Edge Impulse Wrapper - without additional buffer
we are currently trying to implement an edge impulse model (keyword spotting, 600 ms window @ 16kHz) on a nRF52832.
The problem is that the SoC's RAM is already very full and barely fits our audio slab buffer, the library itself and the stuff that's already on it.
It seems like the wrapper requires an additional internal buffer to hold the samples. This unfortunately doesn't fit and we would like to point directly to the audio buffer that already contains our raw samples.
I would be grateful if you could give us a hint on how to achieve that.
Thank you very much.
Edit 1: What I probably have to do is to drastically reduce the "audio slab" size and use the wrapper's buffer to accumulate the data using the "ei_wrapper_add_data()" function.
What creates a problem then, however, is that the wrapper uses a float array. I have space for my 600 ms window filled with int16 samples but not for a float32 array of the same length :/
Edit 2: It seems like the ei_wrapper_add_data() function only accepts data inputs of the window length or larger. If I am not mistaken, that means that I need space for at least 2x the window length (which I don't have). For me only the following scenarios would work:
1. Small memory slab for the input audio that gradually fills the wrapper's buffer. When full -> run classifier on buffer data
2. Using only the audio data slab of total size = window size. Wait until slab is full -> run classifier on slab data
I don't need any continuous streaming functionality right now. Therefore "Filling buffer -> running inference -> filling buffer -> ...." would work for me.
  • Hi again,
    Here's some input from one of our engineers who's had a deeper dive into the EI SDK:
    What should be happening is that they have a ping-pong buffer to store one window (20ms I think is EI's default window size) of raw incoming audio samples at 16bit, another buffer also windows size padded out to the next power of 2 (for calculating MFCCs), and a 3rd buffer to accumulate MFCCs in.
    It appears that all of EI's signal processing is done in f32, so the 2nd buffer will need to be f32, as well as possibly the 3rd if they don't quantize on the fly.
    If by slab buffer the OP means a buffer to hold 600ms of audio, that is completely unnecessary(unless the CPU can't keep up). But I don't know EI well enough how to restructure this. I don't think trying to re-do all the signal processing in int16 is going to work; the model is trained w/ the float implementation so it should be inferred with float as well.
    So the flow should be to:
    1. capture one window (20ms) of audio in ping buffer.
    2. Switch DMA to the pong buffer (if it's a circular buffer, set the threshold interrupt to 50%).
    3. Extract MFCCs on ping buffer, save them to MFCC buffer.
    4. Repeat above, alternating ping/pong until 600ms is captured.
    5. Perform inference.
    This all depends on being able to calculate the MFCCs for a single window within a window's frame of time.
    A short-cut could be use 8kfps audio. Cuts the audio buffers in half. Most voice is below 4K, and we've actually seen improvements using 8K audio, I think because the MFCCs comb filters are narrower. That's just anecdotal though.
    This will unfortunately be close to the limit of what we can offer of support for this, since our knowledge is somewhat limited w.r.t the EI SDK and how it works.
    Hope that this is helpful (not too obvious or abstract)
    Andreas
  • Hei Andreas,
    thank you very much for your input and I apologize for the late reply.
    Unfortunately, after the holidays, we don't have the resources anymore to continue our work on this and we have to omit running the NN at the edge on a nRF52. Maybe we'll get a bigger chip at some point or more time for trying to implement the approach you explained above.
    Thank you very much again for your support.
    Best regards, Nordix
  • Heihei,
    Thanks for the heads up and I wish you the best of luck with your research moving forward.
    As always feel free to open new cases for any nRF/Nordic related questions or reach out if you have any questions regarding how to get access to a bigger chip.
    I'll mark this case as resolved/closed for now, but I won't close the discussion so you can still comment to reopen the discussion
    Andreas
