Trouble creating a create a certificate signing request on nrf5340 for BLE Mesh Certificate based provisioning.
So basically, I am have created a key pair using the Identity key generation example and exported the public key using Identity key usage example. Now i need to create a certificate signing request, so I am trying to follow the PSA Crypto example to do the same. But it is not building as I facing the following error:
<command-line>: fatal error: user-tls-conf.h: No such file or directory
please help me with the same
  • Happy to hear that!
    Btw, I just added a new commit to the project, so you might want to check that one out.
  • Thank you very much for adding TF-M support!
    Is there a reason why patch was required and not included in the NCS release?
    The sample itself does not support TF-M. But the patch from before was breaking TF-M globally so I fixed that.
    We are currently working on converting our crypto libraries, and not everything has been moved yet. This will be added to NCS at some point, but in the meantime I created a patch as a workaround. The patch is not "clean", so the final solution at some later point will probably be different.
  • Hi, I have tried using the newer patch but it isnt working for me. This is the error that I get
    [2/228] Generating include/generated/version.h
    -- Zephyr version: 3.5.99 (C:/ncs/v2.6.1/zephyr), build: v3.5.99-ncs1-1
    [8/228] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.6.1/modules/crypto/mbedtls/library/base64.c.obj
    FAILED: modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.6.1/modules/crypto/mbedtls/library/base64.c.obj
    C:\ncs\toolchains\cf2149caf2\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_PSA_CRYPTO_CONFIG_FILE=\"nrf-psa-crypto-want-config.h\" -DMBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE=\"nrf-psa-crypto-config.h\" -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DPICOLIBC_LONG_LONG_PRINTF_SCANF -D_FORTIFY_SOURCE=1 -D_POSIX_C_SOURCE=200809 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.6.1/zephyr/include -IC:/Users/Dell/Nordic_Projects/csr_ecdsa/build_1/zephyr/include/generated -IC:/ncs/v2.6.1/zephyr/soc/arm/nordic_nrf/nrf53 -IC:/ncs/v2.6.1/zephyr/lib/libc/common/include -IC:/ncs/v2.6.1/zephyr/soc/common/nordic_nrf/. -IC:/ncs/v2.6.1/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.6.1/nrf/include -IC:/ncs/v2.6.1/nrfxlib/crypto/nrf_cc312_mbedcrypto/include -IC:/ncs/v2.6.1/nrfxlib/crypto/nrf_cc312_mbedcrypto/include/mbedtls -IC:/ncs/v2.6.1/nrf/tests/include -IC:/ncs/v2.6.1/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.6.1/zephyr/modules/cmsis/. -IC:/ncs/v2.6.1/modules/hal/nordic/nrfx -IC:/ncs/v2.6.1/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.6.1/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.6.1/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v2.6.1/nrfxlib/crypto/nrf_cc312_platform/include -IC:/Users/Dell/Nordic_Projects/csr_ecdsa/build_1/modules/nrf/subsys/nrf_security/src/include/generated -IC:/ncs/v2.6.1/nrf/subsys/nrf_security/include -IC:/ncs/v2.6.1/nrf/ext/oberon/psa/core/include -IC:/ncs/v2.6.1/nrf/ext/oberon/psa/core/library -IC:/ncs/v2.6.1/modules/crypto/mbedtls/include -IC:/ncs/v2.6.1/modules/crypto/mbedtls/library -IC:/ncs/v2.6.1/nrf/subsys/nrf_security/src/drivers/nrf_cc3xx/include -fno-strict-aliasing -Os -imacros C:/Users/Dell/Nordic_Projects/csr_ecdsa/build_1/zephyr/include/generated/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -mtp=soft --sysroot=C:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.6.1/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/Users/Dell/Nordic_Projects/csr_ecdsa=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.6.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.6.1=WEST_TOPDIR -ffunction-sections -fdata-sections --specs=picolibc.specs -std=c99 -MD -MT modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.6.1/modules/crypto/mbedtls/library/base64.c.obj -MF modules\nrf\subsys\nrf_security\src\CMakeFiles\mbedcrypto_base.dir\C_\ncs\v2.6.1\modules\crypto\mbedtls\library\base64.c.obj.d -o modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.6.1/modules/crypto/mbedtls/library/base64.c.obj -c C:/ncs/v2.6.1/modules/crypto/mbedtls/library/base64.c
    C:/ncs/v2.6.1/modules/crypto/mbedtls/library/base64.c: In function 'mbedtls_base64_encode':
    C:/ncs/v2.6.1/modules/crypto/mbedtls/library/base64.c:77:16: error: 'MBEDTLS_ERR_BASE64_BUFFER_TOO_SMALL' undeclared (first use in this function); did you mean 'MBEDTLS_ERR_MPI_BUFFER_TOO_SMALL'?
       77 |         return MBEDTLS_ERR_BASE64_BUFFER_TOO_SMALL;
    C:/ncs/v2.6.1/modules/crypto/mbedtls/library/base64.c:77:16: note: each undeclared identifier is reported only once for each function it appears in
    C:/ncs/v2.6.1/modules/crypto/mbedtls/library/base64.c: In function 'mbedtls_base64_decode':
    C:/ncs/v2.6.1/modules/crypto/mbedtls/library/base64.c:164:20: error: 'MBEDTLS_ERR_BASE64_INVALID_CHARACTER' undeclared (first use in this function); did you mean 'MBEDTLS_ERR_MPI_INVALID_CHARACTER'?
      164 |             return MBEDTLS_ERR_BASE64_INVALID_CHARACTER;
    C:/ncs/v2.6.1/modules/crypto/mbedtls/library/base64.c:200:16: error: 'MBEDTLS_ERR_BASE64_BUFFER_TOO_SMALL' undeclared (first use in this function); did you mean 'MBEDTLS_ERR_MPI_BUFFER_TOO_SMALL'?
      200 |         return MBEDTLS_ERR_BASE64_BUFFER_TOO_SMALL;
    [21/228] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.6.1/modules/crypto/mbedtls/library/bignum.c.obj
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\cf2149caf2\opt\bin\cmake.EXE' --build 'c:\Users\Dell\Nordic_Projects\csr_ecdsa\build_1'
     *  The terminal process terminated with exit code: 1.
  • Also it is breaking my other codes with the error:
    #error "MBEDTLS_PEM_WRITE_C defined, but not all prerequisites"
