I'm struggling to use ble_app_att_mtu_throughput and spi. Some help?
When I merge the two codes the main code (ble_app_att_mtu_throughput) doesn't work.
Thanks for your help
Yes, I see the classic log output of ble_app_att_mtu_throughput
I mean:
NRF_LOG_INFO("ATT MTU example started.");
NRF_LOG_INFO("Press button 3 on the board connected to the PC.");
NRF_LOG_INFO("Press button 4 on other board.");
And next the other parts of the code
The project you shared doesn't contain any source file?
Ste_ said:Yes, I see the classic log output of ble_app_att_mtu_throughput
So you only see the log output if you only connect the client side?
Because earlier you wrote this:
Ste_ said:When I run just ble_app_att_mtu_throughput and I open the PuTTY terminals, I see "this board act as responder" and "this board act as tester.
This doesn't happen when I add spi code. I open the two terminals and nothing happen, neither if I push the reset button on the nRF52832 boards
So please clarify, when you see log output, what log output you see, and from what device,
regards
Jared
This is what I see on responder and on tester terminal if I try to integrate my code with SPI code.
And this is what I see if I run just the code ble_app_att_mtu_throughput:
Then, If I comment the SPI part of the code, it runs perfectly. But I need the SPI part.
Not if I integrate the SPI code
Sorry, is it right now?
Thank you for the clear explanation.
The zip file does still not contain any main.c or any other source file as far as I can see. You're using Segger Embedded Studio as IDE right?
regards
Jared
Yes, I'm using SEGGER
