Can't get UART to work via GPIO interface
I need to use UART0 of the nRF9161 via Tx(P0.27) and Rx(P0.26) for serial communication.  There is no CTS/RTS signal.
I used the code from Lesson 5 of the DevAcademy. i can't get it to work. The code right after int main(void) checking for device availability show no active (when tested in debug mode)
I have a feeling my code does not have right setup for the UART. I spent countless hours to debug and read to fix - but no luck.
i would appreciate if you can please review and provide recommendations for resultion.
BTw, the code complies and build to the end.
 * Copyright (c) 2016 Intel Corporation
/* Controlling LEDs through UART. Press 1-3 on your keyboard to toggle LEDS 1-3 on your development kit */
#include <zephyr/kernel.h>
#include <zephyr/device.h>
/* STEP 3 - Include the header file of the UART driver in main.c */
#include <zephyr/drivers/uart.h>
 *struct uart_config{
 *  uint32_t baudrate;
 *  uint8_t parity;
 *  uint8_t stop_bits;
 *  uint8_t data_bits;
 *  uint8_t flow_ctrl;
const struct uart_config uart_cfg = {
    .baudrate = 9600,
    .parity = UART_CFG_STOP_BITS_1,
    .data_bits = UART_CFG_DATA_BITS_8,
    .flow_ctrl = UART_CFG_FLOW_CTRL_NONE
/* 1000 msec = 1 sec */
#define SLEEP_TIME_MS   100
/* STEP 10.1.1 - Define the size of the receive buffer */
#define RECEIVE_BUFF_SIZE 113
/* STEP 10.2 - Define the receiving timeout period */
#define RECEIVE_TIMEOUT 100
/* STEP 5.1 - Get the device pointers of the LEDs through gpio_dt_spec */
/* The nRF7002dk has only 2 LEDs so this step uses a compile-time condition to reflect the DK you are building for */
#if defined (CONFIG_BOARD_NRF7002DK_NRF5340_CPUAPP)|| defined (CONFIG_BOARD_NRF7002DK_NRF5340_CPUAPP_NS)
static const struct gpio_dt_spec led0 = GPIO_DT_SPEC_GET(DT_ALIAS(led0), gpios);
static const struct gpio_dt_spec led1 = GPIO_DT_SPEC_GET(DT_ALIAS(led1), gpios);
#else
static const struct gpio_dt_spec led2 = GPIO_DT_SPEC_GET(DT_ALIAS(led2), gpios);
/* STEP 4.1 - Get the device pointer of the UART hardware */
const struct device *uart= DEVICE_DT_GET(DT_NODELABEL(uart0));
int uart_configure(const struct device *dev, const struct uart_config *cfg);
/* STEP 9.1 - Define the transmission buffer, which is a buffer to hold the data to be sent over UART */
static uint8_t tx_buf[] =  {"nRF Connect SDK Fundamentals Course\n\r"
                          "Press 1-3 on your keyboard to toggle LEDS 1-3 on your development kit\n\r"};
/* STEP 10.1.2 - Define the receive buffer */
static uint8_t rx_buf[RECEIVE_BUFF_SIZE] = {0};
/* STEP 7 - Define the callback function for UART */
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
    switch (evt->type) {
    case UART_RX_RDY:
        if((evt->data.rx.len) == 1){
        if(evt->data.rx.buf[evt->data.rx.offset] == '1')
            gpio_pin_toggle_dt(&led0);
        else if (evt->data.rx.buf[evt->data.rx.offset] == '2')
            gpio_pin_toggle_dt(&led1);
    #else
        else if (evt->data.rx.buf[evt->data.rx.offset] == '3')
            gpio_pin_toggle_dt(&led2);
    case UART_RX_DISABLED:
        uart_rx_enable(dev ,rx_buf,sizeof rx_buf,RECEIVE_TIMEOUT);
    int ret;
    int err = uart_configure (uart, &uart_cfg);
    if (err == -ENOSYS) {
        return -ENOSYS;
/* STEP 4.2 - Verify that the UART device is ready */
    if (!device_is_ready(uart)){
        printk("UART device not ready\r\n");
        return 1 ;
/* STEP 5.2 - Verify that the LED devices are ready */
    if (!device_is_ready(led0.port)){
        printk("GPIO device is not ready\r\n");
        return 1;
/* STEP 6 - Configure the GPIOs of the LEDs */
    ret = gpio_pin_configure_dt(&led0, GPIO_OUTPUT_ACTIVE);
    if (ret < 0) {
        return 1 ;
    ret = gpio_pin_configure_dt(&led1, GPIO_OUTPUT_ACTIVE);
    if (ret < 0) {
        return 1 ;
#else
    if (ret < 0) {
        return 1 ;
    if (ret < 0) {
        return 1 ;
    ret = gpio_pin_configure_dt(&led2, GPIO_OUTPUT_ACTIVE);
    if (ret < 0) {
        return 1 ;
/* STEP 8 - Register the UART callback function */
    ret = uart_callback_set(uart, uart_cb, NULL);
        if (ret) {
            return 1;
/* STEP 9.2 - Send the data over UART by calling uart_tx() */
    ret = uart_tx(uart, tx_buf, sizeof(tx_buf), (-1));
    if (ret) {
        return 1;
/* STEP 10.3  - Start receiving by calling uart_rx_enable() and pass it the address of the receive  buffer */
    ret = uart_rx_enable(uart ,rx_buf,sizeof(rx_buf),(-1));
    if (ret) {
        return 1;
    while (1) {
        k_msleep(SLEEP_TIME_MS);
