I have to use Nordic SDK and VS Code Dev Kit on my company enterprise PC but I cannot fetch the toolchain or install SDKs via VSCode or nRF Connect for Desktop
Our nRF Connect for VS Code extension developers inform me that the extension uses nrfutil toolchain-manager v0.14.1, while support for native certificates were added in nrfutil toolchain-manager v0.14.2.
The team has been working on updating the version used with the extension and have a planned release in the coming weeks. This will update the nrfutil toolchain-manager in the extension to v0.14.4.
If for some reason you cannot wait until then, you can use nrfutil in the command line. This tool is independent of VS code, and toolchain-manager is a CLI tool for managing and using toolchains for the nRF Connect SDK.
Let me know how that works for you!
Øyvind
I tried the following:
C:\Users\d3bkbz>nrfutil toolchain-manager search
Error: Failed to bootstrap core functionality before executing command.
HTTP request to default bootstrap resource
https://files.nordicsemi.com/artifactory/swtools/external/nrfutil/index/bootstrap.json
failed.
Please check that your internet connection is functioning. If you use a proxy, please try the --detect-proxy flag or
manually set the appropriate HTTP_PROXY-style environment variable(s).
To use a custom bootstrap config, set NRFUTIL_BOOTSTRAP_CONFIG_URL. To bootstrap directly from a nrfutil-core package
tarball, set NRFUTIL_BOOTSTRAP_TARBALL_PATH.
Caused by:
0: error sending request for url (https://files.nordicsemi.com/artifactory/swtools/external/nrfutil/index/bootstrap.json)
1: client error (Connect)
2: tcp connect error: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. (os error 10061)
3: Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte. (os error 10061)
C:\Users\d3bkbz>nrfutil toolchain-manager search --detect-proxy
Error: The 'proxy' helper program was not found in the system PATH nor $HOME/.nrfutil/proxy_utils/
So it does not work at the first glance...
Could you advice me how to install the proxy helper program on Windows 10?
Hi Andreas,
I've forwarded the inquiry to our team, however, due to summer vacation period starting in our office this week there will be a delay in our answers.
Sorry for the inconvenience.
Øyvind
