Toolchain very slow on Windows machines
Dear Nordic Team,
we are using the adafruit_feather_nrf52840 and nrf52840dk for our prototypes and recently the toolchain around nrf and zephyr has become a problem.
Build times (especially compilation of the device tree according to logs) became very long such that one reload of our cmake project takes up to 15 minutes.
It had worked in reasonable time previously, at some point the toolchain slowed down on 2 individual machines.
This has happened on 2 different machines with 3 different versions of zephyr and the nrf toolchain (v2.6.0, v2.6.1, v2.7.0).
I tested using standalone zephyr for the build which doesn't seem to work trivially, however it does build an image in less than 10 seconds.
Also on a Linux machine I have available, the build times are much shorter.
Is anybody aware of any windows specific problems or problems with dtc.exe that may cause this?
Is there some cache we directory or temporal files we may have missed to clean?
We have been investigating for some time now as it really slows down our development iterations severely.
  • Hi Carles,
    thank you for your reply.
    I just had the chance to try the toolchain by manually installing the version of dtc as you suggested.
    Copying all the binaries from chocolatey into their respective location in the ncs toolchain works.
    However it seems that doesn't fix our problem.
    The build is still taking a very long time and I have to swap networks to shorten that. It does seem to be a bit faster than our initial version (~8 minutes instead of 15m)
    Best
    Peter
  • Hi Peter
    So, it seems we're out of ways to potentially fix this, and rather have to move towards avoiding the issue instead. Could you try skipping the dtc.exe check altogether and see if that at least unblocks you from these incredibly long build times:
    State that DTC is not there by doing -DDTC=False when invoking CMake (or west).
    This will do two things:
    1. Tell the system that DTC isn't available and just not perform the checks
    2. Avoid FindDtc.cmake to lookup Dtc.
    Please note that this will only work for builds running without sysbuild (introduced in NCS 2.7.0) so you would need to run something like the following on newer SDK versions:
    ❯ west build --no-sysbuild ../zephyr/samples/hello_world -- -DDTC=False
    I hope this will get you around the issue at least.
    Simon
  • Hi Simon,
    I can verify that this indeed circumvents the issue.
    My buildchain though required to also set that flag for the mcuboot subimage I also had to set: -Dmcuboot_DTC=False
    We don't use sysbuild atm so I cannot verify the latter.
    Peter Haas
