Softdevice Extended Advertising: iOS connection
I am running into a recurring issue with attempting to connect to a nRF52840DK advertising using extended advertising from iOS devices.
Connections repeatedly fail to establish (HCI error 0x3E) regardless of how close the devices are.
All testing is being done with a nRF52840DK, NCS v2.7.0 and an in-tree sample:
west build -b nrf52840dk/nrf52840 zephyr/samples/bluetooth/extended_adv/advertiser/ -p
Essentially, no matter how many times I reboot this device and attempt to connect using nRF Connect for Mobile, it is only on very rare occasions that I get a result other than:
*** Booting nRF Connect SDK v2.7.0-5cb85570ca43 ***
*** Using Zephyr OS v3.6.99-100befc70c74 ***
Starting Extended Advertising Demo
Connected (err 0x00)
Connected state!
Initiating disconnect within 5 seconds...
Disconnected (reason 0x3E)
Connection object available from previous conn. Disconnect is complete!
ASSERTION FAIL [0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/conn.c:1630
        Invalid conn type 0
Running the same sample with the Zephyr controller (CONFIG_BT_LL_SW_SPLIT=y) does not exhibit the issue:
west build -b nrf52840dk/nrf52840 zephyr/samples/bluetooth/extended_adv/advertiser/ -p -- -DCONFIG_BT_LL_SW_SPLIT=y
Console:
Connected state!
Disconnected (reason 0x16)
Disconnected state! Restarting advertising
Connected state!
System Information:
iPhone 15,4 (iPhone 15)
iOS 17.5.1
nRF Connect for Mobile 2.7.7
  • Understandable. I will keep track of the progress of this internally and I will let you know when there is a fix or if we need something more from your end.
  • Hi Maria,
    It is almost 18 months later, and the same issue still exist on the `v3.2.0-preview2` tag, with the same reproduction steps.
    The following logs just repeat several times a second.
    Connected state!
    Disconnected, reason 0x3E
    Remote disconnected early...
    Connected state!
    Connected state!
    To me this is basic functionality that doesn't work, is there any plan to fix this?
  • As far as I know, this is yet to be fixed in the SDK, as it was more than just a patch job. It is not planned for NCS 3.2.0 either. However, I was told today when asking that this has been fixed on the iOS side in iOS 26.
    Simon
