I have an nRF52840 that is on an Ezurio BL654 module that I have programmed dozens of times during development. Something happened during a recent programming event that caused the nRF52840 to stop responding. Appears to be not running code but not in reset either, sort of locked. Not responding very well to SWD programming or recovery and doesn't seem to be able to be erased, programmed again or recovered. I am attaching the recovery log from nrfjprog. The error it gives back on the cmd line is error -21, details in the log. BTW, the code is mcuboot + Zephyr application. Have had no issues like this on other boards of same design and same firmware and hardware. This board worked for a long time. How do I recover?
[2024-Aug-14 16:22:59] [debug] --------------------------------------------------------------------------------
[2024-Aug-14 16:22:59] [debug] nrfjprog -f NRF52 --recover --force --log
[2024-Aug-14 16:22:59] [debug] nrfjprog version 10.23.0 external
[2024-Aug-14 16:22:59] [ info] Load library at C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
[2024-Aug-14 16:22:59] [ info] Library loaded, loading member functions.
[2024-Aug-14 16:22:59] [ info] Member functions succesfully loaded.
[2024-Aug-14 16:22:59] [debug] [ Client] - open
[2024-Aug-14 16:22:59] [debug] [ Client] - start
[2024-Aug-14 16:22:59] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence b710e1a5-90a2-4309-81b5-1074fe9a05a0.
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2024-Aug-14 16:22:59] [trace] [ Client] - Command open executed for 41 milliseconds with result 0
[2024-Aug-14 16:22:59] [debug] [ JLink] - Logger sink registered in JLink logger
[2024-Aug-14 16:22:59] [debug] [ nRF52] - open
[2024-Aug-14 16:22:59] [debug] [ nRF52] - just_check_family
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - open_dll
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2024-Aug-14 16:22:59] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink_V794e\JLink_x64.dll.
[2024-Aug-14 16:22:59] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2024-Aug-14 16:22:59] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - Set batch mode
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - dll_version
[2024-Aug-14 16:22:59] [ info] [SeggerBackend] - Segger dll version 7.94.e loaded.
[2024-Aug-14 16:22:59] [trace] [ Worker] - Command open executed for 3 milliseconds with result 0
[2024-Aug-14 16:22:59] [debug] [ Client] - config
[2024-Aug-14 16:22:59] [trace] [ Client] - Command config executed for 14 milliseconds with result 0
[2024-Aug-14 16:22:59] [debug] [ Client] - enum_emu_snr
[2024-Aug-14 16:22:59] [debug] [ nRF52] - config
[2024-Aug-14 16:22:59] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - enum_emu_snr
[2024-Aug-14 16:22:59] [trace] [ Worker] - Command config executed for 2 milliseconds with result 0
[2024-Aug-14 16:22:59] [debug] [ nRF52] - enum_emu_con_info
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - is_connected_to_emu
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - enum_emu_con_info
[2024-Aug-14 16:22:59] [trace] [ Worker] - Command enum_emu_con_info executed for 2 milliseconds with result 0
[2024-Aug-14 16:22:59] [debug] [ Client] - connect_to_emu_with_snr
[2024-Aug-14 16:22:59] [debug] [ nRF52] - connect_to_emu_with_snr
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - ---just_get_num_emus
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - Segger logging enabled.
[2024-Aug-14 16:22:59] [trace] [ JLink] - Firmware: J-Link V9 compiled May 7 2021 16:26:12
[2024-Aug-14 16:22:59] [trace] [ Client] - Command connect_to_emu_with_snr executed for 45 milliseconds with result 0
[2024-Aug-14 16:22:59] [trace] [ JLink] - Decompressing FW timestamp took 106 us
[2024-Aug-14 16:22:59] [debug] [ Client] - read_connected_emu_snr
[2024-Aug-14 16:22:59] [trace] [ JLink] - Hardware: V9.30
[2024-Aug-14 16:22:59] [trace] [ JLink] - S/N: 609302551
[2024-Aug-14 16:22:59] [trace] [ JLink] - OEM: SEGGER
[2024-Aug-14 16:22:59] [trace] [ JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
[2024-Aug-14 16:22:59] [trace] [ JLink] - Bootloader: (Could not read)
[2024-Aug-14 16:22:59] [trace] [ JLink] - TELNET listener socket opened on port 19021
[2024-Aug-14 16:22:59] [trace] [ JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2024-Aug-14 16:22:59] [trace] [ JLink] - WEBSRV Failed to put socket into listener state (port 19080)
[2024-Aug-14 16:22:59] [trace] [ JLink] - WEBSRV Webserver running on local port 19081
[2024-Aug-14 16:22:59] [trace] [ JLink] - Looking for J-Link GUI Server exe at: C:\Program Files\SEGGER\JLink_V794e\JLinkGUIServer.exe
[2024-Aug-14 16:22:59] [trace] [ JLink] - Forking J-Link GUI Server: C:\Program Files\SEGGER\JLink_V794e\JLinkGUIServer.exe
[2024-Aug-14 16:22:59] [trace] [ Client] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2024-Aug-14 16:22:59] [debug] [ Client] - recover
[2024-Aug-14 16:22:59] [trace] [ JLink] - J-Link GUI Server info: "J-Link GUI server V7.96m "
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 23.554ms returns "O.K."
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_HasError()
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_Lock()
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.002ms returns 0x01
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.000ms returns 0x00
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.004ms returns 0x00
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_SetHookUnsecureDialog
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...)
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.009ms returns 0
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.693ms returns 0x00
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_GetSpeedInfo()
[2024-Aug-14 16:22:59] [trace] [ JLink] - 12000000 Hz / n, n >= 1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.013ms
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 12000kHz
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_SetSpeed(2000)
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.089ms
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_GetSpeed()
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.002ms returns 2000
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - SWD clock set to 2000kHz
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_GetSN()
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.002ms returns 609302551
[2024-Aug-14 16:22:59] [debug] [ nRF52] - read_device_family
[2024-Aug-14 16:22:59] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 43 milliseconds with result 0
[2024-Aug-14 16:22:59] [debug] [ nRF52] - read_connected_emu_snr
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_IsOpen()
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.007ms returns 0x01
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - read_connected_emu_snr
[2024-Aug-14 16:22:59] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2024-Aug-14 16:22:59] [debug] [ nRF52] - recover
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.004ms returns 0x01
[2024-Aug-14 16:22:59] [debug] [ nRF52] - Just_recover
[2024-Aug-14 16:22:59] [debug] [ nRF52] - Just_is_ctrl_ap_available
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - read_access_port_register
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - ---just_read_access_port_register
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - coresight_configure
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_GetHWStatus(...)
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.126ms returns 0
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_CORESIGHT_Configure()
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 99.942ms returns 0
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - read_debug_port_idr
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - read_debug_port_register
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.754ms returns -1
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - ---just_abort_debug_action
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.573ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.617ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.615ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.465ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.515ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.554ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.548ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.517ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.522ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.496ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.472ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.490ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.503ms returns -1
[2024-Aug-14 16:22:59] [error] [ Client] - Encountered error -21: Command recover executed for 124 milliseconds with result -21
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.603ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.652ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.588ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.557ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.498ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.493ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.486ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.467ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.459ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.483ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.461ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.482ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.495ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.488ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.485ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.448ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.457ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.484ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.478ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.501ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.060ms
[2024-Aug-14 16:22:59] [error] [ Worker] - An unknown error.
[2024-Aug-14 16:22:59] [trace] [ Worker] - Command recover executed for 122 milliseconds with result -21
[2024-Aug-14 16:22:59] [debug] [ nRF52] - close
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.024ms returns 0x01
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - close
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - disconnect_from_emu
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - is_connected_to_device
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_IsConnected()
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.003ms returns FALSE
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.561ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.578ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.550ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.494ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.579ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.468ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.480ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.475ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.559ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.462ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.500ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.477ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.487ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.510ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.571ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.452ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.463ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.492ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.535ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.464ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.451ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.460ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.458ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.441ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.518ms returns -1
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.446ms returns -1
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - Ignore exception An unknown error.
[2024-Aug-14 16:22:59] [trace] [ JLink] - - 0.026ms
[2024-Aug-14 16:22:59] [trace] [ JLink] - JLINK_Close()
[2024-Aug-14 16:22:59] [debug] [SeggerBackend] - Segger Backend closed.
[2024-Aug-14 16:22:59] [debug] [ nRF52] - nRF family DLL closed
[2024-Aug-14 16:22:59] [trace] [ Worker] - Command close executed for 62 milliseconds with result 0
[2024-Aug-14 16:22:59] [trace] [ Client] - Command close executed for 78 milliseconds with result 0
[2024-Aug-14 16:22:59] [debug] [ Client] - terminate
[2024-Aug-14 16:22:59] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
[2024-Aug-14 16:22:59] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2024-Aug-14 16:22:59] [trace] [ Worker] - Executed 8 commands for 234 milliseconds
[2024-Aug-14 16:22:59] [debug] [ Client] - Worker process exited with code: 0
[2024-Aug-14 16:22:59] [debug] [ Client] - Child process terminated with result 0
[2024-Aug-14 16:22:59] [trace] [ Client] - Executed 8 commands for 317 milliseconds
