BLE Throughput with S112
Hi guys,
starting to improve my throughput with an nrf52805 and S112, i know this version does not support DLE, but it's also the one with lower footprint, I will ask you some questions because i see something that is not clear to me, I read around that there are also "issues" due to mobiles and OS, but to start I will drop here a log from the sniffer and then share other doubts.
Basically I am testing with an android device with nrf toolbox, using NUS to exchange a text file of about 70Kb to get data rate.
First of all I will drop this log...
connection_from_nrf_toolbox_to_nrf52805.pcapng
In this I cannot understand why in packet 1133 here below:
I see a connection interval of 7.5 msec ( so 6 units ) and then after some messages for discovery i get another LL_CONNECTION_UPDATE_IND, both from the master with this...
Where connection interval is set to 45 ms ( so 32 units )
What I can't understand is that I setup my sd to 24 units of interval so 30 ms, but I never see this request...
Where am I wrong?
Than I will have other doubts about data rate...i will attach here a longer long where first I send the file from nrf toolbox to embedded board and then viceversa and seems much more faster when data is sent from embedded to mobile, I just have an UART sending data to Ble via NUS.
mobile-to-nrf52-and-viceversa.pcapng
 Any help is appreaciated in my journey to a higher data rate...
Thanks
  • Q1: no i am just connecting mobile as central to my board as peripheral, what I see also is that for example if I send max interval of 30 and min of 14 it seems settings the average value in the end so 22.
    I will check better my config parameters anyway... I tried on an older asus zenfone with android 9 and also with a samsung a12 with android 13.
    Q2: will check i was just asking if it's a normal behaviour or not.
