nRF Connect SDK v2.6.1 - https_client works for example.com but not other hosts such as google.com
With nRF7002DK and TF-M (nrf7002dk_nrf5340_cpuapp_ns.conf) configuration, the sample project works for example.com:
*** Booting nRF Connect SDK v3.5.99-ncs1-1 ***
HTTPS client sample started
Bringing network interface up
Provisioning certificate
Connecting to the network
[00:00:04.949,981] <inf> wifi_mgmt_ext: Connection requested
[00:00:09.183,044] <inf> net_dhcpv4: Received: 192.168.101.16
Network connectivity established and IP address assigned
Looking up example.com
Resolved 93.184.215.14 (AF_INET)
Connecting to example.com:443
Sent 61 bytes
Received 377 bytes
> HTTP/1.1 200 OK
Finished, closing socket.
Network connectivity lost
Disconnected from the network
However, replace the host with google.com and its associated CA:
[00:00:45.647,186] <inf> wifi_mgmt_ext: Connection requested
[00:00:49.878,845] <inf> net_dhcpv4: Received: 192.168.101.16
Looking up google.com
Resolved 142.250.191.206 (AF_INET)
Connecting to google.com:443
connect() failed, err (22): Invalid argument
  • I enabled the MbedTLS logging and force the lenght log as error. The log messages showed that the received message length was less than what the handshake header indicated 4642 vs 4096:
    [00:00:07.373,260] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3869: input record: msgtype = 22, version = [0x303], msglen = 98
    [00:00:07.373,413] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3242: handshake message: msglen = 98, type = 2, hslen = 98
    [00:00:07.373,718] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3869: input record: msgtype = 22, version = [0x303], msglen = 4096
    [00:00:07.376,678] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3869: input record: msgtype = 22, version = [0x303], msglen = 4096
    [00:00:07.379,730] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3869: input record: msgtype = 22, version = [0x303], msglen = 4096
    [00:00:07.382,019] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3869: input record: msgtype = 22, version = [0x303], msglen = 4096
    [00:00:07.382,202] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3242: handshake message: msglen = 4096, type = 11, hslen = 4642
    [00:00:07.382,263] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3308: TLS handshake fragmentation not supported
    [00:00:07.382,354] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:4177: mbedtls_ssl_handle_message_type() returned -28800 (-0x7080)
    [00:00:07.382,446] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7536: mbedtls_ssl_read_record() returned -28800 (-0x7080)
    connect() failed, err (113): Software caused connection abort
    Google.com happened to have the largest hslen as 4010.
    Thank you for the log. We are continuin to look into this and will get back to you by the end of the week.
    Google is using a single certificate for all their domains, which means that they have to squeeze in over 450 DNS entries into the SAN (Subject Alternate Name) extension in the certificate. This is why their certificate is so big (over 4096 bytes).
    The main issue is that zephyr/mbedtls restricts the maximum TLS fragment length to 4096 here and mbed TLS is not able to handle fragmented handshake messages, unfortunately (see this comment). So every message over 4096 bytes will be truncated.
    If we simply skip the check and allow for any fragment size the TLS-handshake can succeed. This is done by adding the config:
    CONFIG_NET_SOCKETS_TLS_SET_MAX_FRAGMENT_LENGTH=n
    However, there may be unforseen onsequences of skippingthe check. So, it is probably better to create your own fragment length of 8192, which should be okay by looking at the recommendations here.
    You also need to incrase a number of configs to make it work (you may not need to incrase the top three as much as here, though):
    CONFIG_MBEDTLS_HEAP_SIZE=80000
    CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=8192
    CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=8192
    CONFIG_PSA_WANT_RSA_KEY_SIZE_4096=y
    CONFIG_MBEDTLS_MPI_MAX_SIZE=512
    Br,
    Einar
  • The existing configurations worked for www.google.com before because it seems that the fragment size was less than 4096. However, even with the suggested configuration, it still have troubles with the certificate fragment that is bigger than 4096, as in the case of auth0 or azure. When the size is not an issue for the link: www.auth0.com. I have this error from Mbedtls:
    Looking up www.auth0.com
    Resolved 104.17.254.182 (AF_INET)
    Connecting to www.auth0.com:443
    [00:00:06.605,346] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3242: handshake message: msglen = 91, type = 2, hslen = 91
    [00:00:06.610,656] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_msg.c:3242: handshake message: msglen = 3479, type = 11, hslen = 3479
    [00:00:06.614,685] <err> mbedtls: WEST_TOPDIR/modules/crypto/mbedtls/library/ssl_tls.c:7192: mbedtls_x509_crt_parse_der() returned -14848 (-0x3a00)
    Do I need pick a particular cipher?
    Regardign long certificates, did you tern off max frament length negotiations using CONFIG_NET_SOCKETS_TLS_SET_MAX_FRAGMENT_LENGTH=n? If max-fragment-length negotiation is enabled every TLS handshake message over 4k will be fragmented, and re-assembly of TLS handshake message fragments is not supported in mbed TLS (see here).
    Regardign the -0x3a00 error you get with auth0, that is MBEDTLS_ERR_PK_UNKNOWN_NAMED_CURVE. It seems auth0 requiers p256r1 (so you need CONFIG_PSA_WANT_ECC_SECP_R1_256=y) and also x25519 (CONFIG_PSA_WANT_ECC_MONTGOMERY_255=y) and one of aes-128 gcm, aes-256 gcm or chachapoly (see Driver configurations and supported features for enabling support for that, for instance
    CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305=y).
