Can't build Guiconfig in nRF Connect on Mac
I have nRF Connect SDK v2.6.1 installed on a Mac, the latest toolchain installed via nRF Connect for Desktop, and VSCode with all the nRF extensions.  Everything works pretty well except that I cannot build and run the guiconfig tool.  The Python terminal window shows the following results:
* Executing task: west build -d /Users/Glen/Documents/Projects/nordic/ncs-inter/inter_less1_exer2/build -t guiconfig
-- west build: running target guiconfig
[0/1] cd /Users/Glen/Documents/Projects/nordic/ncs-inter/inter_less1_exer2/bui....6.1/zephyr/scripts/kconfig/guiconfig.py /opt/nordic/ncs/v2.6.1/zephyr/Kconfig
File "/opt/nordic/ncs/v2.6.1/zephyr/scripts/kconfig/guiconfig.py", line 2331, in <module>
_main()
File "/opt/nordic/ncs/v2.6.1/zephyr/scripts/kconfig/guiconfig.py", line 105, in _main
menuconfig(standard_kconfig(__doc__))
File "/opt/nordic/ncs/v2.6.1/zephyr/scripts/kconfig/guiconfig.py", line 183, in menuconfig
_create_ui()
File "/opt/nordic/ncs/v2.6.1/zephyr/scripts/kconfig/guiconfig.py", line 295, in _create_ui
_root = Tk()
File "/opt/nordic/ncs/toolchains/580e4ef81c/Cellar/[email protected]/3.9.6/Frameworks/Python.framework/Versions/3.9/lib/python3.9/tkinter/__init__.py", line 2270, in __init__
self.tk = _tkinter.create(screenName, baseName, className, interactive, wantobjects, useTk, sync, use)
_tkinter.TclError: Can't find a usable init.tcl in the following directories:
/usr/local/Cellar/tcl-tk/8.6.11_1/lib/tcl8.6 /opt/nordic/ncs/toolchains/580e4ef81c/Cellar/[email protected]/3.9.6/lib/tcl8.6 /opt/nordic/ncs/toolchains/580e4ef81c/Cellar/[email protected]/lib/tcl8.6 /opt/nordic/ncs/toolchains/580e4ef81c/Cellar/[email protected]/3.9.6/library /opt/nordic/ncs/toolchains/580e4ef81c/Cellar/[email protected]/library /opt/nordic/ncs/toolchains/580e4ef81c/Cellar/[email protected]/tcl8.6.11/library /opt/nordic/ncs/toolchains/580e4ef81c/Cellar/tcl8.6.11/library
This probably means that Tcl wasn't installed properly.
FAILED: CMakeFiles/guiconfig /Users/Glen/Documents/Projects/nordic/ncs-inter/inter_less1_exer2/build/CMakeFiles/guiconfig
cd /Users/Glen/Documents/Projects/nordic/ncs-inter/inter_less1_exer2/build/zephyr/kconfig && /opt/nordic/ncs/toolchains/580e4ef81c/Cellar/cmake/3.21.0/bin/cmake -E env ZEPHYR_BASE=/opt/nordic/ncs/v2.6.1/zephyr PYTHON_EXECUTABLE=/opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 srctree=/opt/nordic/ncs/v2.6.1/zephyr KERNELVERSION=0x3056300 APPVERSION= APP_VERSION_EXTENDED_STRING= APP_VERSION_TWEAK_STRING= CONFIG_=CONFIG_ KCONFIG_CONFIG=/Users/Glen/Documents/Projects/nordic/ncs-inter/inter_less1_exer2/build/zephyr/.config ARCH=arm ARCH_DIR=/opt/nordic/ncs/v2.6.1/zephyr/arch BOARD_DIR=/opt/nordic/ncs/v2.6.1/nrf/boards/arm/nrf7002dk_nrf5340 BOARD_REVISION= KCONFIG_BINARY_DIR=/Users/Glen/Documents/Projects/nordic/ncs-inter/inter_less1_exer2/build/Kconfig APPLICATION_SOURCE_DIR=/Users/Glen/Documents/Projects/nordic/ncs-inter/inter_less1_exer2 ZEPHYR_TOOLCHAIN_VARIANT=zephyr TOOLCHAIN_KCONFIG_DIR=/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/cmake/zephyr TOOLCHAIN_HAS_NEWLIB=y TOOLCHAIN_HAS_PICOLIBC=y HIDE_CHILD_PARENT_CONFIG= EDT_PICKLE=/Users/Glen/Documents/Projects/nordic/ncs-inter/inter_less1_exer2/build/zephyr/edt.pickle NCS_MEMFAULT_FIRMWARE_SDK_KCONFIG=/opt/nordic/ncs/v2.6.1/nrf/modules/memfault-firmware-sdk/Kconfig ZEPHYR_NRF_MODULE_DIR=/opt/nordic/ncs/v2.6.1/nrf ZEPHYR_MCUBOOT_MODULE_DIR=/opt/nordic/ncs/v2.6.1/bootloader/mcuboot ZEPHYR_MCUBOOT_KCONFIG=/opt/nordic/ncs/v2.6.1/nrf/modules/mcuboot/Kconfig ZEPHYR_MBEDTLS_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/crypto/mbedtls ZEPHYR_MBEDTLS_KCONFIG=/opt/nordic/ncs/v2.6.1/zephyr/modules/mbedtls/Kconfig ZEPHYR_TRUSTED_FIRMWARE_M_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/tee/tf-m/trusted-firmware-m ZEPHYR_TRUSTED_FIRMWARE_M_KCONFIG=/opt/nordic/ncs/v2.6.1/nrf/modules/trusted-firmware-m/Kconfig ZEPHYR_PSA_ARCH_TESTS_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/tee/tf-m/psa-arch-tests ZEPHYR_CJSON_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/cjson ZEPHYR_CJSON_KCONFIG=/opt/nordic/ncs/v2.6.1/nrf/modules/cjson/Kconfig ZEPHYR_AZURE_SDK_FOR_C_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/azure-sdk-for-c ZEPHYR_AZURE_SDK_FOR_C_KCONFIG=/opt/nordic/ncs/v2.6.1/nrf/modules/azure-sdk-for-c/Kconfig ZEPHYR_CIRRUS_LOGIC_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/hal/cirrus-logic ZEPHYR_OPENTHREAD_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/openthread ZEPHYR_OPENTHREAD_KCONFIG=/opt/nordic/ncs/v2.6.1/zephyr/modules/openthread/Kconfig ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/memfault-firmware-sdk ZEPHYR_CANOPENNODE_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/canopennode ZEPHYR_CANOPENNODE_KCONFIG=/opt/nordic/ncs/v2.6.1/zephyr/modules/canopennode/Kconfig ZEPHYR_CHRE_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/chre ZEPHYR_LZ4_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/lz4 ZEPHYR_LZ4_KCONFIG=/opt/nordic/ncs/v2.6.1/zephyr/modules/lz4/Kconfig ZEPHYR_NANOPB_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/nanopb ZEPHYR_NANOPB_KCONFIG=/opt/nordic/ncs/v2.6.1/zephyr/modules/nanopb/Kconfig ZEPHYR_TF_M_TESTS_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/tee/tf-m/tf-m-tests ZEPHYR_ZSCILIB_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/zscilib ZEPHYR_CMSIS_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/hal/cmsis ZEPHYR_CMSIS_KCONFIG=/opt/nordic/ncs/v2.6.1/zephyr/modules/cmsis/Kconfig ZEPHYR_CMSIS_DSP_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/cmsis-dsp ZEPHYR_CMSIS_DSP_KCONFIG=/opt/nordic/ncs/v2.6.1/zephyr/modules/cmsis-dsp/Kconfig ZEPHYR_CMSIS_NN_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/cmsis-nn ZEPHYR_CMSIS_NN_KCONFIG=/opt/nordic/ncs/v2.6.1/zephyr/modules/cmsis-nn/Kconfig ZEPHYR_FATFS_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/fs/fatfs ZEPHYR_FATFS_KCONFIG=/opt/nordic/ncs/v2.6.1/zephyr/modules/fatfs/Kconfig ZEPHYR_HAL_NORDIC_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/hal/nordic ZEPHYR_HAL_NORDIC_KCONFIG=/opt/nordic/ncs/v2.6.1/zephyr/modules/hal_nordic/Kconfig ZEPHYR_ST_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/hal/st ZEPHYR_HAL_WURTHELEKTRONIK_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/hal/wurthelektronik ZEPHYR_LIBMETAL_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/hal/libmetal ZEPHYR_LIBLC3_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/liblc3 ZEPHYR_LIBLC3_KCONFIG=/opt/nordic/ncs/v2.6.1/zephyr/modules/liblc3/Kconfig ZEPHYR_LITTLEFS_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/fs/littlefs ZEPHYR_LITTLEFS_KCONFIG=/opt/nordic/ncs/v2.6.1/zephyr/modules/littlefs/Kconfig ZEPHYR_LORAMAC_NODE_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/loramac-node ZEPHYR_LORAMAC_NODE_KCONFIG=/opt/nordic/ncs/v2.6.1/zephyr/modules/loramac-node/Kconfig ZEPHYR_LVGL_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/gui/lvgl ZEPHYR_LVGL_KCONFIG=/opt/nordic/ncs/v2.6.1/zephyr/modules/lvgl/Kconfig ZEPHYR_MIPI_SYS_T_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/debug/mipi-sys-t ZEPHYR_NRF_HW_MODELS_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/bsim_hw_models/nrf_hw_models ZEPHYR_OPEN_AMP_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/open-amp ZEPHYR_PICOLIBC_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/picolibc ZEPHYR_SEGGER_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/debug/segger ZEPHYR_SEGGER_KCONFIG=/opt/nordic/ncs/v2.6.1/zephyr/modules/segger/Kconfig ZEPHYR_TINYCRYPT_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/crypto/tinycrypt ZEPHYR_UOSCORE_UEDHOC_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/uoscore-uedhoc ZEPHYR_UOSCORE_UEDHOC_KCONFIG=/opt/nordic/ncs/v2.6.1/zephyr/modules/uoscore-uedhoc/Kconfig ZEPHYR_ZCBOR_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/zcbor ZEPHYR_ZCBOR_KCONFIG=/opt/nordic/ncs/v2.6.1/zephyr/modules/zcbor/Kconfig ZEPHYR_NRFXLIB_MODULE_DIR=/opt/nordic/ncs/v2.6.1/nrfxlib ZEPHYR_CONNECTEDHOMEIP_MODULE_DIR=/opt/nordic/ncs/v2.6.1/modules/lib/matter SHIELD_AS_LIST= DTS_POST_CPP=/Users/Glen/Documents/Projects/nordic/ncs-inter/inter_less1_exer2/build/zephyr/zephyr.dts.pre DTS_ROOT_BINDINGS=/opt/nordic/ncs/v2.6.1/nrf/dts/bindings?/opt/nordic/ncs/v2.6.1/zephyr/dts/bindings /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 /opt/nordic/ncs/v2.6.1/zephyr/scripts/kconfig/guiconfig.py /opt/nordic/ncs/v2.6.1/zephyr/Kconfig
FATAL ERROR: command exited with status 1: /usr/local/bin/cmake --build /Users/Glen/Documents/Projects/nordic/ncs-inter/inter_less1_exer2/build --target guiconfig
It appears to be looking for an init.tcl file that I confirmed is not in any of the directories listed.  I confirmed that Tcl is on my Mac, version 8.5.9.
