central device will not raise security level with new periphral if no power reset on central side
The central device has the below settings
static void auth_passkey_entry(struct bt_conn *conn)
	// Check for passkey entry event
	unsigned int passkey = STATIC_PASSKEY;
	LOG_DBG("Passkey entered %s: %06u", addr, passkey);
	// Set passkey using bt_conn_auth_passkey_entry()
	bt_conn_auth_passkey_entry(conn, passkey);
static void auth_cancel(struct bt_conn *conn)
	LOG_INF("Pairing cancelled: %s", addr);
static void pairing_complete(struct bt_conn *conn, bool bonded)
	LOG_INF("Pairing completed: %s, bonded: %d", addr, bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	LOG_ERR("Pairing failed conn: %s, reason %d", addr, reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_entry = auth_passkey_entry,
	.cancel        = auth_cancel,
static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
	.pairing_complete = pairing_complete,
	.pairing_failed   = pairing_failed
One central device A and two peripheral devices B and C,  B and C have the exact same firmware. A can establish the connection with B or C.
but I have to power reset A in order to change the connection between A-B and A-C otherwise auth_passkey_entry on A will not be triggered and security level will always be the lowest.
I tried to do power reset B and C but the situation still remain the same.
Is there any flag or bonding info I need to clear on the central side before establish a new connection ?
