Bootloader hardfault
Im trying to use BLE DFU Bootloader from examples. I loaded SD8 and then bootloader via nrfStudio (dont have a valid app flashed), but I cant see the device from Android app. I decided to do some debugging via Keil. I recompiled Bootloader with no optimisation and moved bootloader address to 0x3A000.
If I try to debug in Keil it doesnt stop at main, but if i manually press stop it gets into hardfault: image description
Memory settings: image description
Compilation settings: image description
Im using Revision 3 chip. What do I do wrong?
app.zip
hex
Bootloader
Bootloader hex O3
bootloader package without BANK_VALID_APP
Bootloader HEX without BANK_VALID_APP
Memory map according to NRF Studio: Memory map
Bootloader optimisation Level 2 gets stuck on run: image description
Image size > 0x6400
  • Your application is 70kB and not 47kB. This means that you need at least 140kB of application flash space( two banks of 70kB each) when using a Dual Bank Bootloader. If you use the default ROM settings for the bootloader, i.e. the bootloader starts at 0x3C000 then you'll have
    0x3C000 - 0x18000 = 0x24000( 144kB left)
    However, extending the bootloader section in order to debug the bootloader you are left with
    0x3A000 - 0x18000 = 0x22000( 136kB left)
    which is not enough and you will get the Data Size Exceeds Limiterror
  • Hi Bjorn, how do you see its 70Kb? And why package generator says its 47Kb?
  • When you compile a project in Keil, the following line will be displayed in the Build Output:
    Program Size: Code=4740 RO-data=1112 RW-data=16 ZI-data=17568
    Which tells you the size of your application program in bytes.
       Total RO Size (Code + RO Data) - Code size in bytes
       Total RW Size (RW Data + ZI Data) - RAM size in bytes
       Total ROM Size (Code + RO Data + RW Data) - Image size in bytes
  • Bjorn, you are totally correct, thanks! I switched to a single bank DFU, but now I have the same problem when trying to update bootloader. Not exactly sure how the procedure for bootloader works since it cant really overwrite itself while running... Would it erase application and work like a dual bank update?
  • The size of the new bootloader must NOT excede the size of the bootloader that is currently present on the chip. This is because the bootloader start adress is written to the UICR register which cannot be updated with out re-flashing the chip with a programmer. As for the memory layout during a bootloader update, please refer this page on our Infocenter
