I am facing heap memory issues in my code. I am using dynamic memory allocation for saving microphone data into sd card. Along with this I am using wifi also.
Updated_home_with_wifi.zip
When I don't place the breakpoint in the faults.c, I get
[00:00:37.674,804] <err> os: ***** USAGE FAULT *****
[00:00:37.674,804] <err> os: Illegal load of EXC_RETURN into PC
[00:00:37.674,835] <err> os: r0/a1: 0x0cdb1640 r1/a2: 0x0cd4162e r2/a3: 0x0cca162c
[00:00:37.674,835] <err> os: r3/a4: 0x0cc11630 r12/ip: 0x0cbc162a r14/lr: 0x0cc21630
[00:00:37.674,865] <err> os: xpsr: 0x0ce01600
[00:00:37.674,865] <err> os: Faulting instruction address (r15/pc): 0x0ccd1635
[00:00:37.674,896] <err> os: >>> ZEPHYR FATAL ERROR 34: Unknown error on CPU 0
[00:00:37.674,926] <err> os: Current thread: 0x2000a720 (unknown)
[00:00:38.072,448] <err> os: Halting system
So I already made a addr2line.sh file in which I am executing arm-none-eabi-addr2line -e build/zephyr/zephyr.elf pc address
So I run ./addr2line.sh 0x0ccd1635 but I get ??:0
U got anything?
It is unclear why this fault happens based on the limited logs that is generated. We can improve the information of the fault logs if you add these below in your prj.conf, recompile, flash and run the new binary.
CONFIG_REBOOT=y # CONFIG_RESET_ON_FATAL_ERROR=y CONFIG_FATAL_ERROR_LOG_LEVEL_DBG=y CONFIG_BT_HCI_VS_FATAL_ERROR=y CONFIG_EXTRA_EXCEPTION_INFO=y CONFIG_THREAD_NAME=y CONFIG_THREAD_ANALYZER=y CONFIG_THREAD_STACK_INFO=y CONFIG_THREAD_MONITOR=y CONFIG_THREAD_ANALYZER_ISR_STACK_USAGE=y CONFIG_THREAD_ANALYZER_AUTO_INTERVAL=5 # CONFIG_THREAD_ANALYZER_USE_PRINTK=n CONFIG_THREAD_ANALYZER_AUTO=y CONFIG_THREAD_ANALYZER_USE_LOG=y CONFIG_INIT_STACKS=y CONFIG_STACK_USAGE=y #CONFIG_MPU_STACK_GUARD=y #CONFIG_STACK_SENTINEL=y CONFIG_IDLE_STACK_SIZE=4096 CONFIG_MAIN_STACK_SIZE=8196 CONFIG_ISR_STACK_SIZE=8196 CONFIG_MPSL_WORK_STACK_SIZE=8196 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=8196
With this, we hopefully get more context to see if there is a stack overflow in any thread and which thread executed a instruction that caused a fault.
After enabling the above configurations you mentioned, I got the below logs
[00:00:00.188,476] <inf> fs_nvs: 2 Sectors of 4096 bytes
[00:00:00.188,476] <inf> fs_nvs: alloc wra: 0, fe8
[00:00:00.188,507] <inf> fs_nvs: data wra: 0, 0
*** Booting nRF Connect SDK v2.5.2 ***
[00:00:00.188,903] <inf> home_demo: UART_RX_BUF_REQUEST
[00:00:00.188,934] <inf> home_demo: New buffer set successfully
[00:00:00.188,964] <inf> home_demo: UART initialised
[00:00:00.191,192] <inf> thread_analyzer: Thread analyze:
[00:00:00.191,558] <inf> thread_analyzer: 0x2000a3f8 : STACK: unused 1360 usage 2736 / 4096 (66 %); CPU: 0 %
[00:00:00.191,558] <inf> thread_analyzer: : Total CPU cycles used: 11
[00:00:00.191,711] <inf> thread_analyzer: thread_analyzer : STACK: unused 536 usage 488 / 1024 (47 %); CPU: 0 %
[00:00:00.191,711] <inf> thread_analyzer: : Total CPU cycles used: 16
[00:00:00.203,918] <inf> thread_analyzer: pcm_thread_id : STACK: unused 3912 usage 18--- 45[00:00:02.782,440] <inf> wifi_mgmt_ext: Connection requested
[00:00:03.570,129] <inf> home_demo: UART_RX_RDY
[00:00:03.572,692] <inf> home_demo: The data from prodo is: 00:00:03 {"Hcho-mg/m3": 0.00,"Co-PPM": 0,"Co2-PPM": 1048,"Pm1.0-µg/m3": 8,"Pm10-µg/m3": 9,"Pm25-µg/m3": 8,"Voc-mg/m3": 0,"Temp-°C": 71,"Hum-": 70,"Noi-DB": 47,"UVA-mw/cm2": 0.07,"UVB-mw/cm2": 0.00,"UVC-mw/cm2": 0.00,"RED": 4,"GREEN": 422,"BLUE": 319,"IR": 10}
[00:00:03.578,613] <inf> home_demo: UART_RX_BUF_RELEASED
[00:00:03.578,643] <inf> home_demo: Buffer is released
[00:00:03.578,643] <inf> home_demo: UART_RX_BUF_RELEASED
[00:00:03.578,674] <inf> home_demo: Buffer is released
[00:00:03.578,674] <inf> home_demo: UART_RX_DISABLED
[00:00:03.578,704] <inf> home_demo: UART_RX_BUF_REQUEST
[00:00:03.578,735] <inf> home_demo: New buffer set successfully
[00:00:05.222,625] <inf> thread_analyzer: Thread analyze:
[00:00:05.223,419] <inf> thread_analyzer: 0x2000a2f8 : STACK: unused 5968 usage 176 / 6144 (2 %); CPU: 0 %
[00:00:05.223,449] <inf> thread_analyzer: : Total CPU cycles used: 0
[00:00:05.223,663] <inf> thread_analyzer: 0x2000a3f8 : STACK: unused 1208 usage 2888 / 4096 (70 %); CPU: 0 %
[00:00:05.223,663] <inf> thread_analyzer: : Total CPU cycles used: 72
[00:00:05.223,754] <inf> thread_analyzer: thread_analyzer : STACK: unused 504 usage 520 / 1024 (50 %); CPU: 0 %
[00:00:05.223,785] <inf> thread_analyzer: : Total CPU cycles used: 421
[00:00:05.224,273] <inf> thread_analyzer: pcm_thread_id : STACK: unused 3912 usage 184 / 4096 (4 %); CPU: 0 %
[00:00:05.224,304] <inf> thread_analyzer: : Total CPU cycles used: 65
[00:00:05.225,006] <inf> thread_analyzer: 0x2000a1e8 : STACK: unused 5216 usage 2976 / 8192 (36 %); CPU: 0 %
[00:00:05.225,006] <inf> thread_analyzer: : Total CPU cycles used: 501
[00:00:05.225,830] <inf> thread_analyzer: 0x2000a4f8 : STACK: unused 6224 usage 1968 / 8192 (24 %); CPU: 84 %
[00:00:05.225,860] <inf> thread_analyzer: : Total CPU cycles used: 143660
[00:00:05.226,348] <inf> thread_analyzer: rx_q[0] : STACK: unused 3968 usage 128 / 4096 (3 %); CPU: 0 %
[00:00:05.226,379] <inf> thread_analyzer: : Total CPU cycles used: 1
[00:00:05.226,867] <inf> thread_analyzer: net_mgmt : STACK: unused 3840 usage 256 / 4096 (6 %); CPU: 0 %
[00:00:05.226,867] <inf> thread_analyzer: : Total CPU cycles used: 2
[00:00:05.227,203] <inf> thread_analyzer: tcp_work : STACK: unused 1872 usage 176 / 2048 (8 %); CPU: 0 %
[00:00:05.227,203] <inf> thread_analyzer: : Total CPU cycles used: 0
[00:00:05.228,454] <inf> thread_analyzer: sysworkq : STACK: unused 7944 usage 256 / 8200 (3 %); CPU: 0 %
[00:00:05.228,454] <inf> thread_analyzer: : Total CPU cycles used: 52
[00:00:05.228,698] <inf> thread_analyzer: 0x2000a5d8 : STACK: unused 1448 usage 600 / 2048 (29 %); CPU: 0 %
[00:00:05.228,729] <inf> thread_analyzer: : Total CPU cycles used: 378
[00:00:05.228,912] <inf> thread_analyzer: 0x2000a6d8 : STACK: unused 1072 usage 976 / 2048 (47 %); CPU: 0 %
[00:00:05.228,912] <inf> thread_analyzer: : Total CPU cycles used: 144
[00:00:05.228,973] <inf> thread_analyzer: logging : STACK: unused 216 usage 552 / 768 (71 %); CPU: 0 %
[00:00:05.229,003] <inf> thread_analyzer: : Total CPU cycles used: 491
[00:00:05.229,522] <inf> thread_analyzer: idle : STACK: unused 4048 usage 48 / 4096 (1 %); CPU: 13 %
[00:00:05.229,522] <inf> thread_analyzer: : Total CPU cycles used: 23493
[00:00:05.230,224] <inf> thread_analyzer: main : STACK: unused 5456 usage 2744 / 8200 (33 %); CPU: 0 %
[00:00:05.230,224] <inf> thread_analyzer: : Total CPU cycles used: 1462
[00:00:05.231,140] <inf> thread_analyzer: ISR0 : STACK: unused 6960 usage 1240 / 8200 (15 %)
[00:00:09.384,429] <inf> home_demo: UART_RX_RDY
[00:00:09.387,054] <inf> home_demo: The data from prodo is: 00:00:09 {"Hcho-mg/m3": 0.00,"Co-PPM": 0,"Co2-PPM": 1012,"Pm1.0-µg/m3": 8,"Pm10-µg/m3": 9,"Pm25-µg/m3": 8,"Voc-mg/m3": 0,"Temp-°C": 71,"Hum-": 69,"Noi-DB": 40,"UVA-mw/cm2": 0.07,"UVB-mw/cm2": 0.00,"UVC-mw/cm2": 0.00,"RED": 4,"GREEN": 423,"BLUE": 320,"IR": 10}
[00:00:09.393,066] <inf> home_demo: UART_RX_BUF_RELEASED
[00:00:09.393,096] <inf> home_demo: Buffer is released
[00:00:09.393,096] <inf> home_demo: UART_RX_BUF_RELEASED
[00:00:09.393,127] <inf> home_demo: Buffer is released
[00:00:09.393,127] <inf> home_demo: UART_RX_DISABLED
[00:00:09.393,188] <inf> home_demo: UART_RX_BUF_REQUEST
[00:00:09.393,188] <inf> home_demo: New buffer set successfully
[00:00:10.231,201] <inf> thread_analyzer: Thread analyze:
[00:00:10.231,994] <inf> thread_analyzer: 0x2000a2f8 : STACK: unused 5968 usage 176 / 6144 (2 %); CPU: 0 %
[00:00:10.232,025] <inf> thread_analyzer: : Total CPU cycles used: 0
[00:00:10.232,238] <inf> thread_analyzer: 0x2000a3f8 : STACK: unused 1208 usage 2888 / 4096 (70 %); CPU: 0 %
[00:00:10.232,238] <inf> thread_analyzer: : Total CPU cycles used: 81
[00:00:10.232,330] <inf> thread_analyzer: thread_analyzer : STACK: unused 504 usage 520 / 1024 (50 %); CPU: 0 %
[00:00:10.232,360] <inf> thread_analyzer: : Total CPU cycles used: 700
[00:00:10.232,849] <inf> thread_analyzer: pcm_thread_id : STACK: unused 3832 usage 264 / 4096 (6 %); CPU: 0 %
[00:00:10.232,849] <inf> thread_analyzer: : Total CPU cycles used: 534
[00:00:10.233,551] <inf> thread_analyzer: 0x2000a1e8 : STACK: unused 5216 usage 2976 / 8192 (36 %); CPU: 0 %
[00:00:10.233,581] <inf> thread_analyzer: : Total CPU cycles used: 501
[00:00:10.234,344] <inf> thread_analyzer: 0x2000a4f8 : STACK: unused 5648 usage 2544 / 8192 (31 %); CPU: 42 %
[00:00:10.234,375] <inf> thread_analyzer: : Total CPU cycles used: 143878
[00:00:10.234,954] <inf> thread_analyzer: rx_q[0] : STACK: unused 3968 usage 128 / 4096 (3 %); CPU: 0 %
[00:00:10.234,954] <inf> thread_analyzer: : Total CPU cycles used: 1
[00:00:10.235,443] <inf> thread_analyzer: net_mgmt : STACK: unused 3840 usage 256 / 4096 (6 %); CPU: 0 %
[00:00:10.235,473] <inf> thread_analyzer: : Total CPU cycles used: 2
[00:00:10.235,717] <inf> thread_analyzer: tcp_work : STACK: unused 1872 usage 176 / 2048 (8 %); CPU: 0 %
[00:00:10.235,748] <inf> thread_analyzer: : Total CPU cycles used: 0
[00:00:10.236,968] <inf> thread_analyzer: sysworkq : STACK: unused 7944 usage 256 / 8200 (3 %); CPU: 0 %
[00:00:10.236,968] <inf> thread_analyzer: : Total CPU cycles used: 155
[00:00:10.237,213] <inf> thread_analyzer: 0x2000a5d8 : STACK: unused 1448 usage 600 / 2048 (29 %); CPU: 0 %
[00:00:10.237,243] <inf> thread_analyzer: : Total CPU cycles used: 1062
[00:00:10.237,426] <inf> thread_analyzer: 0x2000a6d8 : STACK: unused 1072 usage 976 / 2048 (47 %); CPU: 0 %
[00:00:10.237,457] <inf> thread_analyzer: : Total CPU cycles used: 997
[00:00:10.237,487] <inf> thread_analyzer: logging : STACK: unused 160 usage 608 / 768 (79 %); CPU: 0 %
[00:00:10.237,518] <inf> thread_analyzer: : Total CPU cycles used: 779
[00:00:10.238,037] <inf> thread_analyzer: idle : STACK: unused 4048 usage 48 / 4096 (1 %); CPU: 55 %
[00:00:10.238,037] <inf> thread_analyzer: : Total CPU cycles used: 184460
[00:00:10.238,739] <inf> thread_analyzer: main : STACK: unused 5456 usage 2744 / 8200 (33 %); CPU: 0 %
[00:00:10.238,739] <inf> thread_analyzer: : Total CPU cycles used: 1462
[00:00:10.239,624] <inf> thread_analyzer: ISR0 : STACK: unused 6960 usage 1240 / 8200 (15 %)
[00:00:15.188,873] <inf> home_demo: UART_RX_RDY
[00:00:15.191,497] <inf> home_demo: The data from prodo is: 00:00:15 {"Hcho-mg/m3": 0.00,"Co-PPM": 0,"Co2-PPM": 975,"Pm1.0-µg/m3": 8,"Pm10-µg/m3": 9,"Pm25-µg/m3": 8,"Voc-mg/m3": 0,"Temp-°C": 71,"Hum-": 69,"Noi-DB": 39,"UVA-mw/cm2": 0.07,"UVB-mw/cm2": 0.00,"UVC-mw/cm2": 0.00,"RED": 4,"GREEN": 423,"BLUE": 320,"IR": 10}
[00:00:15.197,509] <inf> home_demo: UART_RX_BUF_RELEASED
[00:00:15.197,540] <inf> home_demo: Buffer is released
[00:00:15.197,540] <inf> home_demo: UART_RX_BUF_RELEASED
[00:00:15.197,570] <inf> home_demo: Buffer is released
[00:00:15.197,570] <inf> home_demo: UART_RX_DISABLED
[00:00:15.197,601] <inf> home_demo: UART_RX_BUF_REQUEST
[00:00:15.197,631] <inf> home_demo: New buffer set successfully
[00:00:15.239,685] <inf> thread_analyzer: Thread analyze:
[00:00:15.240,478] <inf> thread_analyzer: 0x2000a2f8 : STACK: unused 5968 usage 176 / 6144 (2 %); CPU: 0 %
[00:00:15.240,509] <inf> thread_analyzer: : Total CPU cycles used: 0
[00:00:15.240,722] <inf> thread_analyzer: 0x2000a3f8 : STACK: unused 1208 usage 2888 / 4096 (70 %); CPU: 0 %
[00:00:15.240,722] <inf> thread_analyzer: : Total CPU cycles used: 90
[00:00:15.240,814] <inf> thread_analyzer: thread_analyzer : STACK: unused 504 usage 520 / 1024 (50 %); CPU: 0 %
[00:00:15.240,814] <inf> thread_analyzer: : Total CPU cycles used: 976
[00:00:15.241,333] <inf> thread_analyzer: pcm_thread_id : STACK: unused 3832 usage 264 / 4096 (6 %); CPU: 0 %
[00:00:15.241,333] <inf> thread_analyzer: : Total CPU cycles used: 1018
[00:00:15.242,095] <inf> thread_analyzer: 0x2000a1e8 : STACK: unused 5216 usage 2976 / 8192 (36 %); CPU: 0 %
[00:00:15.242,095] <inf> thread_analyzer: : Total CPU cycles used: 501
[00:00:15.242,858] <inf> thread_analyzer: 0x2000a4f8 : STACK: unused 5648 usage 2544 / 8192 (31 %); CPU: 28 %
[00:00:15.242,858] <inf> thread_analyzer: : Total CPU cycles used: 144209
[00:00:15.243,377] <inf> thread_analyzer: rx_q[0] : STACK: unused 3968 usage 128 / 4096 (3 %); CPU: 0 %
[00:00:15.243,408] <inf> thread_analyzer: : Total CPU cycles used: 1
[00:00:15.243,896] <inf> thread_analyzer: net_mgmt : STACK: unused 3840 usage 256 / 4096 (6 %); CPU: 0 %
[00:00:15.243,896] <inf> thread_analyzer: : Total CPU cycles used: 2
[00:00:15.244,171] <inf> thread_analyzer: tcp_work : STACK: unused 1872 usage 176 / 2048 (8 %); CPU: 0 %
[00:00:15.244,171] <inf> thread_analyzer: : Total CPU cycles used: 0
[00:00:15.245,422] <inf> thread_analyzer: sysworkq : STACK: unused 7944 usage 256 / 8200 (3 %); CPU: 0 %
[00:00:15.245,422] <inf> thread_analyzer: : Total CPU cycles used: 199
[00:00:15.245,666] <inf> thread_analyzer: 0x2000a5d8 : STACK: unused 1448 usage 600 / 2048 (29 %); CPU: 0 %
[00:00:15.245,697] <inf> thread_analyzer: : Total CPU cycles used: 1444
[00:00:15.245,880] <inf> thread_analyzer: 0x2000a6d8 : STACK: unused 1072 usage 976 / 2048 (47 %); CPU: 0 %
[00:00:15.245,880] <inf> thread_analyzer: : Total CPU cycles used: 1330
[00:00:15.245,941] <inf> thread_analyzer: logging : STACK: unused 160 usage 608 / 768 (79 %); CPU: 0 %
[00:00:15.245,941] <inf> thread_analyzer: : Total CPU cycles used: 1138
[00:00:15.246,490] <inf> thread_analyzer: idle : STACK: unused 4048 usage 48 / 4096 (1 %); CPU: 69 %
[00:00:15.246,490] <inf> thread_analyzer: : Total CPU cycles used: 346225
[00:00:15.247,192] <inf> thread_analyzer: main : STACK: unused 5456 usage 2744 / 8200 (33 %); CPU: 0 %
[00:00:15.247,192] <inf> thread_analyzer: : Total CPU cycles used: 1462
[00:00:15.248,077] <inf> thread_analyzer: ISR0 : STACK: unused 6960 usage 1240 / 8200 (15 %)
[00:00:20.248,168] <inf> thread_analyzer: Thread analyze:
[00:00:20.248,992] <inf> thread_analyzer: 0x2000a2f8 : STACK: unused 5968 usage 176 / 6144 (2 %); CPU: 0 %
[00:00:20.248,992] <inf> thread_analyzer: : Total CPU cycles used: 0
[00:00:20.249,206] <inf> thread_analyzer: 0x2000a3f8 : STACK: unused 1208 usage 2888 / 4096 (70 %); CPU: 0 %
[00:00:20.249,206] <inf> thread_analyzer: : Total CPU cycles used: 99
[00:00:20.249,298] <inf> thread_analyzer: thread_analyzer : STACK: unused 504 usage 520 / 1024 (50 %); CPU: 0 %
[00:00:20.249,328] <inf> thread_analyzer: : Total CPU cycles used: 1252
[00:00:20.249,816] <inf> thread_analyzer: pcm_thread_id : STACK: unused 3832 usage 264 / 4096 (6 %); CPU: 0 %
[00:00:20.249,816] <inf> thread_analyzer: : Total CPU cycles used: 1510
[00:00:20.250,518] <inf> thread_analyzer: 0x2000a1e8 : STACK: unused 5216 usage 2976 / 8192 (36 %); CPU: 0 %
[00:00:20.250,549] <inf> thread_analyzer: : Total CPU cycles used: 501
[00:00:20.251,312] <inf> thread_analyzer: 0x2000a4f8 : STACK: unused 5648 usage 2544 / 8192 (31 %); CPU: 21 %
[00:00:20.251,312] <inf> thread_analyzer: : Total CPU cycles used: 144708
[00:00:20.251,831] <inf> thread_analyzer: rx_q[0] : STACK: unused 3968 usage 128 / 4096 (3 %); CPU: 0 %
[00:00:20.251,831] <inf> thread_analyzer: : Total CPU cycles used: 1
[00:00:20.252,349] <inf> thread_analyzer: net_mgmt : STACK: unused 3840 usage 256 / 4096 (6 %); CPU: 0 %
[00:00:20.252,349] <inf> thread_analyzer: : Total CPU cycles used: 2
[00:00:20.252,655] <inf> thread_analyzer: tcp_work : STACK: unused 1872 usage 176 / 2048 (8 %); CPU: 0 %
[00:00:20.252,655] <inf> thread_analyzer: : Total CPU cycles used: 0
[00:00:20.253,906] <inf> thread_analyzer: sysworkq : STACK: unused 7944 usage 256 / 8200 (3 %); CPU: 0 %
[00:00:20.253,906] <inf> thread_analyzer: : Total CPU cycles used: 221
[00:00:20.254,150] <inf> thread_analyzer: 0x2000a5d8 : STACK: unused 1448 usage 600 / 2048 (29 %); CPU: 0 %
[00:00:20.254,180] <inf> thread_analyzer: : Total CPU cycles used: 1777
[00:00:20.254,364] <inf> thread_analyzer: 0x2000a6d8 : STACK: unused 1072 usage 976 / 2048 (47 %); CPU: 0 %
[00:00:20.254,364] <inf> thread_analyzer: : Total CPU cycles used: 1521
[00:00:20.254,425] <inf> thread_analyzer: logging : STACK: unused 160 usage 608 / 768 (79 %); CPU: 0 %
[00:00:20.254,425] <inf> thread_analyzer: : Total CPU cycles used: 1492
[00:00:20.254,974] <inf> thread_analyzer: idle : STACK: unused 4048 usage 48 / 4096 (1 %); CPU: 76 %
[00:00:20.254,974] <inf> thread_analyzer: : Total CPU cycles used: 508022
[00:00:20.255,737] <inf> thread_analyzer: main : STACK: unused 5456 usage 2744 / 8200 (33 %); CPU: 0 %
[00:00:20.255,737] <inf> thread_analyzer: : Total CPU cycles used: 1462
[00:00:20.256,622] <inf> thread_analyzer: ISR0 : STACK: unused 6960 usage 1240 / 8200 (15 %)
[00:00:20.993,286] <inf> home_demo: UART_RX_RDY
[00:00:20.995,910] <inf> home_demo: The data from prodo is: 00:00:20 {"Hcho-mg/m3": 0.00,"Co-PPM": 0,"Co2-PPM": 938,"Pm1.0-µg/m3": 8,"Pm10-µg/m3": 9,"Pm25-µg/m3": 8,"Voc-mg/m3": 0,"Temp-°C": 71,"Hum-": 69,"Noi-DB": 39,"UVA-mw/cm2": 0.07,"UVB-mw/cm2": 0.00,"UVC-mw/cm2": 0.00,"RED": 4,"GREEN": 423,"BLUE": 320,"IR": 10}
[00:00:21.001,892] <inf> home_demo: UART_RX_BUF_RELEASED
[00:00:21.001,892] <inf> home_demo: Buffer is released
[00:00:21.001,922] <inf> home_demo: UART_RX_BUF_RELEASED
[00:00:21.001,953] <inf> home_demo: Buffer is released
[00:00:21.001,953] <inf> home_demo: UART_RX_DISABLED
[00:00:21.001,983] <inf> home_demo: UART_RX_BUF_REQUEST
[00:00:21.002,014] <inf> home_demo: New buffer set successfully
[00:00:25.256,683] <inf> thread_analyzer: Thread analyze:
[00:00:25.257,476] <inf> thread_analyzer: 0x2000a2f8 : STACK: unused 5968 usage 176 / 6144 (2 %); CPU: 0 %
[00:00:25.257,507] <inf> thread_analyzer: : Total CPU cycles used: 0
[00:00:25.257,720] <inf> thread_analyzer: 0x2000a3f8 : STACK: unused 1208 usage 2888 / 4096 (70 %); CPU: 0 %
[00:00:25.257,720] <inf> thread_analyzer: : Total CPU cycles used: 106
[00:00:25.257,812] <inf> thread_analyzer: thread_analyzer : STACK: unused 504 usage 520 / 1024 (50 %); CPU: 0 %
[00:00:25.257,843] <inf> thread_analyzer: : Total CPU cycles used: 1529
[00:00:25.258,331] <inf> thread_analyzer: pcm_thread_id : STACK: unused 3832 usage 264 / 4096 (6 %); CPU: 0 %
[00:00:25.258,331] <inf> thread_analyzer: : Total CPU cycles used: 1990
[00:00:25.259,033] <inf> thread_analyzer: 0x2000a1e8 : STACK: unused 5216 usage 2976 / 8192 (36 %); CPU: 0 %
[00:00:25.259,063] <inf> thread_analyzer: : Total CPU cycles used: 501
[00:00:25.259,796] <inf> thread_analyzer: 0x2000a4f8 : STACK: unused 5648 usage 2544 / 8192 (31 %); CPU: 17 %
[00:00:25.259,826] <inf> thread_analyzer: : Total CPU cycles used: 144880
[00:00:25.260,345] <inf> thread_analyzer: rx_q[0] : STACK: unused 3968 usage 128 / 4096 (3 %); CPU: 0 %
[00:00:25.260,345] <inf> thread_analyzer: : Total CPU cycles used: 1
[00:00:25.260,833] <inf> thread_analyzer: net_mgmt : STACK: unused 3840 usage 256 / 4096 (6 %); CPU: 0 %
[00:00:25.260,864] <inf> thread_analyzer: : Total CPU cycles used: 2
[00:00:25.261,108] <inf> thread_analyzer: tcp_work : STACK: unused 1872 usage 176 / 2048 (8 %); CPU: 0 %
[00:00:25.261,138] <inf> thread_analyzer: : Total CPU cycles used: 0
[00:00:25.262,359] <inf> thread_analyzer: sysworkq : STACK: unused 7944 usage 256 / 8200 (3 %); CPU: 0 %
[00:00:25.262,359] <inf> thread_analyzer: : Total CPU cycles used: 295
[00:00:25.262,664] <inf> thread_analyzer: 0x2000a5d8 : STACK: unused 1448 usage 600 / 2048 (29 %); CPU: 0 %
[00:00:25.262,695] <inf> thread_analyzer: : Total CPU cycles used: 2245
[00:00:25.262,878] <inf> thread_analyzer: 0x2000a6d8 : STACK: unused 1072 usage 976 / 2048 (47 %); CPU: 0 %
[00:00:25.262,908] <inf> thread_analyzer: : Total CPU cycles used: 2129
[00:00:25.262,939] <inf> thread_analyzer: logging : STACK: unused 160 usage 608 / 768 (79 %); CPU: 0 %
[00:00:25.262,969] <inf> thread_analyzer: : Total CPU cycles used: 1845
[00:00:25.263,488] <inf> thread_analyzer: idle : STACK: unused 4048 usage 48 / 4096 (1 %); CPU: 80 %
[00:00:25.263,488] <inf> thread_analyzer: : Total CPU cycles used: 669534
[00:00:25.264,190] <inf> thread_analyzer: main : STACK: unused 5456 usage 2744 / 8200 (33 %); CPU: 0 %
[00:00:25.264,190] <inf> thread_analyzer: : Total CPU cycles used: 1462
[00:00:25.265,075] <inf> thread_analyzer: ISR0 : STACK: unused 6960 usage 1240 / 8200 (15 %)
[00:00:26.238,189] <inf> home_demo: Network connected
[00:00:26.238,586] <inf> home_demo: ################
[00:00:26.391,326] <inf> home_demo: Block count 31116288
Sector size 512
Memory Size(MB) 15193
Disk mounted.
Listing dir /SD: ...
[FILE] RIFF$ (size = 0)
[FILE] (size = 0)
[FILE] MIC.WAV (size = 68724736)
[FILE] TESTFILE.TXT (size = 68444)
[DIR ] SPOTLI~4
[DIR ] FSEVEN~7
[FILE] _TESTF~9.TXT (size = 4096)
[DIR ] TEMPO~12
[FILE] _MI~15.WAV (size = 4096)
[FILE] MICRO.WAV (size = 20598828)
[FILE] _MICR~18.WAV (size = 4096)
[00:00:26.400,848] <inf> home_demo:
[00:00:26.400,848] <inf> home_demo: INFO: Allocated Heap = 122060
[00:00:26.400,848] <inf> home_demo: INFO: Free Heap = 30708
[00:00:26.400,878] <inf> home_demo: INFO: Max Allocated Heap = 127404
[00:00:26.409,698] <inf> home_demo: Mic switch is on at startup
[00:00:26.409,729] <inf> home_demo: PDM start was successful at startup
[00:00:26.416,656] <inf> home_demo: Wrote 262 bytes to file /SD:/testfile.txt
[00:00:26.440,887] <err> home_demo: Memory allocation for circular buffer failed
[00:00:26.472,015] <err> home_demo: Memory allocation for circular buffer failed
[00:00:26.503,143] <err> home_demo: Memory allocation for circular buffer failed
Sorry for late reply Rakshita, this thread fell out of my visible queue.
It does not look like there is an assert in this case but it looks like the error is different about the failure of memory allocation?
Do you still have the same issue or did you already manage to fix this yourself? If you got it working, can you please write here what was the issue?
If you still have the same error, then Please attach your project so that I can quickly test this on my end on a DK.
