there seems to be an overlap problem for rsrp and for rsrq in documentation and code comments
* RSRP.
* * -17: RSRP < -156 dBm
* * -16: -156 ≤ RSRP < -155 dBm
* * -3: -143 ≤ RSRP < -142 dBm
* * -2: -142 ≤ RSRP < -141 dBm
* * -1: -141 ≤ RSRP < -140 dBm
* * 0: RSRP < -140 dBm
* * 1: -140 ≤ RSRP < -139 dBm
* * 2: -139 ≤ RSRP < -138 dBm
* * 95: -46 ≤ RSRP < -45 dBm
* * 96: -45 ≤ RSRP < -44 dBm
* * 97: -44 ≤ RSRP dBm
* * @ref LTE_LC_CELL_RSRP_INVALID : not known or not detectable
int16_t rsrp;
* RSRQ.
* * -30: RSRQ < -34 dB
* * -29: -34 ≤ RSRQ < -33.5 dB
* * -2: -20.5 ≤ RSRQ < -20 dB
* * -1: -20 ≤ RSRQ < -19.5 dB
* * 0: RSRQ < -19.5 dB
* * 1: -19.5 ≤ RSRQ < -19 dB
* * 2: -19 ≤ RSRQ < -18.5 dB
* * 32: -4 ≤ RSRQ < -3.5 dB
* * 33: -3.5 ≤ RSRQ < -3 dB
* * 34: -3 ≤ RSRQ dB
* * 35: -3 ≤ RSRQ < -2.5 dB
* * 36: -2.5 ≤ RSRQ < -2 dB
* * 45: 2 ≤ RSRQ < 2.5 dB
* * 46: 2.5 ≤ RSRQ dB
what is the actual behaviour?
  • This should be fixed in upcoming version of NCS and MFW.
    Thanks again for the report.
    Elfving
  • Hello again Richard,
    Just a quick update. It turns out that the AT command specification follows the RSRP and RSRQ values specified by 3GPP TS 36.133 chapters 9.1.4 and 9.1.7. Because these values come directly from the 3GPP specifications, we’re most likely not going to change the AT command specifications or the LTE LC API.
    This might be an error in the spec. The way it’s currently specified is ambiguous. It is hard to know if this is intentional or not.
    Either way, like I mentioned earlier, this would must likely not be a practical problem. If you believe the way it currently is will turn into an issue for you and your application, please let me know.
    EDIT: Okay, there will be an update after all, but we are unsure about when it will be done.
    Elfving
  • Thanks for the update.
    you can see in another post that using the location lib to directly resolve raw location values to lat,lon position via nrfcloud/here calls from the device is not the approach I follow. Therefore handling the raw values myself became a topic.
    I can not estimate how big the position error can become through the value glitch and when I explain what I developed I feel uneasy to say: I just ignored some points and can't give any estimation for the effects of ignoring these points.
    Also i just want to understand.
    For that reason I also would be happy to read more about the calculations nrfCloud does to derive lat,lon,precision from cells and wifi.
    Best regards
  • Understood.
    For that request it would be better if you could create another DevZone ticket. We try to keep the tickets tidy here by having them focused on one topic each.
    Elfving
