Packet loss during ISO transmission when advertising
Bug:
With a connected ISO connection between two devices X and Y:
  • X acts as a peripheral. It's the ISO server and it is transmiting iso data to Y.
  • Y is multirole. It connects to X and establish an ISO connection to receive ISO data.
As long as Y only receives data, the communication is stable (no packet loss). As soon as Y advertises (bt_le_adv_start), Y does not receive all packets.
  • Increasing advertising interval, decrease packet loss.
  • Decreasing advertising interval, increase packet loss.
Environment:
  • OS: Linux
  • Toolchain zephyr-sdk-0.16.8
  • NRF5340DK
  • NCS 2.7 (sdk-nrf v2.7.0 and zephyr v3.6.99-ncs2)
How can solve this issue, which causes too many packet loss ?
Thank you
  • I have updated my diagram according to your previous message:
    If I follow correctly, with 2 retransmission and a latency of 20ms, we shouldn't have any loss. This is what is represented on the diagram.
    So, can you explain to me, why 2 retransmission and a latency of 20ms does not solve this packet loss issue ?
    Thank you
    Sorry for chiming in. As you already know, with an advertising interval set to 20ms, the actual advertising interval could range from 10ms to 30ms due to the random offset. So in the updated diagram, it is possible that the retransmitted Frame B is also blocked by the advertising activity, when the actual advertising interval is ~10ms. Since the retransmission number (RTN) is set to 2, and Frame B has been transmitted twice without a success, Frame B will be flushed, resulting in a packet loss.
    For reference, the basic audio profile (BAP) for Bluetooth low energy defines two sets of quality of service configurations: low latency and high reliability (See 5.6.2 QoS Configurations in https://www.bluetooth.com/specifications/specs/basic-audio-profile-1-0-1/). There you can see a RTN of 2 is still in the realm of "low latency". In your application, to ensure a high reliabitliy without a high packet loss rate, I'd recommend a much higher RTN.
    As a side note, the Softdevice Controller would select flush timeout (FT) and number of subevents (NSE) based on the given RTN and max transport latency. I wouldn't go into details about FT and NSE here to keep the answer short. However, the Softdevice Controller would always prioritize max transport latency over RTN, as by the Core Specification, the RTN is only a recommendation, not a mendatory requirement. Therefore, I would suggest setting a max transport latency that your application can accept first and foremost, and then increase the RTN to achieve better reliability.
    Hope this helps!
    Cheers,
    Yuxuan
    My advertising is 1 second, not 20ms.
    Sorry for the confusion it was only to amplify what I didn't understand in one post. You can forget this value of 20ms.
    So since my advertising is (about) every second, my diagram is valid (I think) and I don't understand why the parameters (rtn:2, latency: 20ms) do not work. Can you provide me with an example where this doesn't work ?
    If possible, can you provide me with the correct parameters to have no packet loss with 1s advertising, 10ms ISO interval and 128 bytes payload ?  (In my opinion, the correct parameters are predictable)
    Thank you
    Here is another possibility.
    The ISO reception could be blocked by the ACL connection. To establish a CIS, you shall have an ACL connection by the spec. These two connections have individual intervals, and it is possible/expected that they would interfere with each other. What is the connection interval you are using for the ACL connection? It is recommended to use an ACL connection interval larger than ISO interval (say 60ms or 70ms when the ISO interval is 10ms) to reduce the inteference. Such interference might already exist before, and it was not noticed because of the retransmission. With the advertising activity of the peripheral, the radio becomes busier and thus the packet loss is noticed.
    It is not guaranteed to work but could you please try a RTN = 13 with a max transport latency >= 50 ms? This allows transmitting the same ISO packet across 5 ISO intervals, in which each interval the packet could be retransmitted 3 times.
    Also, it would be nice if you have any sniffer logs that we could look into.
    Cheers,
    Yuxuan
    So this is my current configuration:
    • Advertising: 1/1.2s
    • ACL: 450/750 ms
    • RTN: 13
    • Latency: 100 ms
    In theory, we should have no packet loss with this configuration (related to Soft Device internal mechanism/scheduling).
    The result of my tests shows:
    • Increasing latency and RTN reduces packet loss, I now see 0.1% packet loss instead of 1%. However, it's still too much loss for a "best case scenario" (2 boards next to each others).
    • Increasing ACL connection is not reducing packet loss.
    I'm sorry to insist, but I need a configuration with 0% packet loss in the "best case scenario". This is mandatory for our product to have the packet loss to a minimum (even though we know we can't have 0% packet loss when deployed).
    To my knowledge, NRFSniffer does not support Isochronous connection. If it's not supported, I can provided you the code I run to reproduce it on your side. That would allow you to sniff the traffic on your side.
    As a reminder, if I remove advertising I see absolutely no packet loss. (Even with 30/60ms ACL connection time)
