LED array indication while dfu process in MCU boot
I am working on a project where my hardware includes an array of LEDs. I want to run an LED pattern on the array during the DFU process. I have tried to find a solution for this and found that there is an MCUboot indication LED macro available in Zephyr. However, I am unsure how to implement this on an array of LEDs.
  • Hi Abhijith,
    Thank you for your response.
    It's okay if you can't compare the nRF5 SDK and the nRF Connect SDK. thank you for your help with the MCUBOOT_INDICATION_LED configuration.
    Regarding the firmware packets, I have managed to implement a solution
    In case you don't want to modify sdk code, I used MCUmgr callbacks to implement something similar to what you describe:
    https://docs.zephyrproject.org/latest/services/device_mgmt/mcumgr_callbacks.html
    However, I would still like to know which driver file or BLE service file handles the downloading of packets from BLE. Additionally, it seems the MCUBOOT_INDICATION_LED is only for UART. Even after enabling it, the LED did not blink. I also tried printing logs in the main.c file of zephyr/boot to see where the code sets the LED, but none of those logs printed during a DFU over BLE. The only logs that printed were from the LED initialization function. It appears the indication LED may not be working for DFU over BLE.
  • hello Priyesh,
    DFU over BLE is primarily managed by the Simple Management Protocol (SMP) service in the nRF Connect SDK. I recommend checking ncs\v2.x.x\zephyr\subsys\mgmt\mcumgr\transport\smp_bt.c, which handles the Bluetooth transport layer specific to SMP, and smp.c, which handles the core SMP.
    Yes, you are right that the MCUBOOT_INDICATION_LED feature is typically used for UART-based DFU and might not be directly tied to the BLE DFU process. I think you can achieve this by modifying the SMP callbacks
    Kind Regards,
    Abhijith
  • Thank you Abhijith,
    I will try with these files also.
