periodic advertising and sleep mode
link text from this link i want to advertise for 10 second then i want to stop advertise for 20 second then again advertise for 10 second. i want this continuously. for that i have defined timer
static void timers1_init(void)
    uint32_t err_code;
    // Initialize timer module.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    // Create timers.
    err_code = app_timer_create(&abc,
                               APP_TIMER_MODE_SINGLE_SHOT,
                                timeout_handler);
//APP_TIMER_MODE_SINGLE_SHOT-The timer will expire only once.
//APP_TIMER_MODE_REPEATED-The timer will restart each time it expires.
static void application_timers_start(void)
    uint32_t err_code;
    // Start application timers.
    err_code = app_timer_start(abc, INTERVAL, NULL);
static void timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
	sd_ble_gap_adv_stop ();
	//power_manage();
  • one more question is if i write timeout handler as below
    static void timeout_handler(void * p_context) { UNUSED_PARAMETER(p_context);
    power_manage();
  • here i know that power_manage() function is used for entering low power mode. then this time out handler will stop advertising??
  • /* Copyright (c) 2015 Nordic Semiconductor. All Rights Reserved. * * The information contained herein is property of Nordic Semiconductor ASA. * Terms and conditions of usage are described in detail in NORDIC * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT. * * Licensees are granted free, non-transferable use of the information. NO * WARRANTY of ANY KIND is provided. This heading must NOT be removed from * the file. * */
    /** @example examples/ble_peripheral/ble_app_blinky/main.c
     * @brief Blinky Sample Application main file.
     * This file contains the source code for a sample application using the LED Button service.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "softdevice_handler.h"
    #include "app_timer.h"
    #include "app_button.h"
    #include "ble_lbs.h"
    #include "bsp.h"
    #include "ble_gap.h"
    #define ADVERTISING_LED_PIN             BSP_LED_0_MASK                              /**< Is on when device is advertising. */
    #define CONNECTED_LED_PIN               BSP_LED_1_MASK                              /**< Is on when device has connected. */
    #define LEDBUTTON_LED_PIN               BSP_LED_0_MASK                              /**< LED to be toggled with the help of the LED Button Service. */
    #define LEDBUTTON_BUTTON_PIN            BSP_BUTTON_0                                /**< Button that will trigger the notification event with the LED Button Service */
    #define DEVICE_NAME                     "Nordic_Blinky"                             /**< Name of device. Will be included in the advertising data. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
    #define APP_ADV_TIMEOUT_IN_SECONDS      BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED       /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
    #define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
    #define APP_TIMER_MAX_TIMERS            6                                           /**< Maximum number of simultaneously created timers. */
    #define APP_TIMER_OP_QUEUE_SIZE         4                                           /**< Size of timer operation queues. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)            /**< Minimum acceptable connection interval (0.5 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)            /**< Maximum acceptable connection interval (1 second). */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory time-out (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000, APP_TIMER_PRESCALER) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define APP_GPIOTE_MAX_USERS            1                                           /**< Maximum number of users of the GPIOTE handler. */
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50, APP_TIMER_PRESCALER)    /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define INTERVAL     APP_TIMER_TICKS(4000, APP_TIMER_PRESCALER)
    #define INTERVAL1     APP_TIMER_TICKS(8000, APP_TIMER_PRESCALER)
    static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
    static ble_lbs_t                        m_lbs;                                      /**< LED Button Service instance. */
    APP_TIMER_DEF(abc);
    APP_TIMER_DEF(abc1);
    /**@brief Function for assert macro callback.
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    static void power_manage(void)
        uint32_t err_code = sd_app_evt_wait();
    static void application_timers1_start(void)
        uint32_t err_code;
        err_code = app_timer_start(abc1, INTERVAL1, NULL);
        uint32_t      err_code;
        ble_advdata_t advdata;
        ble_advdata_t scanrsp;
        ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
        // Build and set advertising data
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = true;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        memset(&scanrsp, 0, sizeof(scanrsp));
        scanrsp.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
        scanrsp.uuids_complete.p_uuids  = adv_uuids;
        err_code = ble_advdata_set(&advdata, &scanrsp);
    		application_timers1_start();
        uint32_t err_code;
        // Create timers.
                                    timeout_handler);
        uint32_t err_code;
        uint32_t             err_code;
        ble_gap_adv_params_t adv_params;
        // Start advertising
        memset(&adv_params, 0, sizeof(adv_params));
        adv_params.type        = BLE_GAP_ADV_TYPE_ADV_IND;
        adv_params.p_peer_addr = NULL;
        adv_params.fp          = BLE_GAP_ADV_FP_ANY;
        adv_params.interval    = APP_ADV_INTERVAL;
        adv_params.timeout     = APP_ADV_TIMEOUT_IN_SECONDS;
        err_code = sd_ble_gap_adv_start(&adv_params);
        LEDS_ON(ADVERTISING_LED_PIN);
    static void timeout_handler1(void * p_context)
    	uint32_t err_code;
    	application_timers_start();
    	advertising_start();
    static void timers2_init(void)
        uint32_t err_code;
        // Create timers.
        err_code = app_timer_create(&abc1,
                                    timeout_handler1);
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
        LEDS_CONFIGURE(ADVERTISING_LED_PIN | CONNECTED_LED_PIN);
        LEDS_OFF(ADVERTISING_LED_PIN | CONNECTED_LED_PIN);
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module.
    static void timers_init(void)
        // Initialize timer module, making it use the scheduler
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
        uint32_t                err_code;
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
    /**@brief Function for handling write events to the LED characteristic.
     * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
     * @param[in] led_state Written/desired state of the LED.
    static void led_write_handler(ble_lbs_t * p_lbs, uint8_t led_state)
        if (led_state)
            LEDS_ON(LEDBUTTON_LED_PIN);
            LEDS_OFF(LEDBUTTON_LED_PIN);
        uint32_t       err_code;
        ble_lbs_init_t init;
        init.led_write_handler = led_write_handler;
        err_code = ble_lbs_init(&m_lbs, &init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module that
     *          are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply
     *       setting the disconnect_on_fail config parameter, but instead we use the event
     *       handler mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling a Connection Parameters error.
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the Application's BLE stack events.
     * @param[in] p_ble_evt  Bluetooth stack event.
    static void on_ble_evt(ble_evt_t * p_ble_evt)
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                LEDS_ON(CONNECTED_LED_PIN);
                LEDS_OFF(ADVERTISING_LED_PIN);
                err_code = app_button_enable();
                LEDS_OFF(CONNECTED_LED_PIN);
                err_code = app_button_disable();
                // Pairing not supported
                err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                       BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                       NULL,
                                                       NULL);
                // No implementation needed.
    /**@brief Function for dispatching a BLE stack event to all modules with a BLE stack event handler.
     * @details This function is called from the scheduler in the main loop after a BLE stack
     *          event has been received.
    static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
        on_ble_evt(p_ble_evt);
        ble_conn_params_on_ble_evt(p_ble_evt);
        ble_lbs_on_ble_evt(&m_lbs, p_ble_evt);
        uint32_t err_code;
        // Initialize the SoftDevice handler module.
        SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, false);
        // Enable BLE stack
        ble_enable_params_t ble_enable_params;
        memset(&ble_enable_params, 0, sizeof(ble_enable_params));
        err_code = sd_ble_enable(&ble_enable_params);
        ble_gap_addr_t addr;
        err_code = sd_ble_gap_address_get(&addr);
        err_code = sd_ble_gap_address_set(BLE_GAP_ADDR_CYCLE_MODE_NONE, &addr);
        // Subscribe for BLE events.
        err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
     * @param[in] button_action The button action (press/release).
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        uint32_t err_code;
        switch (pin_no)
            case LEDBUTTON_BUTTON_PIN:
                err_code = ble_lbs_on_button_change(&m_lbs, button_action);
                if (err_code != NRF_SUCCESS &&
                    err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                    err_code != NRF_ERROR_INVALID_STATE)
                APP_ERROR_HANDLER(pin_no);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
        uint32_t err_code;
        //The array must be static because a pointer to it will be saved in the button handler module.
        static app_button_cfg_t buttons[] =
            {LEDBUTTON_BUTTON_PIN, false, BUTTON_PULL, button_event_handler}
        err_code = app_button_init(buttons, sizeof(buttons) / sizeof(buttons[0]),
                                   BUTTON_DETECTION_DELAY);
    /**@brief Function for the Power Manager.
    /**@brief Function for application main entry.
        // Initialize.
        leds_init();
        timers_init();
        buttons_init();
        ble_stack_init();
        gap_params_init();
        services_init();
        advertising_init();
    	timers1_init();
    timers2_init();
        conn_params_init();
        // Start execution.
    	//application_timers1_start();
        // Enter main loop.
        for (;;)
           // power_manage();
  • its my finle code.here device periodically advertises but on time and off time are not equal.
