme reported, with "exception" to the Rust exception. When time permits, I will check the Wireshark domain for support.
    Thanks again. David
