A customer is asking for the following information for the Kyocera antenna we have on the nRF9151-DK - P822601
The attached datasheets detail passive parameters, such as Antenna Gain, Antenna Efficiency, 3-D radiation patterns from
LTE LB ( 698MHz) to MB (3.8GHz).
Do you have any active LTE-M1 RF performance test results of nRF9151 DK + P822601 LTE chip antenna
OTA with CMW500 eNodeB LTE call box for our design reference?
Such as
Max DL TCP/UDP iperf throughput from LTE-M1 LB to MB?
Max UL TCP/UDP iperf throughput from LTE-M1 LB to MB ?
Minimum receiver sensitivity?
Rate versus Range Waterfall chart?
AVX-E_P822601-P822602-5G NR chip antenna-DS.pdf7224909_nRF9151 antenna data information.pdf
