VS Code errors/problem
Hi.
I am using SDK v2.6.0 (Toolchain v.2.6.0).
When I open VS Code (v1.91.1) I keep getting this warning -->Bad CMake executable: “”. Check to make sure it is installed or the value of the “cmake.cmakePath” setting contains the correct path.
Also, warnings regarding header files appear in the program code.
I don't understand why these warnings occur, because in the .defconfig file I enabled GPIO -->
And in the prj.conf file I enabled PWM -->
Such errors did not occur before.
Please help me solve this problem.
Thanks.
    The issue reported about not finding CMake has been resolved. However, I am confused about whether you are trying to build the application using CMake (and not using west). Are you looking for a terminal that has the complete toolchain? If so, you can open a terminal for that SDK and toolchain.
    Please note that the issue you reported is not specific to the Nordic extension.
    Kind Regards,
    Abhijith
