I actually didn't understand so well the second part. My goal is to verify the power saving capabilities of the devices when they are used with the DECT NR+ standard, so I wanted to measure the power consumed during an established communication between 2 devices using DECT NR+.
The suggestion is to break down the problem inot smaller pieces. Know you are getting numbers that you don't know if are correct or not. It could be a HW issue or it could be a SW issue. If you test with a FW with known power consumption then you can see if the HW is working as it should. If that is the case, then you can trust the numbers and if the current is not what you expect, then you know you have a FW issue on your board.
Thanks a lot for the suggestion. What about the voltage ‘V’ that powers the device, considering it is connected via a USB cable to my laptop? Is it 3.3V or 5V?
My area is the PPK2 so you will need to check the nRF9161 DK documentation for that, or measure the voltage.
Can you please provide more information on what you are running on your board?
The nRF9161DK documentation provides more information on the power supply.
Øyvind
