QSPI NOR power manager errrors when CONFIG_PM_DEVICE_RUNTIME is set
I recently enabled power management in my code base by adding these two oiptions to my prj.conf:
CONFIG_PM_DEVICE=y
CONFIG_PM_DEVICE_RUNTIME=y
The code runs on an nRF5340 MCU with a LittleFS instance in an external MX25R64 QSPI flash. It all worked fine until I enabled the two options above in prj.conf, now I get this error each time the MCU starts:
<err> qspi_nor: pm_device_runtime_put failed: -16
It appears that things continue to work normally though, but I've yet to run extensive read/write tests on the external flash and the above error is a bit concerning. I also have
CONFIG_NORDIC_QSPI_NOR_XIP=y in my prj.conf, which (among other things) is supposed to keep the external flash from sleeping if I understood correctly (I need this for various reasons).
Does anybody know how concerned I should be about this error? Thank you.
EDIT: sorry, forgot to specify: I am using Nordic Connect SDK 2.7.0.
