how to disable UART0 for low power
I have a custom nRF9160 board running a modified asset_tracker program. I am using UART0 as a command line interface for testing and debugging. I can enter commands to setup and test the hardware. All is working perfectly. When the nRF9160 board is deployed in the field I need to run on batteries and no longer need the command line interface. Is there a simple or preferred way to disable the UART0 in order to reduce the power without making a completely new code base. The lower power is critical to the application.
