noinit region of RAM also takes up Flash space
I'm working with a nRF54L15 within the nRF Connect SDK on Zephyr. I need an array which retains its content through soft resets, so in another RAM section than the usual bss/data. I'm familiar with doing this on projects where I have full control over linker scripts and the likes and used to do this on nRF52 without any issue, but I'm new to Zephyr.
I found this Q/A and the appropriate zephyr macro to achieve this, and it works well. The issue is that my array not only takes up RAM, but also Flash, which doesn't make sense as it's just a static array with no initialization values.
Here's how it's declared:
#include <zephyr/linker/section_tags.h>
#include <zephyr/toolchain.h>
#include <stdint.h>
static __noinit uint8_t persistent_array[24*1024];
static __noinit uint32_t persistent_crc32;
// .. some functions to read/write in this array
And here's the output of `size -A zephyr.elf`:
build/zephyr/zephyr.elf  :
section        size        addr
rom_start        1148           0
text        155692        1152
.ARM.exidx        8      156844
initlevel        168      156852
device_area        160      157020
sw_isr_table        2168      157180
_static_thread_data_area                                                          48      159352
bt_l2cap_fixed_chan_area                                                          36      159400
bt_conn_cb_area        32      159436
bt_gatt_service_static_area                                                       48      159468
settings_handler_static_area                                                     120      159516
tbss        8      159636
rodata        12600      159648
.ramfunc        0   536870912
datas        2332   536870912
device_states        16   536873244
k_mem_slab_area        84   536873260
k_mutex_area        120   536873344
k_msgq_area        48   536873464
k_sem_area        24   536873512
k_event_area        24   536873536
k_fifo_area        24   536873560
net_buf_pool_area        308   536873584
._NOINIT_SECTION_NAME."CMAKE_SOURCE_DIR/src/dummy/dummy_array.c".1                 4   536873892
._NOINIT_SECTION_NAME."CMAKE_SOURCE_DIR/src/dummy/dummy_array.c".0             24576   536873896
bss        13697   536898472
noinit        22624   536912176
.comment        64           0
.debug_aranges        17648           0
.debug_info        2255551           0
.debug_abbrev        133539           0
.debug_line        368703           0
.debug_frame        48492           0
.debug_str        157143           0
.debug_loc        434689           0
.debug_ranges        57856           0
.ARM.attributes        56           0
.last_section        4      199808
Total        3709862
And the linker summary after building:
           FLASH:      199812 B      1524 KB     12.80%
             RAM:       63888 B       256 KB     24.37%
        IDT_LIST:          0 GB        32 KB      0.00%
For comparison, if I set the array size to 4:
           FLASH:      175224 B      1524 KB     11.23%
             RAM:       39320 B       256 KB     15.00%
Is there a way through Zephyr to have such a persistent linker section which only takes up RAM and not Flash ? I don't care what the initial data is, if it wasn't persistent it would just go to .bss.
edit: Forgot to add that this is a fresh new project, so close to nothing changed compared to the base example project following Nordic's tutorial.
Thanks for any help you can provide
  • Hi tf_tdm,
    I tried to do replicate your issue myself with Hello World sample, but I cannot reproduce it. The variables don't take space on FLASH as expected.
    I tried to have another array with initialized value but still .noinit, but runs into some error with the linker trying to put it into bss. I didn't try to further to make it work.
    Could you please give more details about your setup so that I can reproduce it and try to find out what is wrong?
    Hieu
  • Hi Hieu, thanks for looking into this. Could it be related with the nRF Connect SDK version ? I'm on 2.6.99-cs2 , although I just saw in the getting started guide that -cs1 is the one recommended. Or should we take a more recent version, e.g. one of the 2.7.0 tags ?
    Regarding the setup, we build using nrf-docker with very little modifications, sdk_nrf_version=v2.6.99-cs2 as parameter and the toolchain 2.6.0. The Dockerfile is based on nrf-docker hash 8ffb5e32e549c205834ffcc976df615f96715a75 (still the latest commit of the main branch at the time I'm writing this)
  • Hi tf_tdm,
    It's hard to tell for sure, but my hunch is that the version doesn't matter. I would try to look at something else first, but you can explore that direction if you wish.
    I am honestly unfamiliar with the Docker setup, and I worry that for me to learn it and then set up will take significant amount of time, more so during this busy summertime.
    Could you please try building my project on your setup to see if the issue is reproduced?
    Here is it: hello_world_261_01.zip
    If not, could you create a minimal setup where you reproduce the issue and send it to me?
    Hieu
