Bootloader hardfault
Im trying to use BLE DFU Bootloader from examples. I loaded SD8 and then bootloader via nrfStudio (dont have a valid app flashed), but I cant see the device from Android app. I decided to do some debugging via Keil. I recompiled Bootloader with no optimisation and moved bootloader address to 0x3A000.
If I try to debug in Keil it doesnt stop at main, but if i manually press stop it gets into hardfault: image description
Memory settings: image description
Compilation settings: image description
Im using Revision 3 chip. What do I do wrong?
app.zip
hex
Bootloader
Bootloader hex O3
bootloader package without BANK_VALID_APP
Bootloader HEX without BANK_VALID_APP
Memory map according to NRF Studio: Memory map
Bootloader optimisation Level 2 gets stuck on run: image description
Image size > 0x6400
  • When you flash it using a programmer, you will update the bootloader start address that is written to a UICR register. This is not done when performing a OTA DFU, then you only replace the bootloader, but the bootloader start adress will remain the same as the old bootloader.
  • ive added a screenshot of NRF Studio where it shows that start address of bootloader is 0x3A000, so if the image size would be 0x6000 it wouldnt fit and we would get a programming error, correct? Then the question is why you think image size is 0x6000, but NRF Studio programs it as 0x5C00 without errors and BL also works.
    Nevertheless I did what you suggested - Increased BL memory by another 1K, but the result is still the same - getting Exceeded Data Size error. Do you have some other suggestions?
  • NRF_ERROR_DATA_SIZE is returned at line 334, 339, and 415 in dfu_single_bank.c . Start a Debug Session in the bootloader project, set a breakpoint at each of these locations and perform a firmware update.
    When I performed a DFU, I got caught at the breakpoint at line 334:
     if (m_start_packet.bl_image_size > DFU_BL_IMAGE_MAX_SIZE)
            return NRF_ERROR_DATA_SIZE;
  • I cant even compile it with Level 0 optimisation, I get this error: ._build\nrf51422_xxac.axf: Error: L6985E: Unable to automatically place AT section bootloader_settings.o(.ARM.__AT_0x0003FC00) with required base address 0x0003fc00. Please manually place in the scatter file using the --no_autoat option.
    If I use 24Kb or 25Kb, same error.
  • You're not able to set breakpoints at the locations when using Level 3 or 2?
