v2.6.1 (and 2.6.0) Kernel Panic in sysworkq
Code runs fine in v2.53 but when running in v2.6, we get a kernel panic at the exit of a delayable workqueue function.
Tracing the code and line number, it dies in Zephyr. No idea where to go from here so any help would be appreciated.
ASSERTION FAIL @ WEST_TOPDIR/zephyr/include/zephyr/drivers/gpio.h:883
[00:00:17.195,861] <err> os: r0/a1: 0x00000004 r1/a2: 0x00000373 r2/a3: 0x00000000
[00:00:17.196,380] <err> os: r3/a4: 0x20010060 r12/ip: 0x000002ee r14/lr: 0x00045d0b
[00:00:17.196,899] <err> os: xpsr: 0x41000000
[00:00:17.197,265] <err> os: Faulting instruction address (r15/pc): 0x000668c2
[00:00:17.197,723] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
[00:00:17.198,211] <err> os: Current thread: 0x2000fb38 (sysworkq)
[00:00:17.203,582] <err> os: Halting system
CONFIG_HW_STACK_PROTECTION=y
CONFIG_DYNAMIC_OBJECTS=y
CONFIG_HEAP_MEM_POOL_SIZE=98304
#131072
CONFIG_NRF_MODEM_LIB_HEAP_SIZE=4096
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
#CONFIG_IDLE_STACK_SIZE=2048
CONFIG_AT_MONITOR_HEAP_SIZE=1024
  • int ret = gpio_pin_interrupt_configure_dt(&status, GPIO_INT_EDGE_BOTH);
  • Thanks for sharing.
    From \zephyr\include\zephyr\drivers\gpio.h
     * @brief Configure pin interrupts from a @p gpio_dt_spec.
     * This is equivalent to:
     *     gpio_pin_interrupt_configure(spec->port, spec->pin, flags);
     * The <tt>spec->dt_flags</tt> value is not used.
     * @param spec GPIO specification from devicetree
     * @param flags interrupt configuration flags
     * @return a value from gpio_pin_interrupt_configure()
    static inline int gpio_pin_interrupt_configure_dt(const struct gpio_dt_spec *spec,
    						  gpio_flags_t flags)
    	return gpio_pin_interrupt_configure(spec->port, spec->pin, flags);
    What is &status pointing to in your case?
    Are you able to share more of your code around the interrupt configuration?
    Thanks.
    -Øyvind
  • static const struct gpio_dt_spec status = GPIO_DT_SPEC_GET_OR(SW3_NODE, gpios, {0});
    gpio_pin_configure_dt(&status, GPIO_INPUT);
    void statusCallback(const struct device *dev, struct gpio_callback *cb, uint32_t pins) {
    //printk("*****\nCallback\n*****\n");
       if (gpio_pin_get_dt(&status)) {
          setStatusLED(true);
          //printk("** Status LED On **\n");
       } else {
          setStatusLED(false);
          //printk("** Status LED Off **\n");
    //printk("* Leaving callback *\n");
       int ret = gpio_pin_interrupt_configure_dt(&status, GPIO_INT_EDGE_BOTH); // edge falling is just an example.. you should set it what you need it to be
       if (ret != 0) {
          printk("Error %d: failed to configure interrupt pin %d\n", ret, status.pin);
       } else {
          gpio_init_callback(&fix_cb, statusCallback, BIT(status.pin));
          gpio_add_callback(status.port, &fix_cb);
  • Our application is using the ST's LIS2DH on SPI bus with the Zephyr drivers, and it works fine on SDK version 2.5.1, but with 2.6.1 it causes the same assert error.
    Still looking in to it, might have more information later.
  • Alright, the issue was not present in the LIS2DH sample, but is in our production application, and for some reason the sensor driver doesn't handle the interrupts correctly, resulting in the assertion failure:
    ASSERTION FAIL [(flags & ((1U << 21) | (1U << 22))) != 0U] @ WEST_TOPDIR/zephyr/include/zephyr/drivers/gpio.h:883
       Must either enable or disable interrupts
    The 2.6.1 LIS2DH devicetree binding has new properties, int1-gpio-config and int2-gpio-config, setting them to <3> (LIS2DH_DT_GPIO_INT_LEVEL_HIGH) fixes the issue. A value of <0> results in the assert failure, I assume it's the default value.
    EDIT: I noticed the LIS2DH sample did not have assert enabled, setting CONFIG_ASSERT=y replicated the assertion fail without the proper int-gpio-config setting. Seems to run just fine without the assert.
