Aconno ACN52840 module does not resetting after programming by J-Link, RTT not working.
After problems with the programmer I have successfully flashed simple custom board with ACN52840 module, but the unit does not resetting after flashing using J-Link Pro. Starting after grounding reset pin or "nrfjprog --reset".
Terminal show:
Enabling pin reset.
Applying pin reset.
Simple board configuration:
3xVCC shorted
3xGND shorted
470uF capacitor across supply
Reset pulled-up by 10kohm.
Jlink pro connected to SWDIO, SWDCLK, GND, Vcc.
Another maybe related is that there is nothing on RTT viewer, on the nrf52840DK RTT and reset after programing is working as it should.
  • I do not have schematic, it is absolute minimum for testing:
    ACN52840
    3xVdd shorted
    3xGND shorted
    470uF capacitor across Vdd-GND supply
    Reset pulled-up to Vdd by 10kohm.
    Jlink pro connected in 4-wire configuration to SWDIO, SWDCLK, GND, Vdd.
    Measured voltage on nRESET and Vdd: 2.97V
    Reset of programmer is NOT CONNECTED to module reset pin.
    I tought that reset after programming is applied using SWD lines the same like with command "nrfjprog --reset" but probably not and need electrical connection of Jlink with nRESET(in this configuration it is working fine).
    Maybe there is some option in VSC SDK to run command "nrfjprog --reset" after flashing. For space saving I wish to avoid extra 5th pin for nRESET purpose.
    Please forget about RTT it is sorted out now, I missed CONFIG_USE_SEGGER_RTT=y , CONFIG_RTT_CONSOLE=y in prj.conf, which was not mentioned in the nRF SDK fundamentals course.
    Can you describe in more detail how you flash the board? Are you using VS Code nRF extension or are you flashing a precompiled hex using nRF Command Line Tools?
    Yes, the programmer will issue a reset through the SWD interface when it's done programming, not through the pin reset unless it's explicitly done by adding --pinreset argument. Based on your earlier description I thought that the pin reset was indeed connected to the J-tag interface.
    Do you see the same issue if you try to flash an unmodified sample from the nRF Connect SDK such as the peripheral UART sample?
    Do you see the device advertising after flashing without having to power cycle it? Note, that this sample requires you to either have onboard LF crystal or change the LFCLK source to internal RC oscillator. I just want to make sure that this issue is not related to your custom application somehow.
    regards
    Jared
  • Hi, confirm, using VS Code nRF extension. UART example behave the same like my board, starts working after enforced reset.
    Can you share the whole log from the vs code terminal when you flash the board with the UART sample and it does not start before the enforced reset?
    regards
    Jared
