nrf_sdh_enable_request() Error:4097 when switch from USBD or Gazell to BLE.
Good day, I am working on function to switch between USBD HID, Gazell and BLE HID with nrf52840 and SDK 17.1.0.
From the very beginning of program, USBD and BLE services are all initiated without any problem, and also no problem when switching between USBD HID and BLE HID.
as per below part coding, switch from USBD to Gazell, at the same time, ble services and ble stack stopped smoothly. but switch back to ble, RTT output unknow error, error no.4097 from nrf_sdh_enable_request(), pls see below part codes.
void set_output(uint8_t output) {
    static uint8_t last_output = OUTPUT_NONE;
    switch(output) {
        case OUTPUT_USB:
            switch (last_output) {
                case OUTPUT_BLE_HID:
                    if (nrf_sdh_is_enabled()) ble_disconnect();
                case OUTPUT_GZLL:
                    nrf_drv_clock_lfclk_release();
                    gzll_kbd_device_stop();
            if (nrf_drv_usbd_is_enabled()) app_usbd_start();
                case OUTPUT_GZLL:
            if (!nrf_sdh_is_enabled()) {
                ble_stack_init();
                ble_hid_service_start();
            advertising_restart(false);
        case OUTPUT_GZLL:
                    if (nrf_sdh_is_enabled()) {
                        ble_hid_service_stop();
                        ble_stack_stop();
            gzll_kbd_device_start();
    last_output = output;
void ble_stack_stop(void)
    uint32_t err_code;
    err_code = nrf_sdh_disable_request();
    ASSERT(!nrf_sdh_is_enabled());
void ble_stack_init(void) {
    ret_code_t err_code;
    ASSERT(nrf_sdh_is_enabled());
    uint32_t ram_start = 0;
    err_code           = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start);
    // Enable BLE stack.
void ble_hid_service_stop(void) {
    err_code = ble_conn_params_stop();
    err_code = app_timer_stop(m_battery_timer_id);
void ble_hid_service_start(void) {
    // Initialize.
    timers_create();
    // ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    NRF_LOG_INFO("HID Keyboard example started.");
    timers_start();
    // advertising_restart(false);
  • Kenneth, thanks a lot, your remind me of above.
    But I am using makefile and armgcc. so I include below file:
    NRF_LDFLAGS += $(SDK_ROOT)/components/proprietary_rf/gzll/gcc/gzll_nrf52840_sd_resources_gcc.a \
    bss above user guide, there are two libraries: gzll_arm.lib and gzll_sd_resources_arm.lib.
    Can I say gzll_nrf52840_gcc.a corresponding to gzll_arm.lib and gzll_nrf52840_sd_resources_gcc.a coresponding to gzll_sd_resources_arm.lib?
    At the same time, I noticed that example of ble_app_gzll's makefile, including gzll_nrf52840_gcc.a, and below
    void gzll_app_stop()
        // Disable gazell.
        nrf_gzll_disable();
        // Wait for Gazell to shut down.
        while (nrf_gzll_is_enabled())
        // Clean up after Gazell.
        NVIC_DisableIRQ(RADIO_IRQn);
        NVIC_DisableIRQ(TIMER2_IRQn);
        NVIC_DisableIRQ(SWI0_IRQn);
        NVIC_ClearPendingIRQ(RADIO_IRQn);
        NVIC_ClearPendingIRQ(TIMER2_IRQn);
        NVIC_ClearPendingIRQ(SWI0_IRQn);
    In my makefile, I include gzll_nrf52840_sd_resources_gcc.a, bss above correspondingly, I should ammend above code as below?
        // Disable gazell.
        nrf_gzll_disable();
        NVIC_DisableIRQ(TIMER0_IRQn);  //ammended
        NVIC_ClearPendingIRQ(TIMER0_IRQn);//ammended
    another questions: bss make file and armgcc, am I doing right of including  gzll_nrf52840_sd_resources_gcc.a?
  • I recommend to use the same library as the combined BLE and Gazell example use: gzll_arm.lib (in your case then I expect gzll_nrf52840_gcc.a).
    Kenneth
  • Kenneth
    yes, you are right,  including gzll_nrf52840_gcc is without error,  while including gzll_nrf52840_sd_resources_gcc.a is still error 4097.
    Now all going well, thanks for your patient explaination, much appreciated.
