I am programming BLE with the nRF52840-DK. [Toolchain Manager: v1.3.0, IDE: Visual Studio Code (VSCode), SDK: ncs v2.6.0, window11 pro]
I am using NUS to work with Bluetooth. I am programming new code by looking at the examples peripheral_uart and central_uart. I have a question about the variable bt_conn (in 'conn_internal.h') that exists in the examples peripheral_uart and central_uart.
- Is the
bt_conn(in 'conn_internal.h') variable the information of the currently connected Bluetooth device, or is it the information of the Bluetooth device that holds this code? ( - The code below is the callback function code for
connectedinperipheral_uart. At this time,info.roleis output as peripheral. I am confused whether the functionbt_conn_get_info(conn, &info)puts the information of the Bluetooth device connected toconnintoinfoor if it puts the Bluetooth information ofconnintoinfo."static void connected(struct bt_conn *conn, uint8_t err){ char addr[BT_ADDR_LE_STR_LEN]; bt_addr_le_to_str(bt_conn_get_dst(conn), addr, sizeof(addr)); if (err) { LOG_INF("connected - connected: Connection failed (err %u)", err); return; } LOG_INF("connected - Connected %s", addr); current_conn = bt_conn_ref(conn); struct bt_conn_info info = {0}; err = bt_conn_get_info(conn, &info); LOG_INF("connected - bt_conn_get_info >>> err:%d", err); LOG_INF("connected - Connected as %s", info.role == BT_CONN_ROLE_CENTRAL ? "central" : "peripheral"); LOG_INF("connected - Conn. interval is %u units", info.le.interval); } static struct bt_conn_cb conn_callbacks = { .connected = connected, .disconnected = disconnected, .security_changed = security_changed, .le_param_updated = le_param_updated, .le_data_len_updated = le_data_length_updated, .le_phy_updated = le_phy_updated, };
