Migrating sdk5 ANT Broadcast TX Example from nRF52832 to nRF52840
After successfully compiling and flashing both the blinky example and the ble_app_hrs on my nRF52840 I ran into an issue with ANT Broadcast TX example. The example is written for the nRF52832 so I changed the make file and the rom and ram in the linker file to what I thought were the appropriate values for the 52840. It compiled just fine but when I try to flash the S212 soft device and the application hex it does not like it. I am not sure what going wrong during flashing. I have tried changing the main.c to simplify it down to the blinky example but I am still unable to flash. I have attached my simplified main.c, my makefile, and my linker file.
I have a few hunches as to what might be wrong. 1) the linker file has the incorrect origin/length flash/ram values. 2) the softdevice is not being initialized by the application correctly 3) some other file such as the sdk_config.h needs to be changed to work with the 52840.
I appreciate any help with this. Thank you!
1460.sdk_config.h
 * This software is subject to the ANT+ Shared Source License
 * www.thisisant.com/swlicenses
 * Copyright (c) Garmin Canada Inc. 2014
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or
 * without modification, are permitted provided that the following
 * conditions are met:
 *    1) Redistributions of source code must retain the above
 *       copyright notice, this list of conditions and the following
 *       disclaimer.
 *    2) Redistributions in binary form must reproduce the above
 *       disclaimer in the documentation and/or other materials
 *       provided with the distribution.
 *    3) Neither the name of Garmin nor the names of its
 *       contributors may be used to endorse or promote products
 *       derived from this software without specific prior
 *       written permission.
 * The following actions are prohibited:
 *    1) Redistribution of source code containing the ANT+ Network
 *       Key. The ANT+ Network Key is available to ANT+ Adopters.
 *       Please refer to http://thisisant.com to become an ANT+
 *       Adopter and access the key.
 *    2) Reverse engineering, decompilation, and/or disassembly of
 *       software provided in binary form under this license.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
 * CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
 * INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
 * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE HEREBY
 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES(INCLUDING,
 * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
 * SERVICES; DAMAGE TO ANY DEVICE, LOSS OF USE, DATA, OR
 * PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
 * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
 * ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
 * OF THE POSSIBILITY OF SUCH DAMAGE. SOME STATES DO NOT ALLOW
 * THE EXCLUSION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE
 * ABOVE LIMITATIONS MAY NOT APPLY TO YOU.
/**@file
 * @defgroup nrf_ant_broadcast_tx_example ANT Broadcast TX Example
 * @ingroup nrf_ant_broadcast
 * @brief Example of basic ANT Broadcast TX.
 * Before compiling this example for NRF52, complete the following steps:
 * - Download the S212 SoftDevice from <a href="https://www.thisisant.com/developer/components/nrf52832" target="_blank">thisisant.com</a>.
 * - Extract the downloaded zip file and copy the S212 SoftDevice headers to <tt>\<InstallFolder\>/components/softdevice/s212/headers</tt>.
 * If you are using Keil packs, copy the files into a @c headers folder in your example folder.
 * - Make sure that @ref ANT_LICENSE_KEY in @c nrf_sdm.h is uncommented.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nrf.h"
#include "bsp.h"
#include "hardfault.h"
#include "app_error.h"
#include "app_timer.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ant.h"
#include "nrf_pwr_mgmt.h"
#include "ant_interface.h"
#include "ant_parameters.h"
#include "ant_channel_config.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
#include "nrf_gpio.h"
#define APP_ANT_OBSERVER_PRIO   1    /**< Application's ANT observer priority. You shouldn't need to modify this value. */
/**@brief Function for setting payload for ANT message and sending it.
void ant_message_send(void)
    uint8_t         message_payload[ANT_STANDARD_DATA_PAYLOAD_SIZE];
    static uint8_t  counter = 1u;
    memset(message_payload, 0, ANT_STANDARD_DATA_PAYLOAD_SIZE);
    // Assign a new value to the broadcast data.
    message_payload[ANT_STANDARD_DATA_PAYLOAD_SIZE - 1] = counter;
    // Broadcast the data.
    ret_code_t err_code = sd_ant_broadcast_message_tx(BROADCAST_CHANNEL_NUMBER,
                                                      ANT_STANDARD_DATA_PAYLOAD_SIZE,
                                                      message_payload);
    counter++;
/**@brief Function for handling a ANT stack event.
 * @param[in] p_ant_evt  ANT stack event.
 * @param[in] p_context  Context.
static void ant_evt_handler(ant_evt_t * p_ant_evt, void * p_context)
    ret_code_t err_code;
    nrf_pwr_mgmt_feed();
    if (p_ant_evt->channel == BROADCAST_CHANNEL_NUMBER)
        switch (p_ant_evt->event)
            case EVENT_TX:
                ant_message_send();
                err_code = bsp_indication_set(BSP_INDICATE_SENT_OK);
NRF_SDH_ANT_OBSERVER(m_ant_observer, APP_ANT_OBSERVER_PRIO, ant_evt_handler, NULL);
/**@brief Function for the Timer and BSP initialization.
static void utils_setup(void)
    err_code = bsp_init(BSP_INIT_LEDS,
                        NULL);
/**@brief Function for ANT stack initialization.
static void softdevice_setup(void)
    ret_code_t err_code = nrf_sdh_enable_request();
    ASSERT(nrf_sdh_is_enabled());
    err_code = nrf_sdh_ant_enable();
/**@brief Function for setting up the ANT module to be ready for TX broadcast.
static void ant_channel_tx_broadcast_setup(void)
    ant_channel_config_t broadcast_channel_config =
        .channel_number    = BROADCAST_CHANNEL_NUMBER,
        .channel_type      = CHANNEL_TYPE_MASTER,
        .ext_assign        = 0x00,
        .rf_freq           = RF_FREQ,
        .transmission_type = CHAN_ID_TRANS_TYPE,
        .device_type       = CHAN_ID_DEV_TYPE,
        .device_number     = CHAN_ID_DEV_NUM,
        .channel_period    = CHAN_PERIOD,
        .network_number    = ANT_NETWORK_NUM,
    ret_code_t err_code = ant_channel_init(&broadcast_channel_config);
    // Fill tx buffer for the first frame.
    ant_message_send();
    // Open channel.
    err_code = sd_ant_channel_open(BROADCAST_CHANNEL_NUMBER);
 *@brief Function for initializing logging.
static void log_init(void)
/**@brief Function for application main entry. Does not return.
    //log_init();
    //utils_setup();
    //softdevice_setup();
    //ant_channel_tx_broadcast_setup();
    nrf_gpio_cfg_output(36);
    NRF_LOG_INFO("ANT Broadcast TX example started.");
    // Main loop.
    for (;;)
        //NRF_LOG_FLUSH();
        //nrf_pwr_mgmt_run();
                // Turn the LED on
        nrf_gpio_pin_set(36);
        nrf_delay_ms(1000);  // Wait for 1 second
        // Turn the LED off
        nrf_gpio_pin_clear(36);
