Crash in sd_clock_hfclk_is_running on Soft Device S140, 7.3.0
Hi, I recently noticed crashing in sd_clock_hfclk_is_running() on a nrf52840 using SoftDevice S140 7.3.0. This is the callstack:
??@0x00000ac4 (Unknown Source:0)
<signal handler called>@0xffffffe9 (Unknown Source:0)
sd_clock_hfclk_is_running@0x000276ae (.../nRF5_SDK_17.1.0_ddde560/components/softdevice/s140/headers/nrf_soc.h:720)
I'm using the following to enable the hfclk whenever I enable QSPI to avoid errata 244:
sd_clock_hfclk_request();
uint32_t isHfclkRunning = 0;
do {
  APP_ERROR_CHECK(sd_clock_hfclk_is_running(&isHfclkRunning));
} while (!isHfclkRunning);
I can trigger this somewhat reliably if I unplug and plug usb power while this code triggers.
Any tips on how I can avoid this issue?
Jeff
    We still feel that there might be some mess-up with svc and interrupt configuration. Maybe you end up at this point, calling sd_clock_hfclk_is_running while you have disabled interrupts then?
    The call to all sd_ functions is just implemented as triggering svc interrupts, and when we tried on purpose to do that in a simple program like this, it does hardfault.
     -Priyanka
  • The flow of the program is:
    do {
      sd_clock_hfclk_is_running(...);
    } while (...);
    If any SVC interrupt causes a hard fault when called in an interrupt, would it not crash when calling sd_clock_hfclk_request first?
  • Yes, that is true, unless this code gets interrupted by another interrupt, and that interupt disables irqs for example, and then return.
    To demonstrate, you can see this simple program.
    void SVC_Handler(void)
    __disable_irq();
    void __svc( 10 ) dummy( void ) ;
    dummy();
    __nop();
    __nop();
    __nop();
    __nop();
    dummy();
    while(1)
    It will hardfault on the second call to dummy(), because the first time the SVC handler ran, it disabled interrupts and then returned.
  • So is there any condition under which sd_clock_hfclk_request() or the nrf5 sdk disables irqs? I don't have a single disable_irq in my entire codebase.
    I was informed by our experts about another suspicion after looking more closely at your callstack contents,
    That line there on top of your callstack makes us suspect that the content of address 0x20000000 (so the first address in RAM), has been corrupted somehow.
    Please check that before you call sd_clock_hfclk_is_running().
    The content should, in your case, always be 00001000. it is that address at which the MBR stores where to forward interrupts and 0x1000 will make MBR forward interrupts to Softdevice.
    You can check this, for example, by adding the following code before the call to sd_clock_hfclk_is_running that fails, and see if you get stuck there, and tell us what the value at 0x20000000 is if it hangs there:
    if(*((uint32_t*)0x20000000)!=0x1000)
    while(1);
    Or maybe you can just connect with debugger and see what content is at 0x20000000 when the program has crashed.
    -Priyanka
