I have an EC11 rotary encoder wired to my nRF52840 and I am trying to get readings from it using the sensor API. However, I'm having issues with (seemingly) garbage data. When I rotate one "click" I get a variety of readings. Sometimes no readings whatsoever, sometimes multiple readings. I referenced the nrf_desktop wheel implementation for my configuration.
I should note that I am relying on software pullups for my configuration, hence the specific gpio definition for the encoder pins.
It is important to me that I do not poll the encoder in order to save power. Am I missing something obvious?
Here's my overlay file:
/ { aliases { sw0 = &button0; sw1 = &button1; sw2 = &button2; qdec0 = &qdec0; qenca = &encoder_a; qencb = &encoder_b; }; encoder_a: encoder_a_pin { gpios = <&gpio1 13 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>; label = "Rotary interrupt A"; }; encoder_b: encoder_b_pin { gpios = <&gpio1 15 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>; label = "Rotary interrupt B"; }; }; &pinctrl { qdec_pinctrl: qdec_pinctrl { group1 { psels = <NRF_PSEL(QDEC_A, 1, 13)>, <NRF_PSEL(QDEC_B, 1, 15)>; }; }; }; &qdec0 { status = "okay"; pinctrl-0 = <&qdec_pinctrl>; pinctrl-names = "default"; steps = <80>; led-pre = <0>; };
My interface code:
const struct device *const encoder_device = DEVICE_DT_GET(DT_NODELABEL(qdec0)); static void sample_encoder() { struct sensor_value val; int rc; rc = sensor_sample_fetch(encoder_device); if (rc != 0) { LOG_INF("Failed to fetch sample (%d)\n", rc); return 0; } rc = sensor_channel_get(encoder_device, SENSOR_CHAN_ROTATION, &val); if (rc != 0) { LOG_INF("Failed to get data (%d)\n", rc); return 0; } if (val.val1 != position) { position = val.val1; LOG_INF("Position = %d degrees\n", position); } } void init_encoder(){ if (!device_is_ready(encoder_device)) { LOG_ERR("Cannot get QDEC device"); return -ENXIO; } static const struct sensor_trigger qdec_trig = { .type = SENSOR_TRIG_DATA_READY, .chan = SENSOR_CHAN_ROTATION, }; err = sensor_trigger_set(encoder_device, (struct sensor_trigger *)&qdec_trig, sample_encoder); }
Here is an example log of one "click" clockwise:
[00:11:40.740,112] <inf> main_logging: Position = 4 degrees [00:11:40.822,021] <inf> main_logging: Position = 13 degrees
And here is the logs from three "clicks" counterclockwise:
[00:12:14.900,543] <inf> main_logging: Position = -9 degrees [00:12:17.931,579] <inf> main_logging: Position = -18 degrees [00:12:19.979,553] <inf> main_logging: Position = -4 degrees [00:12:20.061,492] <inf> main_logging: Position = -13 degrees
