Hi.
I have following error:
gen_isr_tables.py: error: multiple registrations at table_index 13 for irq 13 (0xd) Existing handler 0x31a7d, new handler 0x9df1
Here is my prj.conf :
# Peripheral drivers # I2C CONFIG_NRFX_TWIM1=y # Timer CONFIG_NRFX_TIMER2=y # GPIO CONFIG_NRFX_GPIOTE0=y CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=5 # Flash CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_MPU_ALLOW_FLASH_WRITE=y # Others CONFIG_NRFX_PWM0=y CONFIG_NRFX_SPIM2=y CONFIG_NRFX_RNG=y CONFIG_NRFX_UARTE0=y CONFIG_NRFX_NVMC=y # BLE CONFIG_BT=y CONFIG_BT_PERIPHERAL=y CONFIG_BT_DEVICE_NAME_DYNAMIC=y CONFIG_BT_CTLR_CONN_RSSI=y CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y CONFIG_BT_MAX_CONN=1 # Power management CONFIG_POWEROFF=y CONFIG_RESET_ON_FATAL_ERROR=y # Logging CONFIG_USE_SEGGER_RTT=y # Enable printf floating point support beware this take up to 7ko of flash CONFIG_CBPRINTF_FP_SUPPORT=y # Build options CONFIG_BUILD_NO_GAP_FILL=y CONFIG_MAIN_STACK_SIZE=8192 # Needed to share interrupts line and avoid irq conflict? see https://docs.zephyrproject.org/latest/kernel/services/interrupts.html#sharing-interrupt-lines # CONFIG_SHARED_INTERRUPTS=y
IRQ_CONNECT(NRFX_IRQ_NUMBER_GET(NRF_GPIOTE_INST_GET(0)), IRQ_PRIO_LOWEST,
NRFX_GPIOTE_INST_HANDLER_GET(0), 0, 0);
