SPIS with nRF54L15 with the current Development Kit
Hello !
I'm trying to adapt the code from the master-slave SPI example (https://github.com/too1/ncs-spi-master-slave-example) for my nRF54L15 development kit.
The master part runs smoothly, but when it comes to the slave, I get a linking error on build (undefined reference to `__device_dts_ord_72' ).
When I look in build/zephyr/include/generated.devicetree_generated.h, I have Node 72 =  /soc/peripheral@50000000/spi@c8000
When I look in build/zephyr/zephyr.dts, I have :
			spi22: spi_slave: spi@c8000 {
				compatible = "nordic,nrf-spis";
				#address-cells = < 0x1 >;
				#size-cells = < 0x0 >;
				reg = < 0xc8000 0x1000 >;
				interrupts = < 0xc8 0x1 >;
				max-frequency = < 0x7a1200 >;
				easydma-maxcnt-bits = < 0x10 >;
				status = "okay";
				pinctrl-0 = < &spi_slave_default >;
				pinctrl-1 = < &spi_slave_sleep >;
				cs-gpios = < &gpio1 0x0 0x1 >;
				def-char = < 0x0 >;
My .overlay file look like this :
//Disable everything that could collide, test only
&spi20 {
    status = "disabled";
&spi21 {
&spi30 {
&i2c20 {
&i2c21 {
&i2c22 {
&i2c30 {
&uart30 {
&uart22 {
&spi22{
    status = "okay";
&pinctrl {
    spi_slave_default: spi_slave_default {
        group1 {
            psels = <NRF_PSEL(SPIS_MOSI, 1, 2)>,
                    <NRF_PSEL(SPIS_SCK, 1, 1)>,
                    <NRF_PSEL(SPIS_MISO, 1, 3)>;
    spi_slave_sleep: spi_slave_sleep {
        group1 {
            low-power-enable;
spi_slave: &spi22 {
    status = "okay";
	max-frequency = <DT_FREQ_M(8)>;
    pinctrl-0 = <&spi_slave_default>;
    pinctrl-1 = <&spi_slave_sleep>;
	cs-gpios = <&gpio1 0 GPIO_ACTIVE_LOW>;
	def-char = <0>;
In my .conf file, I have enabled CONFIG_SPI and CONFIG_SPI_SLAVE.
the simplified main.c looks like this :
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/spi.h>
#define SPI_SLAVE DT_NODELABEL(spi_slave)
const struct device *my_spi_slave;
static void spi_slave_init(void)
	my_spi_slave = DEVICE_DT_GET(SPI_SLAVE);
	if(!device_is_ready(my_spi_slave)){
		LOG_ERR("SPI master device not ready!");
int main(void){
spi_slave_init();
Whenever I call spi_slave_init(), I have the error on build.
I tried using :
#if !DT_NODE_EXISTS(DT_NODELABEL(spi_slave))
#error "Invalid Node Identifier !"
But it builds correctly (without the spi_slave_init() line).
I also tried to build the same main.c with a nRF52 config by adapting the .overlay file, and it runs smoothly.
If anyone has a clue, I would appreciate this !
Have a good day,
Hugo
