MQTT sample problem
I' m using custom board of nrf5340 with nrf7002, and the SDK version is ncs v2.5.2.
I've tried to build and run, but the log in RTT viewer is only print the line "Bringing network interface up and connecting to the network", It seems the program is stuck, and it didn't proceed to execute.
and I wondered it is because of the MAC address, so I added the "set_mac _address" function into "network.c" and executed it in the function "network_task", but it printed other errors below.
prj.conf
#prj.conf
# Copyright (c) 2023 Nordic Semiconductor ASA
# Common configurations for all boards
CONFIG_WIFI=y
CONFIG_WIFI_NRF700X=y
CONFIG_NET_L2_WIFI_MGMT=y
CONFIG_HEAP_MEM_POOL_SIZE=25000
# System settings
CONFIG_NEWLIB_LIBC=y
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_L2_ETHERNET=y
CONFIG_NET_NATIVE=y
CONFIG_NET_OFFLOAD=y
CONFIG_INIT_STACKS=y
# Memories
CONFIG_MAIN_STACK_SIZE=4096
# General
CONFIG_HW_ID_LIBRARY=y
CONFIG_ASSERT=y
CONFIG_WIFI_CREDENTIALS_STATIC_SSID="allen"
CONFIG_WIFI_CREDENTIALS_STATIC_PASSWORD="123"
CONFIG_WIFI_CREDENTIALS_STATIC_TYPE_OPEN=y
CONFIG_MQTT_SAMPLE_TRANSPORT_BROKER_HOSTNAME="test.mosquitto.org"
CONFIG_MQTT_SAMPLE_TRANSPORT_PUBLISH_TOPIC="my/publish/topic"
CONFIG_MQTT_SAMPLE_TRANSPORT_SUBSCRIBE_TOPIC="my/subscribe/topic"
CONFIG_MQTT_SAMPLE_LED=n
CONFIG_DK_LIBRARY=n
# CONFIG_MQTT_SAMPLE_TRIGGER_THREAD_STACK_SIZE=2048
# Logging
CONFIG_LOG=y
# CONFIG_NET_LOG=y
# CONFIG_MQTT_LOG_LEVEL_DBG=y
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_IPV4=y
CONFIG_NET_TCP=y
CONFIG_NET_NATIVE=y
CONFIG_NET_CONNECTION_MANAGER=y
# ZBus
CONFIG_ZBUS=y
# Zephyr state framework
CONFIG_SMF=y
# MQTT
CONFIG_MQTT_HELPER=y
CONFIG_MQTT_CLEAN_SESSION=y
#config RTT
CONFIG_LOG=y
CONFIG_LOG_PRINTK=y
# CONFIG_LOG_MODE_DEFERRED=y
CONFIG_SERIAL=n
CONFIG_UART_CONSOLE=n
CONFIG_USE_SEGGER_RTT=y
CONFIG_CONSOLE=y
CONFIG_RTT_CONSOLE=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=4096
CONFIG_LOG_BUFFER_SIZE=4096
# Disable internal DCDC
CONFIG_BOARD_ENABLE_DCDC_APP=n
CONFIG_BOARD_ENABLE_DCDC_NET=n
CONFIG_BOARD_ENABLE_DCDC_HV=n
# Use internal capacitor for 32M xtal and set capacitor value to 8.5pF
# (ranging from 7.0 pF to 20.0 pF in 0.5 pF steps
# can be enabled on pins XC1 and XC2. This option specifies doubled
# capacitance value for the two capacitors. Set it to 14 to get 7.0 pF
# for each capacitor, 15 to get 7.5 pF, and so on.
CONFIG_SOC_HFXO_CAP_INTERNAL=y
CONFIG_SOC_HFXO_CAP_INT_VALUE_X2=17
#  Use internal capacitor for 32k xtal and set capacitor value to 7pF
# (only 4 options of internal capacitor value settings for 32k xtal
#   -INT_6PF
#   -INT_7PF
#   -INT_9PF
#   - USE external capacitor)
CONFIG_SOC_ENABLE_LFXO=y
CONFIG_SOC_LFXO_CAP_INT_7PF=y
Below is the function what I added. And this function is executed normally in the Scan sample.
int8_t wifi_set_mac_address()
	struct net_if *iface = net_if_get_default();
	uint8_t mac_addr[6] = {0xF0, 0xCE, 0x36, 0x00, 0x00, 0x4A};
	struct ethernet_req_params eth_param;
	memcpy(eth_param.mac_address.addr, mac_addr, 6);
	// if (net_if_down(iface))
	// 	printk("<Err> Couldn't shutdown WiFi interface\n");
	// 	return -1;
	printk("<Inf> Setting MAC address\n");
	if (net_mgmt(NET_REQUEST_ETHERNET_SET_MAC_ADDRESS, iface, &eth_param, sizeof(struct ethernet_req_params)))
		printk("<Err> Couldn't set new MAC Address\n");
		return -2;
	int ret = memcmp(net_if_get_link_addr(iface)->addr, mac_addr, sizeof(mac_addr));
	if (ret)
		printk("<Err> Couldn't change MAC address\n");
	if (net_if_up(iface))
		printk("<Err> Couldn't wake up interface\n");
		return -3;
	return 0;
How can I run the MQTT sample correctly?
    I've changed my MQTT broker to broker.hivemq.com and include CONFIG_WPA_SUPP_LOG_LEVEL_DBG=y, but it's still the same output.
    Custom Board
    with set_mac_address function.
    00> [00:00:00.339,782] <inf> wifi_nrf: nrf_wifi_fmac_otp_mac_addr_get: MAC addr not programmed in OTP
    00>
    00> [00:00:00.340,240] <err> wifi_nrf: nrf_wifi_if_start_zep: Invalid MAC address: 00:00:00:00:00:00
    00>
    00> [00:00:00.346,374] <inf> fs_nvs: 6 Sectors of 4096 bytes
    00> [00:00:00.346,405] <inf> fs_nvs: alloc wra: 0, fe8
    00> [00:00:00.346,405] <inf> fs_nvs: data wra: 0, 0
    00> *** Booting nRF Connect SDK v2.5.2 ***
    00> <Inf> Setting MAC address
    00> [00:00:00.349,273] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_UNINIT --> MQTT_STATE_DISCONNECTED
    00> [00:00:00.349,517] <dbg> mqtt_helper: mqtt_helper_poll_loop: Waiting for connection_poll_sem
    00> wake up interface err: 0
    00> [00:00:00.482,391] <err> wifi_nrf: nrf_wifi_wpa_supp_event_get_wiphy: Invalid parameters
    00>
    00> [00:00:10.473,236] <err> wpa_supp: 'INTERFACE_ADD wlan0  zephyr  zephyr  zephyr        ' command timed out.
    00>
    00> [00:00:10.473,327] <err> wpa_supp: Failed to add interface: wlan0
    00> [00:00:10.473,388] <inf> network: Bringing network interface up and connecting to the network
    without set_mac_address function.
    [00:00:00.341,430] <inf> wifi_nrf: nrf_wifi_fmac_otp_mac_addr_get: MAC addr not programmed in OTP
    [00:00:00.341,888] <err> wifi_nrf: nrf_wifi_if_start_zep: Invalid MAC address: 00:00:00:00:00:00
    [00:00:00.347,930] <inf> fs_nvs: 6 Sectors of 4096 bytes
    [00:00:00.347,961] <inf> fs_nvs: alloc wra: 0, fe8
    [00:00:00.347,961] <inf> fs_nvs: data wra: 0, 0
    [00:00:00.350,494] <inf> network: Bringing network interface up and connecting to the network
    [00:00:00.350,616] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_UNINIT --> MQTT_STATE_DISCONNECTED
    [00:00:00.350,860] <dbg> mqtt_helper: mqtt_helper_poll_loop: Waiting for connection_poll_sem
    I've tried the nrf7002DK, MQTT connected and transported successfully on original MQTT broker "test.mosquitto.org" without  set_mac_address function ,and it failed when adding set_mac_address function.
    NRF7002DK
    00> [00:00:00.470,825] <inf> fs_nvs: 6 Sectors of 4096 bytes
    00> [00:00:00.470,855] <inf> fs_nvs: alloc wra: 0, fe8
    00> [00:00:00.470,886] <inf> fs_nvs: data wra: 0, 0
    00> wake up interface err: -120
    00> <Err> Couldn't wake up interface
    00> [00:00:00.473,358] <inf> network: Bringing network interface up and connecting to the network
    00> [00:00:00.473,449] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_UNINIT --> MQTT_STATE_DISCONNECTED
    00> [00:00:00.475,646] <dbg> mqtt_helper: mqtt_helper_poll_loop: Waiting for connection_poll_sem
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> [00:00:02.407,104] <inf> wifi_mgmt_ext: Connection requested
    00> OK
    00> [00:00:33.420,623] <err> wpa_supp: Connection timed out, timeout: 30 seconds
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> [00:00:00.758,331] <inf> fs_nvs: 6 Sectors of 4096 bytes
    00> [00:00:00.758,361] <inf> fs_nvs: alloc wra: 0, fe8
    00> [00:00:00.758,361] <inf> fs_nvs: data wra: 0, 0
    00> [00:00:00.761,016] <inf> network: Bringing network interface up and connecting to the network
    00> [00:00:00.761,138] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_UNINIT --> MQTT_STATE_DISCONNECTED
    00> [00:00:00.763,427] <dbg> mqtt_helper: mqtt_helper_poll_loop: Waiting for connection_poll_sem
    00> [00:00:02.697,357] <inf> wifi_mgmt_ext: Connection requested
    00> [00:00:07.293,762] <inf> network: Network connectivity established
    00> [00:00:12.295,166] <dbg> mqtt_helper: broker_init: Resolving IP address for test.mosquitto.org
    00> [00:00:13.434,295] <dbg> mqtt_helper: broker_init: IPv4 Address found 91.121.93.94 (AF_INET)
    00> [00:00:13.434,356] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_DISCONNECTED --> MQTT_STATE_TRANSPORT_CONNECTING
    00> [00:00:13.818,420] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_TRANSPORT_CONNECTING --> MQTT_STATE_TRANSPORT_CONNECTED
    00> [00:00:13.818,481] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_TRANSPORT_CONNECTED --> MQTT_STATE_CONNECTING
    00> [00:00:13.818,511] <dbg> mqtt_helper: client_connect: Using send socket timeout of 60 seconds
    00> [00:00:13.818,511] <dbg> mqtt_helper: mqtt_helper_connect: MQTT connection request sent
    00> [00:00:13.822,601] <dbg> mqtt_helper: mqtt_helper_poll_loop: Took connection_poll_sem
    00> [00:00:13.822,967] <dbg> mqtt_helper: mqtt_helper_poll_loop: Starting to poll on socket, fd: 9
    00> [00:00:13.822,967] <dbg> mqtt_helper: mqtt_helper_poll_loop: Polling on socket fd: 9
    00> [00:00:14.139,373] <dbg> mqtt_helper: mqtt_evt_handler: MQTT mqtt_client connected
    00> [00:00:14.139,434] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_CONNECTING --> MQTT_STATE_CONNECTED
    00> [00:00:14.139,465] <inf> transport: Connected to MQTT broker
    00> [00:00:14.139,495] <inf> transport: Hostname: test.mosquitto.org
    00> [00:00:14.139,526] <inf> transport: Client ID: F4CE36001FE8
    00> [00:00:14.139,526] <inf> transport: Port: 1883
    00> [00:00:14.139,556] <inf> transport: TLS: No
    00> [00:00:14.139,587] <inf> transport: Subscribing to: F4CE36001FE8/my/subscribe/topic
    00> [00:00:14.139,617] <dbg> mqtt_helper: mqtt_helper_subscribe: Subscribing to: F4CE36001FE8/my/subscribe/topic
    00> [00:00:14.148,651] <dbg> mqtt_helper: mqtt_helper_poll_loop: Polling on socket fd: 9
    00> [00:00:15.461,242] <dbg> mqtt_helper: mqtt_evt_handler: MQTT_EVT_SUBACK: id = 2469 result = 0
    00> [00:00:15.461,456] <inf> transport: Subscribed to topic F4CE36001FE8/my/subscribe/topic
    00> [00:00:15.461,486] <dbg> mqtt_helper: mqtt_helper_poll_loop: Polling on socket fd: 9
    00> [00:01:00.761,566] <dbg> mqtt_helper: mqtt_helper_publish: Publishing to topic: F4CE36001FE8/my/publish/topic
    00> [00:01:00.762,664] <inf> transport: Published message: "Hello MQTT! Current uptime is: 60761" on topic: "F4CE36001FE8/my/publish/topic"
    00> [00:01:03.388,061] <dbg> mqtt_helper: mqtt_evt_handler: MQTT_EVT_PUBACK: id = 60761 result = 0
    00> [00:01:03.388,092] <dbg> mqtt_helper: mqtt_helper_poll_loop: Polling on socket fd: 9
    I think the main issue is "How to set mac address correctly?"
    Allen
  • Hi Allen,
    I apologize for not providing complete information. I have found out that in order for CONFIG_WPA_SUPP_LOG_LEVEL_DBG=y to become active you need to comment out CONFIG_WPA_SUPP_LOG_LEVEL_ERR=y in your nrf7002dk_nrf5340_cpuapp.conf file. In addition to CONFIG_WPA_SUPP_LOG_LEVEL_DBG=y, please add CONFIG_LOG_MODE_IMMEDIATE=y to your prj.conf and provide the logs in both cases.
    Dejan
    Now I can see more log messages after making the changes.
    custom board
    with set mac address function
    00> [00:00:00.444,274] <inf> wifi_nrf: nrf_wifi_fmac_otp_mac_addr_get: MAC addr not programmed in OTP
    00>
    00> [00:00:00.445,098] <err> wifi_nrf: nrf_wifi_if_start_zep: Invalid MAC address: 00:00:00:00:00:00
    00>
    00> [00:00:00.451,568] <inf> fs_nvs: 6 Sectors of 4096 bytes
    00> [00:00:00.451,873] <inf> fs_nvs: alloc wra: 0, fe8
    00> [00:00:00.452,178] <inf> fs_nvs: data wra: 0, 0
    00> [00:00:00.452,819] <dbg> wpa_supp: wpa_printf_impl: wpa_supplicant v2.11-devel
    00> [00:00:00.454,315] <inf> wpa_supp: Successfully initialized wpa_supplicant
    00> [00:00:00.456,542] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_UNINIT --> MQTT_STATE_DISCONNECTED
    00> [00:00:00.457,214] <dbg> mqtt_helper: mqtt_helper_poll_loop: Waiting for connection_poll_sem
    00> [00:00:00.579,345] <dbg> wpa_supp: wpa_printf_impl: Event: -805240828
    00> [00:00:00.579,711] <dbg> wpa_supp: wpa_printf_impl: Adding interface wlan0
    00>
    00> [00:00:00.580,230] <dbg> wpa_supp: wpa_printf_impl: Calling wpa_cli: interface_add, argc: 5
    00>
    00> [00:00:00.580,657] <dbg> wpa_supp: wpa_printf_impl: argv[0]: interface_add
    00>
    00> [00:00:00.581,054] <dbg> wpa_supp: wpa_printf_impl: argv[1]: wlan0
    00>
    00> [00:00:00.581,420] <dbg> wpa_supp: wpa_printf_impl: argv[2]: zephyr
    00>
    00> [00:00:00.581,817] <dbg> wpa_supp: wpa_printf_impl: argv[3]: zephyr
    00>
    00> [00:00:00.582,183] <dbg> wpa_supp: wpa_printf_impl: argv[4]: zephyr
    00>
    00> [00:00:00.584,014] <dbg> wpa_supp: wpa_printf_impl: RX global ctrl_iface - hexdump_ascii(len=44):
    00> [00:00:00.584,442] <dbg> wpa_supp: _wpa_hexdump_ascii:
    00>                                    49 4e 54 45 52 46 41 43  45 5f 41 44 44 20 77 6c |INTERFAC E_ADD wl
    00>                                    61 6e 30 09 7a 65 70 68  79 72 09 7a 65 70 68 79 |an0.zeph yr.zephy
    00>                                    72 09 7a 65 70 68 79 72  09 09 09 09             |r.zephyr ....
    00> [00:00:00.586,822] <dbg> wpa_supp: wpa_printf_impl: CTRL_IFACE GLOBAL INTERFACE_ADD 'wlan0  zephyr  zephyr  zephyr        '
    00> [00:00:00.587,921] <dbg> wpa_supp: wpa_printf_impl: Initializing interface 'wlan0' conf 'zephyr' driver 'zephyr' ctrl_interface 'zephyr' bridge 'N/A'
    00> [00:00:00.592,895] <dbg> wpa_supp: wpa_printf_impl: Add interface wlan0 to a new radio N/A
    00> [00:00:00.596,588] <err> wifi_nrf: nrf_wifi_wpa_supp_event_get_wiphy: Invalid parameters
    00>
    00> [00:00:10.583,038] <err> wpa_supp: 'INTERFACE_ADD wlan0  zephyr  zephyr  zephyr        ' command timed out.
    00>
    00> [00:00:10.583,496] <err> wpa_supp: Failed to add interface: wlan0
    00> [00:00:10.583,892] <inf> network: Bringing network interface up and connecting to the network
    00> [00:00:10.594,787] <dbg> wpa_supp: wpa_printf_impl: l2_packet_init: iface wlan0 ifindex 1
    00> [00:00:10.595,428] <dbg> wpa_supp: wpa_printf_impl: wlan0: Own MAC address: f0:ce:36:00:00:4a
    00> [00:00:10.596,008] <dbg> wpa_supp: wpa_printf_impl: wlan0: RSN: flushing PMKID list in the driver
    00> [00:00:10.596,557] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: DISCONNECTED -> INACTIVE
    00> [00:00:10.598,114] <dbg> wpa_supp: wpa_printf_impl: MBO: Update non-preferred channels, non_pref_chan=N/A
    00> [00:00:10.598,846] <dbg> wpa_supp: wpa_printf_impl: wlan0: Added interface wlan0
    00> [00:00:10.599,395] <dbg> wpa_supp: wpa_printf_impl: wlan0: State: INACTIVE -> DISCONNECTED
    without set mac address function
    00> [00:00:00.447,814] <inf> wifi_nrf: nrf_wifi_fmac_otp_mac_addr_get: MAC addr not programmed in OTP
    00>
    00> [00:00:00.448,638] <err> wifi_nrf: nrf_wifi_if_start_zep: Invalid MAC address: 00:00:00:00:00:00
    00>
    00> [00:00:00.455,291] <inf> fs_nvs: 6 Sectors of 4096 bytes
    00> [00:00:00.455,596] <inf> fs_nvs: alloc wra: 0, fe8
    00> [00:00:00.455,871] <inf> fs_nvs: data wra: 0, 0
    00> [00:00:00.456,542] <dbg> wpa_supp: wpa_printf_impl: wpa_supplicant v2.11-devel
    00> [00:00:00.457,855] <inf> wpa_supp: Successfully initialized wpa_supplicant
    00> [00:00:00.459,320] <inf> network: Bringing network interface up and connecting to the network
    00> [00:00:00.459,777] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_UNINIT --> MQTT_STATE_DISCONNECTED
    00> [00:00:00.460,479] <dbg> mqtt_helper: mqtt_helper_poll_loop: Waiting for connection_poll_sem
    nrf7002dk
    00> [00:00:00.519,531] <inf> fs_nvs: 6 Sectors of 4096 bytes
    00> [00:00:00.519,836] <inf> fs_nvs: alloc wra: 0, fe8
    00> [00:00:00.520,141] <inf> fs_nvs: data wra: 0, 0
    00> [00:00:00.523,254] <inf> network: Bringing network interface up and connecting to the network
    00> [00:00:00.523,712] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_UNINIT --> MQTT_STATE_DISCONNECTED
    00> [00:00:00.526,306] <dbg> mqtt_helper: mqtt_helper_poll_loop: Waiting for connection_poll_sem
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> OK
    00> [00:00:02.457,885] <inf> wifi_mgmt_ext: Connection requested
    00> [00:00:33.470,855] <err> wpa_supp: Connection timed out, timeout: 30 seconds
    00> OK
    Allen
  • Hi Allen,
    Timeout error usually indicates misconfiguration. Have you checked that your connection parameters are set correctly?
    I see in your previously provided log that you used password which is less than 8 characters long. Is this password actually used? If not, can you set the password to be of length minimum 8 characters and provide new logs?
    Dejan
    That password is not actually be used, I use another password, the length is greater than 8 characters.
    I think the connection parameters are correct, since the application works fine and connected to MQTT broker normally when not adding “set MAC address “ function in nRF7002dk build.
    Allen
