I'm working on adapting ST's RFAL NFC library for ST25R3916B/X-NUCLEO-NFC08A1 on an nRF5340/DK in order to emulate an NFC tag, and have run into an inconsistency I'm hoping for help on. When I run the RFAL, the vast majority of SPI transactions run without any problems. At minimum two points, I get the below error:
The RFAL requires that a mechanism to lock interrupts be provided; this is alongside manual CS control so that multiple SPI transactions to be chained (see below for example code). st25r3916comStart() disables interrupts and sets CS active (low); st25r3916comStop sets CS inactive (high) and reenables interrupts. My abstractions of those functions just call irq_lock and store the key, then irq_unlock() with the same key, in order, as expected. However, I'm seeing SPI behavior where when, during a set of transactions (after irq_lock() has been called) the ISR is still executed. Please see the below capture + table for the behavior, described in the following steps:
- The 5340 sends a 0x42 to read register 02.
- An IRQ is sent, unrelated to the 0x42.
- In the ISR, the 5340 sends a 0x5A to read the interrupt registers. Instead of a 0x00 from the ST25 as usual, it sends 0x83 because from the ST25's perspective, it's still responding to the 0x42.
- The 5340 sends four 0xFF frames to read the four IRQ registers, and gets the IRQ (TXE in this case).
- The IRQ goes low. Control returns to the main thread. CS goes high because the response is complete.
During step 3, the SPI peripheral attempts to put the 0x83 into a nullptr, causing a memory access exception (I think). What I don't understand is why the next four 0xFFs were sent, as the host should have already crashed.
My GPIO IRQ init is below as well, it initializes without any problems. This is the IRQ pin associated with the SPI instance.
This is not the irq_lock() behavior I expected. CONFIG_USERSPACE is not set, so this is a supervisor thread. Please let me know what I should adjust to get the expected behavior.
st25r3916comStart();
st25r3916comTxByte( ST25R3916_FIFO_READ, true, false );
st25r3916comRepeatStart();
st25r3916comRx( buf, length );
st25r3916comStop();
