Nrf52 flash programming : 'writes in a block between erase'
In the nrf52 OPS datasheet, for NVM and flash programming electrical specification (page 41) it has "Amount of writes in a block between erase" and Minimum for that is 181.
What does that actually mean?
For example, I know and understand "Write/erase cycles", but this is a new one on me.
A sector in nrf52 has 4K which means 1024 dwords. Which means I could end up having 1024 write operations before it is full. So the 181 specified can't be referring to how many times I could write.
To make matters worse, there are 32 bits in a write operation, so there are 32768 bits. So I could theretically have 32 seperate write operations at each of the 1024 locations, giving me a total of 32768 write operation before I would have to erase the block.
I am confused !!
Hope someone can clarify.
  • I asked and the definitive answer about how many times one can write to a dword is as per the following response I got ...
    The real limitation is that you can write up to 8 times to the same address, as long as you don't touch other 32-bit words inside the same 128-bit block. For simplicity we have stated in the product specification that the maximum is 2 writes for a 32-bit word. The limitation should be considered hard as breaking it may result in bits being flipped.
    So I asked a follow on question about the address boundary of that 128 bit block and the answer was ...
    I can confirm that the start addresses of the 128 bit blocks are those addresses which are divisible by 16.
    I think I can manage to develop I driver to atomically write a multidword object and still be able to detect an interruption on next power up.
1 2
