Secure bootloader ble with UART
HI currently  i am utilizing sdk ver 17.1.10  nrf52840 s140 we are using dfu/secure_bootloader/pca10056_ble app and i need to add UART app to it so that so we need both bootloader ble  advertiser and with UART added to it   currently we have added UART to it but whenever we call app_uart_put() function it was unable to advertise if we comment this function it is advertising as dfuTarg can you suggest me any steps to add uart to the secure bootloader /ble so that both peripheral can be utilized f it is possible NOTE: We referred secure bootloader /pca10056_uart  example but in this sdk it will not advertise so we need both advertiser + Uart
  • Hi AP1,
    You have created a new ticket for this BLE connection issue, so let's try to fix the issue over there.
    Regarding the requirement you have listed here, what kind of help do you expect from the community and Nordic here? I am a little unclear.
    There is one part in your requirement that says that the image is only saved to flash if the image is for the current device.
    Whether this is possible or not depends on what you mean by saved to flash. The image itself is always downloaded to flash memory. It is just first downloaded to the unused spare space, and then copied over to the application region when confirmed. Refer to: nRF5 SDK v17.1.0: Dual-bank and single-bank updates (nordicsemi.com).
    As for transferring the image to another device over UART, you will want to take a look at the experimental NRF_DFU_SUPPORTS_EXTERNAL_APP feature.
    It is discussed in this DevZone case:  OTA from application layer .
    I do not think you will want to enable UART as a DFU transport if you are doing this. If I understand correctly, the DFU libraries and bootloader just trigger a user implemented callback to start sending the image and does not itself take part in the sending. You will only need to enable UART functionality like you do in a regular app. I am not 100% certain about this last part, please go over the resources mentioned in the linked DevZone case.
  • 1. Hi thanks for your reply let me explain in simple way in booloader_ble_debug sdk after while performing dfu the new firmware is going to write in the flash instead of writing the data in flash the same should be sent in the uart
    2. flash -> replace with UART transfer
    3. So whenever it is required we will write in flash or we will send same data in UART only one at a time
    4. we need to achieve this in booloader_ble_debug app
    New_firmware_write_func
    if(cond)
    uart_tx(data)
     rc = nrf_fstorage_write(&m_fs, dest, p_src, len, (void *)callback);
  • I really sorry, but I am still unclear what the problem or question is, or if there is any.
    Could you please use shorter sentences and more punctuations?
  • Hi our requirement is instead of writing the data in flash for new bin the same bin data should be tx via uart we will comment the flash writing part in bootloader_ble_debug NOTE: this one we need to achieve through he secure_booloader/ble_bootloader_debug sdk
  • Unfortunately, I still don't understand what you want help with, or if there is any issue at all.
