Help with LTE connection after loss of connection
We have noticed that several of our nRF9160 in production have problem with reconnecting to the LTE-M network after temporarily losing connection. We have tried reproducing this issue by deactivating the sim for about 10 seconds and then activating it again. After the default six retries it gives up and stop trying to reconnect to the network. the only way we can achieve a connection is if we do a sys_reboot() or a hard reboot with watchdog. Why is the reconnect attempts not enough? Why do we have to force a reboot? Attached are relevant logs.
  • We set the value to 5s, and the board starts to reregister after 5s instead of after 247s.
    This is exactly how we want the board to behave. Is there any other way to declare the exchange timeouts?
    Have you checked with Wireshark what is exactly happening if you do this?
    What problem do you expect this to fix?
    I tried to explain in  RE: Help with LTE connection after loss of connection why it does not make sense to modify CoAP timeouts for just one specific messages.
    It is highly likely that you need, or want, to modify CoAP timeouts to match the network, but do it globally for all messages. Equally consider what happens in DTLS layer and IP+network layer. When you see problems in application layer protocol (LwM2M) you most probably need to fix the problem on the layer below.
  • My bad. I forgot about using Wireshark this time.
    Here are the last logs before we stop the Leshan server:
    547	110.376831			                 LTE RRC DL_DCCH	53	RRCConnectionReconfiguration
    548	110.377746				             LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    549	110.378113	<LOCAL_IP>	<LESHAN_IP>	 DTLSv1.2	        95	Application Data
    550	110.437866		                     LTE RRC DL_DCCH	47	RRCConnectionReconfiguration
    551	110.438202	    	                 LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    552	118.979034						     AT	                30	Rcvd AT Command: %CESQ: 61,3,16,2
    And here below is the rest of the logs. Around entry 601 (ca 250s after the last registration update), is when the pending registration update fails. A bit after entry 620 is when the watchdog triggers a restart, which is followed by a bootstrapping by our bootstrap server.
    553	120.293121			LTE RRC DL_DCCH	26	RRCConnectionRelease [cause=other]
    554	121.547973			AT	23	Rcvd AT Command: +CSCON: 0
    555	121.548096			AT	31	Rcvd AT Command: %XT3412: 10799999
    556	121.564850			LTE RRC DL_SCH	60	SystemInformationBlockType1
    557	121.565399			LTE RRC DL_SCH	117	SystemInformation [ SIB2 SIB3 ]
    558	121.565582			LTE RRC DL_SCH	117	SystemInformation [ SIB5 ]
    559	127.704376			AT	30	Rcvd AT Command: %CESQ: 61,3,11,1
    560	137.588409			NAS-EPS	20	Service request
    561	137.589355			LTE RRC UL_CCCH	30	RRCConnectionRequest
    562	137.667480			LTE RRC DL_CCCH	71	RRCConnectionSetup
    563	137.668457			LTE RRC UL_DCCH/NAS-EPS	33	RRCConnectionSetupComplete, Service request
    564	137.669952			AT	24	Rcvd AT Command: %XT3412: 0
    565	137.670074			AT	23	Rcvd AT Command: +CSCON: 1
    566	137.729492			LTE RRC DL_DCCH	27	SecurityModeCommand
    567	137.731293			LTE RRC UL_DCCH	26	SecurityModeComplete
    568	137.738525			LTE RRC DL_DCCH	53	RRCConnectionReconfiguration
    569	137.739471			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    570	137.739807	<LOCAL_IP>	<LESHAN_IP>	DTLSv1.2	95	Application Data
    571	137.801575			LTE RRC DL_DCCH	47	RRCConnectionReconfiguration
    572	137.801880			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    573	145.499725			AT	30	Rcvd AT Command: %CESQ: 62,3,16,2
    574	147.741821			LTE RRC DL_DCCH	26	RRCConnectionRelease [cause=other]
    575	148.994293			AT	23	Rcvd AT Command: +CSCON: 0
    576	148.994415			AT	31	Rcvd AT Command: %XT3412: 10799999
    577	149.065552			LTE RRC DL_SCH	60	SystemInformationBlockType1
    578	149.066101			LTE RRC DL_SCH	117	SystemInformation [ SIB2 SIB3 ]
    579	149.066284			LTE RRC DL_SCH	117	SystemInformation [ SIB5 ]
    580	192.408386			NAS-EPS	20	Service request
    581	192.409332			LTE RRC UL_CCCH	30	RRCConnectionRequest
    582	192.489898			LTE RRC DL_CCCH	71	RRCConnectionSetup
    583	192.490845			LTE RRC UL_DCCH/NAS-EPS	33	RRCConnectionSetupComplete, Service request
    584	192.492340			AT	24	Rcvd AT Command: %XT3412: 0
    585	192.492462			AT	23	Rcvd AT Command: +CSCON: 1
    586	192.541931			LTE RRC DL_DCCH	27	SecurityModeCommand
    587	192.543732			LTE RRC UL_DCCH	26	SecurityModeComplete
    588	192.550934			LTE RRC DL_DCCH	53	RRCConnectionReconfiguration
    589	192.551880			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    590	192.552215	<LOCAL_IP>	<LESHAN_IP>	DTLSv1.2	95	Application Data
    591	192.593933			LTE RRC DL_DCCH	47	RRCConnectionReconfiguration
    592	192.594238			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    593	202.591217			LTE RRC DL_DCCH	26	RRCConnectionRelease [cause=other]
    594	203.843689			AT	23	Rcvd AT Command: +CSCON: 0
    595	203.843780			AT	31	Rcvd AT Command: %XT3412: 10799999
    596	203.946960			LTE RRC DL_SCH	60	SystemInformationBlockType1
    597	203.947510			LTE RRC DL_SCH	117	SystemInformation [ SIB2 SIB3 ]
    598	203.947693			LTE RRC DL_SCH	117	SystemInformation [ SIB5 ]
    599	205.786377			AT	30	Rcvd AT Command: %CESQ: 64,3,11,1
    600	302.048248			NAS-EPS	20	Service request
    601	302.049194			LTE RRC UL_CCCH	30	RRCConnectionRequest
    602	302.132690			LTE RRC DL_CCCH	71	RRCConnectionSetup
    603	302.133667			LTE RRC UL_DCCH/NAS-EPS	33	RRCConnectionSetupComplete, Service request
    604	302.135132			AT	24	Rcvd AT Command: %XT3412: 0
    605	302.135254			AT	23	Rcvd AT Command: +CSCON: 1
    606	302.215668			LTE RRC DL_DCCH	27	SecurityModeCommand
    607	302.217499			LTE RRC UL_DCCH	26	SecurityModeComplete
    608	302.224701			LTE RRC DL_DCCH	53	RRCConnectionReconfiguration
    609	302.225647			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    610	302.226013	<LOCAL_IP>	<LESHAN_IP>	DTLSv1.2	95	Application Data
    611	302.269745			LTE RRC DL_DCCH	47	RRCConnectionReconfiguration
    612	302.270050			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    613	312.208038			LTE RRC DL_DCCH	26	RRCConnectionRelease [cause=other]
    614	312.519958			AT	30	Rcvd AT Command: %CESQ: 62,3,16,2
    615	313.460754			AT	23	Rcvd AT Command: +CSCON: 0
    616	313.460876			AT	31	Rcvd AT Command: %XT3412: 10799999
    617	313.549743			LTE RRC DL_SCH	60	SystemInformationBlockType1
    618	313.550293			LTE RRC DL_SCH	117	SystemInformation [ SIB2 SIB3 ]
    619	313.550476			LTE RRC DL_SCH	117	SystemInformation [ SIB5 ]
    620	329.949554			AT	30	Rcvd AT Command: %CESQ: 64,3,11,1
    621	343.474029			NAS-EPS	20	Service request
    622	343.474365			AT	20	Sent AT Command: AT+CMEE?
    623	343.474365			AT	26	Rcvd AT Command: +CMEE: 0  OK
    624	343.475311			AT	21	Sent AT Command: AT+CMEE=1
    625	343.475342			AT	16	Rcvd AT Command: OK
    626	343.475738			AT	19	Sent AT Command: AT%CMNG
    627	343.487915			LTE RRC UL_CCCH	30	RRCConnectionRequest
    628	343.506561			AT	21	Rcvd AT Command: Sensitive
    629	343.507049			AT	21	Sent AT Command: AT+CMEE=0
    630	343.507080			AT	16	Rcvd AT Command: OK
    631	343.507477			AT	20	Sent AT Command: AT+CMEE?
    632	343.507507			AT	26	Rcvd AT Command: +CMEE: 0  OK
    633	343.507965			AT	21	Sent AT Command: AT+CMEE=1
    634	343.507995			AT	16	Rcvd AT Command: OK
    635	343.508606			AT	19	Sent AT Command: AT%CMNG
    636	343.541321			AT	21	Rcvd AT Command: Sensitive
    637	343.541748			AT	21	Sent AT Command: AT+CMEE=0
    638	343.541778			AT	16	Rcvd AT Command: OK
    639	343.542267			AT	20	Sent AT Command: AT+CMEE?
    640	343.542297			AT	26	Rcvd AT Command: +CMEE: 0  OK
    641	343.542724			AT	21	Sent AT Command: AT+CMEE=1
    642	343.542755			AT	16	Rcvd AT Command: OK
    643	343.543701			AT	19	Sent AT Command: AT%CMNG
    644	343.573761			LTE RRC DL_CCCH	71	RRCConnectionSetup
    645	343.574707			LTE RRC UL_DCCH/NAS-EPS	33	RRCConnectionSetupComplete, Service request
    646	343.586059			AT	21	Rcvd AT Command: Sensitive
    647	343.586181			AT	24	Rcvd AT Command: %XT3412: 0
    648	343.586304			AT	23	Rcvd AT Command: +CSCON: 1
    649	343.586883			AT	21	Sent AT Command: AT+CMEE=0
    650	343.586914			AT	16	Rcvd AT Command: OK
    651	343.587585			AT	20	Sent AT Command: AT+CMEE?
    652	343.587616			AT	26	Rcvd AT Command: +CMEE: 0  OK
    653	343.588043			AT	21	Sent AT Command: AT+CMEE=1
    654	343.588043			AT	16	Rcvd AT Command: OK
    655	343.588684			AT	19	Sent AT Command: AT%CMNG
    656	343.628876			AT	21	Rcvd AT Command: Sensitive
    657	343.629791			AT	21	Sent AT Command: AT+CMEE=0
    658	343.629822			AT	16	Rcvd AT Command: OK
    659	343.653778			LTE RRC DL_DCCH	27	SecurityModeCommand
    660	343.655609			LTE RRC UL_DCCH	26	SecurityModeComplete
    661	343.662750			LTE RRC DL_DCCH	53	RRCConnectionReconfiguration
    662	343.663696			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    663	343.664062	<LOCAL_IP>	<LESHAN_IP>	DTLSv1.2	71	Encrypted Alert
    664	343.664154	<LOCAL_IP>	<LESHAN_IP>	DTLS	170	Client Hello
    665	343.719787			LTE RRC DL_DCCH	47	RRCConnectionReconfiguration
    666	343.720123			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    667	344.734955	<LOCAL_IP>	<LESHAN_IP>	DTLS	170	Client Hello
    668	345.824829			AT	30	Rcvd AT Command: %CESQ: 61,3,16,2
    669	346.835632	<LOCAL_IP>	<LESHAN_IP>	DTLS	170	Client Hello
    670	350.936279	<LOCAL_IP>	<LESHAN_IP>	DTLS	170	Client Hello
    671	359.037231	<LOCAL_IP>	<LESHAN_IP>	DTLS	170	Client Hello
    672	369.827514			LTE RRC DL_DCCH	26	RRCConnectionRelease [cause=other]
    673	371.080292			AT	23	Rcvd AT Command: +CSCON: 0
    674	371.080414			AT	31	Rcvd AT Command: %XT3412: 10799999
    675	371.151214			LTE RRC DL_SCH	60	SystemInformationBlockType1
    676	371.151764			LTE RRC DL_SCH	117	SystemInformation [ SIB2 SIB3 ]
    677	371.151947			LTE RRC DL_SCH	117	SystemInformation [ SIB5 ]
    678	375.138611			NAS-EPS	20	Service request
    679	375.152435			LTE RRC UL_CCCH	30	RRCConnectionRequest
    680	375.214569			LTE RRC DL_CCCH	71	RRCConnectionSetup
    681	375.215515			LTE RRC UL_DCCH/NAS-EPS	33	RRCConnectionSetupComplete, Service request
    682	375.216980			AT	24	Rcvd AT Command: %XT3412: 0
    683	375.217071			AT	23	Rcvd AT Command: +CSCON: 1
    684	375.336548			LTE RRC DL_DCCH	27	SecurityModeCommand
    685	375.338348			LTE RRC UL_DCCH	26	SecurityModeComplete
    686	375.345581			LTE RRC DL_DCCH	53	RRCConnectionReconfiguration
    687	375.346527			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    688	375.346863	<LOCAL_IP>	<LESHAN_IP>	DTLS	170	Client Hello
    689	375.392608			LTE RRC DL_DCCH	47	RRCConnectionReconfiguration
    690	375.392944			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    691	378.504019			AT	30	Sent AT Command: AT%XMODEMTRACE=1,2
    692	378.504812			AT	16	Rcvd AT Command: OK
    693	378.505514			AT	34	Sent AT Command: AT%XSYSTEMMODE=1,0,0,0
    694	378.507193			AT	16	Rcvd AT Command: OK
    695	378.507589			AT	46	Sent AT Command: AT+CPSMS=1,,,"00000110","00001111"
    696	378.507711			AT	16	Rcvd AT Command: OK
    697	378.508261			AT	19	Rcvd AT Command: ERROR
    698	378.508657			AT	32	Sent AT Command: AT+CEDRXS=2,4,"0001"
    699	378.508749			AT	16	Rcvd AT Command: OK
    700	378.509146			AT	28	Sent AT Command: AT%XPTW=4,"0000"
    701	378.509237			AT	16	Rcvd AT Command: OK
    702	378.509603			AT	32	Sent AT Command: AT+CEDRXS=2,5,"0000"
    703	378.509634			AT	16	Rcvd AT Command: OK
    704	378.510031			AT	28	Sent AT Command: AT%XPTW=5,"0000"
    705	378.510061			AT	16	Rcvd AT Command: OK
    706	378.510580			AT	20	Sent AT Command: AT%RAI=0
    707	378.510611			AT	16	Rcvd AT Command: OK
    708	378.510977			AT	20	Sent AT Command: AT+CMEE?
    709	378.511007			AT	26	Rcvd AT Command: +CMEE: 0  OK
    710	378.517569			AT	21	Sent AT Command: AT+CMEE=1
    711	378.517599			AT	16	Rcvd AT Command: OK
    712	378.518026			AT	19	Sent AT Command: AT%CMNG
    713	378.551748			AT	16	Rcvd AT Command: OK
    714	378.552114			AT	21	Sent AT Command: AT+CMEE=0
    715	378.552145			AT	16	Rcvd AT Command: OK
    716	378.552542			AT	19	Sent AT Command: AT+CGSN
    717	378.552603			AT	33	Rcvd AT Command: 351358816873084  OK
    718	378.553152			AT	24	Sent AT Command: AT%HWVERSION
    719	378.553274			AT	46	Rcvd AT Command: %HWVERSION: nRF9160 SIAA B1A  OK
    720	378.564718			AT	20	Sent AT Command: AT+CMEE?
    721	378.564749			AT	26	Rcvd AT Command: +CMEE: 0  OK
    722	378.565145			AT	21	Sent AT Command: AT+CMEE=1
    723	378.565176			AT	16	Rcvd AT Command: OK
    724	378.565603			AT	19	Sent AT Command: AT%CMNG
    725	378.594473			AT	16	Rcvd AT Command: OK
    726	378.594931			AT	21	Sent AT Command: AT+CMEE=0
    727	378.594931			AT	16	Rcvd AT Command: OK
    728	378.595358			AT	20	Sent AT Command: AT+CMEE?
    729	378.595388			AT	26	Rcvd AT Command: +CMEE: 0  OK
    730	378.601797			AT	21	Sent AT Command: AT+CMEE=1
    731	378.601828			AT	16	Rcvd AT Command: OK
    732	378.602224			AT	19	Sent AT Command: AT%CMNG
    733	378.630911			AT	16	Rcvd AT Command: OK
    734	378.631369			AT	21	Sent AT Command: AT+CMEE=0
    735	378.631369			AT	16	Rcvd AT Command: OK
    736	378.631796			AT	20	Sent AT Command: AT+CMEE?
    737	378.631826			AT	26	Rcvd AT Command: +CMEE: 0  OK
    738	378.638388			AT	21	Sent AT Command: AT+CMEE=1
    739	378.638418			AT	16	Rcvd AT Command: OK
    740	378.638815			AT	19	Sent AT Command: AT%CMNG
    741	378.667684			AT	16	Rcvd AT Command: OK
    742	378.668142			AT	21	Sent AT Command: AT+CMEE=0
    743	378.668142			AT	16	Rcvd AT Command: OK
    744	378.677816			AT	20	Sent AT Command: AT+CMEE?
    745	378.677816			AT	26	Rcvd AT Command: +CMEE: 0  OK
    746	378.678244			AT	21	Sent AT Command: AT+CMEE=1
    747	378.678274			AT	16	Rcvd AT Command: OK
    748	378.678732			AT	19	Sent AT Command: AT%CMNG
    749	378.707571			AT	16	Rcvd AT Command: OK
    750	378.814871			AT	21	Sent AT Command: AT+CEREG?
    751	378.814962			AT	29	Rcvd AT Command: +CEREG: 0,4  OK
    752	378.821371			AT	20	Sent AT Command: AT+CFUN?
    753	378.821432			AT	26	Rcvd AT Command: +CFUN: 0  OK
    754	378.821859			AT	22	Sent AT Command: AT+CEREG=5
    755	378.821890			AT	16	Rcvd AT Command: OK
    756	378.822409			AT	36	Sent AT Command: AT%XT3412=1,5000,1200000
    757	378.822439			AT	16	Rcvd AT Command: OK
    758	378.822866			AT	22	Sent AT Command: AT+CSCON=1
    759	378.822866			AT	16	Rcvd AT Command: OK
    760	378.823263			AT	21	Sent AT Command: AT+CFUN=1
    761	378.854574			AT	16	Rcvd AT Command: OK
    762	381.096304			LTE RRC DL_SCH	60	SystemInformationBlockType1
    763	381.142416			LTE RRC DL_SCH	117	SystemInformation [ SIB2 SIB3 ]
    764	381.146322			NAS-EPS	110	Attach request, PDN connectivity request
    765	381.148092			AT	43	Rcvd AT Command: +CEREG: 2,"CEA5","0688000B",7
    766	381.148977			AT	22	Sent AT Command: AT%XTIME=1
    767	381.149008			AT	16	Rcvd AT Command: OK
    768	381.262442			LTE RRC DL_SCH	117	SystemInformation [ SIB5 ]
    769	381.265249			LTE RRC UL_CCCH	30	RRCConnectionRequest
    770	381.288534			LTE RRC DL_CCCH	71	RRCConnectionSetup
    771	381.289541			LTE RRC UL_DCCH/NAS-EPS	129	RRCConnectionSetupComplete, Attach request, PDN connectivity request
    772	381.290975			AT	23	Rcvd AT Command: +CSCON: 1
    773	381.612509			LTE RRC DL_DCCH/NAS-EPS	63	DLInformationTransfer, Authentication request
    774	381.612570			NAS-EPS	52	Authentication request
    775	381.646170			NAS-EPS	27	Authentication response
    776	381.646475			LTE RRC UL_DCCH/NAS-EPS	44	ULInformationTransfer, Authentication response
    777	381.740530			LTE RRC DL_DCCH/NAS-EPS	41	DLInformationTransfer, Security mode command
    778	381.740591			NAS-EPS	30	Security mode command
    779	381.741964			NAS-EPS	29	Security mode complete
    780	381.742086			LTE RRC UL_DCCH/NAS-EPS	46	ULInformationTransfer, Ciphered message
    781	382.935598			LTE RRC DL_DCCH	27	SecurityModeCommand
    782	382.937033			LTE RRC UL_DCCH	26	SecurityModeComplete
    783	382.998617			LTE RRC DL_DCCH	50	UECapabilityEnquiry
    784	383.000418			LTE RRC UL_DCCH	136	UECapabilityInformation
    785	383.120718			LTE RRC DL_DCCH/NAS-EPS	181	RRCConnectionReconfiguration, Ciphered message
    786	383.121633			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    787	383.121847			NAS-EPS	143	Attach accept, Activate default EPS bearer context request (PDN type IPv4 only allowed)
    788	383.122518			NAS-EPS	23	Attach complete, Activate default EPS bearer context accept
    789	383.122671			LTE RRC UL_DCCH/NAS-EPS	40	ULInformationTransfer, Ciphered message
    790	383.158651			LTE RRC DL_DCCH	47	RRCConnectionReconfiguration
    791	383.158987			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    792	383.168417			AT	67	Rcvd AT Command: +CEREG: 5,"CEA5","0688000B",7,,,"11100000","11100000"
    793	383.169363			AT	21	Sent AT Command: AT%CESQ=1
    794	383.169363			AT	16	Rcvd AT Command: OK
    795	383.169760			AT	21	Sent AT Command: AT+CEREG?
    796	383.170004			AT	73	Rcvd AT Command: +CEREG: 5,5,"CEA5","0688000B",7,,,"11100000","11100000"  OK
    797	383.170584			AT	23	Sent AT Command: AT%XMONITOR
    798	383.170797			AT	117	Rcvd AT Command: %XMONITOR: 5,"","","26003","CEA5",7,20,"0688000B",19,6200,65,33,"","11100000","11100000","01011110"  OK
    799	383.171591			AT	20	Sent AT Command: AT+CMEE?
    800	383.171621			AT	26	Rcvd AT Command: +CMEE: 0  OK
    801	383.172293			AT	21	Sent AT Command: AT%XCBAND
    802	383.172354			AT	29	Rcvd AT Command: %XCBAND: 20  OK
    803	383.172903			AT	21	Sent AT Command: AT+CMEE=1
    804	383.172934			AT	16	Rcvd AT Command: OK
    805	383.173605			AT	23	Sent AT Command: AT%XCBAND=?
    806	383.173696			AT	67	Rcvd AT Command: %XCBAND: (1,2,3,4,5,8,12,13,18,19,20,25,26,28,66)  OK
    807	383.174490			AT	19	Sent AT Command: AT%CMNG
    808	383.175589			LTE RRC DL_DCCH/NAS-EPS	64	DLInformationTransfer, Ciphered message
    809	383.175711			NAS-EPS	53	EMM information
    810	383.192617			LTE RRC DL_DCCH/NAS-EPS	64	DLInformationTransfer, Ciphered message
    811	383.192739			NAS-EPS	53	EMM information
    812	383.216207			AT	16	Rcvd AT Command: OK
    813	383.216604			AT	44	Rcvd AT Command: %XTIME: ,"42010101532380","01"
    814	383.216787			AT	44	Rcvd AT Command: %XTIME: ,"42010101533380","01"
    815	383.317007			AT	23	Sent AT Command: AT+CGDCONT?
    816	383.317099			AT	30	Rcvd AT Command: %CESQ: 65,3,16,2
    817	383.317465			AT	69	Rcvd AT Command: +CGDCONT: 0,"IP","<HOST>","<LOCAL_IP>",0,0  OK
    818	383.318563			AT	21	Sent AT Command: AT+CMEE=0
    819	383.318594			AT	16	Rcvd AT Command: OK
    820	383.318960			AT	22	Sent AT Command: AT+CEMODE?
    821	383.318991			AT	28	Rcvd AT Command: +CEMODE: 2  OK
    822	383.319570			AT	20	Sent AT Command: AT+CMEE?
    823	383.319570			AT	26	Rcvd AT Command: +CMEE: 0  OK
    824	383.319967			AT	20	Sent AT Command: AT+COPS?
    825	383.320059			AT	38	Rcvd AT Command: +COPS: 0,2,"26003",7  OK
    826	383.320639			AT	21	Sent AT Command: AT+CMEE=1
    827	383.320669			AT	16	Rcvd AT Command: OK
    828	383.321035			AT	21	Sent AT Command: AT+CEREG?
    829	383.321188			AT	73	Rcvd AT Command: +CEREG: 5,5,"CEA5","0688000B",7,,,"11100000","11100000"  OK
    830	383.322164			AT	19	Sent AT Command: AT%CMNG
    831	383.355062			AT	21	Rcvd AT Command: Sensitive
    832	383.355520			AT	21	Sent AT Command: AT+CEREG?
    833	383.355673			AT	73	Rcvd AT Command: +CEREG: 5,5,"CEA5","0688000B",7,,,"11100000","11100000"  OK
    834	383.356497			AT	21	Sent AT Command: AT+CMEE=0
    835	383.356527			AT	16	Rcvd AT Command: OK
    836	383.357046			AT	27	Sent AT Command: AT%XSYSTEMMODE?
    837	383.357077			AT	39	Rcvd AT Command: %XSYSTEMMODE: 1,0,0,0  OK
    838	383.357870			AT	27	Sent AT Command: AT%XSYSTEMMODE?
    839	383.357901			AT	39	Rcvd AT Command: %XSYSTEMMODE: 1,0,0,0  OK
    840	383.358511	<LOCAL_IP>	8.8.8.8	DNS	73	Standard query 0x3d71 A <BOOTSTRAP_SERVER_HOST>
    841	383.359335			AT	27	Sent AT Command: AT%XSYSTEMMODE?
    842	383.359365			AT	39	Rcvd AT Command: %XSYSTEMMODE: 1,0,0,0  OK
    843	383.359945			AT	20	Sent AT Command: AT+CMEE?
    844	383.359976			AT	26	Rcvd AT Command: +CMEE: 0  OK
    845	383.360403			AT	23	Sent AT Command: AT+CGDCONT?
    846	383.360525			AT	69	Rcvd AT Command: +CGDCONT: 0,"IP","<HOST>","<LOCAL_IP>",0,0  OK
    847	383.361380			AT	21	Sent AT Command: AT+CMEE=1
    848	383.361410			AT	16	Rcvd AT Command: OK
    849	383.361898			AT	19	Sent AT Command: AT+CESQ
    850	383.361929			AT	44	Rcvd AT Command: +CESQ: 99,99,255,255,16,65  OK
    851	383.362631			AT	19	Sent AT Command: AT%CMNG
    852	383.397665			AT	16	Rcvd AT Command: OK
    853	383.398153			AT	36	Sent AT Command: AT+CRSM=176,12258,0,0,10
    854	383.416769			AT	53	Rcvd AT Command: +CRSM: 144,0,"98882208660645235687"  OK
    855	383.417562			AT	21	Sent AT Command: AT+CMEE=0
    856	383.417593			AT	16	Rcvd AT Command: OK
    857	383.418020			AT	19	Sent AT Command: AT+CIMI
    858	383.418020			AT	33	Rcvd AT Command: 901405105432657  OK
    859	383.418600			AT	20	Sent AT Command: AT+CMEE?
    860	383.418600			AT	26	Rcvd AT Command: +CMEE: 0  OK
    861	383.419058			AT	19	Sent AT Command: AT+CGMR
    862	383.419088			AT	35	Rcvd AT Command: mfw_nrf9160_1.3.6  OK
    863	383.419638			AT	21	Sent AT Command: AT+CMEE=1
    864	383.419668			AT	16	Rcvd AT Command: OK
    865	383.420156			AT	20	Sent AT Command: AT%XVBAT
    866	383.420187			AT	30	Rcvd AT Command: %XVBAT: 3825  OK
    867	383.420980			AT	19	Sent AT Command: AT%CMNG
    868	383.449758	8.8.8.8	<LOCAL_IP>	DNS	89	Standard query response 0x3d71 A <BOOTSTRAP_SERVER_HOST> A <BOOTSTRAP_SERVER_IP>
    869	383.453146	<LOCAL_IP>	<BOOTSTRAP_SERVER_IP>	CoAP	89	CON, MID:56360, POST, TKN:55 dc 69 a5 a0 40 46 3e, /bs?ep=<MY_ENDPOINT>&pct=112
    870	383.463888			AT	21	Rcvd AT Command: Sensitive
    871	383.464559			AT	19	Sent AT Command: AT+CGSN
    872	383.464651			AT	33	Rcvd AT Command: 351358816873084  OK
    873	383.465811			AT	21	Sent AT Command: AT+CMEE=0
    874	383.465841			AT	16	Rcvd AT Command: OK
    875	383.541616	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	52	ACK, MID:56360, 2.04 Changed, TKN:55 dc 69 a5 a0 40 46 3e, /bs
    876	383.541677	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	54	CON, MID:43820, DELETE, TKN:20 5d 90 aa f3 4b c0 f8, /0
    877	383.550833	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43820, 2.02 Deleted, TKN:20 5d 90 aa f3 4b c0 f8, /0
    878	383.708517	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	54	CON, MID:43821, DELETE, TKN:bc da d7 f6 d6 2f 04 d7, /1
    879	383.712789	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43821, 2.02 Deleted, TKN:bc da d7 f6 d6 2f 04 d7, /1
    880	383.786611	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	169	CON, MID:43822, PUT, TKN:b4 05 1e aa b6 b8 2f a7, /0/0
    881	383.790579	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43822, 2.04 Changed, TKN:b4 05 1e aa b6 b8 2f a7, /0/0
    882	383.866659	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	219	CON, MID:43823, PUT, TKN:8c 6b 9a cd 24 c9 f2 21, /0/1
    883	383.880941	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43823, 2.04 Changed, TKN:8c 6b 9a cd 24 c9 f2 21, /0/1
    884	383.994650	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	101	CON, MID:43824, PUT, TKN:f8 e9 85 df d5 f2 64 1e, /1/0
    885	384.002157	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43824, 2.04 Changed, TKN:f8 e9 85 df d5 f2 64 1e, /1/0
    886	384.103567	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	89	CON, MID:43825, PUT, TKN:70 f3 84 07 02 32 ca 18, /10351/0
    887	384.106161	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43825, 4.04 Not Found, TKN:70 f3 84 07 02 32 ca 18, /10351/0
    888	384.259573	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	89	CON, MID:43826, PUT, TKN:f4 cb 52 80 e1 5b 6a 12, /10351/1
    889	384.262136	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43826, 4.04 Not Found, TKN:f4 cb 52 80 e1 5b 6a 12, /10351/1
    890	384.417562	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	89	CON, MID:43827, PUT, TKN:cc a6 56 2f f3 cf 13 7c, /10351/2
    891	384.420187	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43827, 4.04 Not Found, TKN:cc a6 56 2f f3 cf 13 7c, /10351/2
    892	384.525625	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	89	CON, MID:43828, PUT, TKN:ec ca e4 7f 2d fc b8 97, /10351/3
    893	384.528219	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43828, 4.04 Not Found, TKN:ec ca e4 7f 2d fc b8 97, /10351/3
    894	384.659597	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	89	CON, MID:43829, PUT, TKN:20 b0 ab 40 29 ff 17 51, /10351/4
    895	384.662161	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43829, 4.04 Not Found, TKN:20 b0 ab 40 29 ff 17 51, /10351/4
    896	384.817587	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	89	CON, MID:43830, PUT, TKN:5c e7 5f da 96 6b 1d 22, /10351/5
    897	384.820211	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43830, 4.04 Not Found, TKN:5c e7 5f da 96 6b 1d 22, /10351/5
    898	384.970602	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	89	CON, MID:43831, PUT, TKN:b0 f3 8c ad 28 54 82 e0, /10351/6
    899	384.973165	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43831, 4.04 Not Found, TKN:b0 f3 8c ad 28 54 82 e0, /10351/6
    900	385.057608	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	89	CON, MID:43832, PUT, TKN:dc 63 68 88 6a af 2c bf, /10351/7
    901	385.060202	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43832, 4.04 Not Found, TKN:dc 63 68 88 6a af 2c bf, /10351/7
    902	385.216635	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	89	CON, MID:43833, PUT, TKN:c0 ca 16 9c 80 33 92 07, /10351/8
    903	385.219198	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43833, 4.04 Not Found, TKN:c0 ca 16 9c 80 33 92 07, /10351/8
    904	385.379660	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	89	CON, MID:43834, PUT, TKN:e8 9d 24 38 f4 e4 30 ef, /10351/9
    905	385.382254	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43834, 4.04 Not Found, TKN:e8 9d 24 38 f4 e4 30 ef, /10351/9
    906	385.495596	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43835, PUT, TKN:60 f7 e6 58 85 24 86 a6, /10351/10
    907	385.498220	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43835, 4.04 Not Found, TKN:60 f7 e6 58 85 24 86 a6, /10351/10
    908	385.617605	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43836, PUT, TKN:78 8b 53 5a ae 5f 6f ae, /10351/11
    909	385.620230	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43836, 4.04 Not Found, TKN:78 8b 53 5a ae 5f 6f ae, /10351/11
    910	385.776632	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43837, PUT, TKN:88 9a d4 f3 9c cf 92 3b, /10351/12
    911	385.779226	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43837, 4.04 Not Found, TKN:88 9a d4 f3 9c cf 92 3b, /10351/12
    912	385.935629	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43838, PUT, TKN:18 95 90 a7 7b 38 30 7c, /10351/13
    913	385.938223	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43838, 4.04 Not Found, TKN:18 95 90 a7 7b 38 30 7c, /10351/13
    914	386.020620	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43839, PUT, TKN:d0 ae 32 0a 24 1d ac 11, /10351/14
    915	386.023184	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43839, 4.04 Not Found, TKN:d0 ae 32 0a 24 1d ac 11, /10351/14
    916	386.176687	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43840, PUT, TKN:88 a7 09 a4 05 dd a8 9e, /10351/15
    917	386.179312	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43840, 4.04 Not Found, TKN:88 a7 09 a4 05 dd a8 9e, /10351/15
    918	386.346640	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43841, PUT, TKN:38 c5 7d e2 ab a6 c0 ca, /10351/16
    919	386.349264	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43841, 4.04 Not Found, TKN:38 c5 7d e2 ab a6 c0 ca, /10351/16
    920	386.475698	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43842, PUT, TKN:24 9e 6a ac 63 8f fc ac, /10351/17
    921	386.478292	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43842, 4.04 Not Found, TKN:24 9e 6a ac 63 8f fc ac, /10351/17
    922	386.576681	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43843, PUT, TKN:e0 19 e4 74 92 d5 04 7f, /10351/18
    923	386.579275	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43843, 4.04 Not Found, TKN:e0 19 e4 74 92 d5 04 7f, /10351/18
    924	386.652670	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43844, PUT, TKN:04 46 e9 d7 8f 69 40 8f, /10351/19
    925	386.655264	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43844, 4.04 Not Found, TKN:04 46 e9 d7 8f 69 40 8f, /10351/19
    926	386.729666	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43845, PUT, TKN:b0 0b b1 b8 77 bf 98 e9, /10351/20
    927	386.732260	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43845, 4.04 Not Found, TKN:b0 0b b1 b8 77 bf 98 e9, /10351/20
    928	386.817678	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43846, PUT, TKN:28 37 b3 85 d7 d4 d3 f9, /10351/21
    929	386.820242	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43846, 4.04 Not Found, TKN:28 37 b3 85 d7 d4 d3 f9, /10351/21
    930	386.981649	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43847, PUT, TKN:58 56 b4 1e f5 4e b1 d3, /10351/22
    931	386.984274	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43847, 4.04 Not Found, TKN:58 56 b4 1e f5 4e b1 d3, /10351/22
    932	387.137655	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43848, PUT, TKN:3c 6c a1 93 5b 1e 84 1a, /10351/23
    933	387.140249	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43848, 4.04 Not Found, TKN:3c 6c a1 93 5b 1e 84 1a, /10351/23
    934	387.297720	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43849, PUT, TKN:94 e8 2b 46 3c 61 d9 61, /10351/24
    935	387.300283	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43849, 4.04 Not Found, TKN:94 e8 2b 46 3c 61 d9 61, /10351/24
    936	387.457693	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43850, PUT, TKN:28 3e 26 be 8c 7b 44 a9, /10351/25
    937	387.460348	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43850, 4.04 Not Found, TKN:28 3e 26 be 8c 7b 44 a9, /10351/25
    938	387.626699	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43851, PUT, TKN:d4 6d b9 11 9b 78 17 08, /10351/26
    939	387.629293	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43851, 4.04 Not Found, TKN:d4 6d b9 11 9b 78 17 08, /10351/26
    940	387.776724	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43852, PUT, TKN:b0 22 7a 7f b9 3e 84 75, /10351/27
    941	387.779318	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43852, 4.04 Not Found, TKN:b0 22 7a 7f b9 3e 84 75, /10351/27
    942	387.936697	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43853, PUT, TKN:dc 98 51 c5 97 25 ee 7b, /10351/28
    943	387.939291	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43853, 4.04 Not Found, TKN:dc 98 51 c5 97 25 ee 7b, /10351/28
    944	388.026693	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43854, PUT, TKN:14 18 3d de a3 a7 1d 76, /10351/29
    945	388.029257	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43854, 4.04 Not Found, TKN:14 18 3d de a3 a7 1d 76, /10351/29
    946	388.179739	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43855, PUT, TKN:60 f5 94 ab 97 f5 dc 8f, /10351/30
    947	388.182333	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43855, 4.04 Not Found, TKN:60 f5 94 ab 97 f5 dc 8f, /10351/30
    948	388.337698	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	91	CON, MID:43856, PUT, TKN:30 74 79 83 a9 04 ac 36, /10351/31
    949	388.340292	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43856, 4.04 Not Found, TKN:30 74 79 83 a9 04 ac 36, /10351/31
    950	388.485647	<LESHAN_SERVER_IP>	<LOCAL_IP>	CoAP	55	CON, MID:43857, POST, TKN:ac 2a ab 5d e2 d9 d0 dd, /bs
    951	388.486776	<LOCAL_IP>	<LESHAN_SERVER_IP>	CoAP	52	ACK, MID:43857, 2.04 Changed, TKN:ac 2a ab 5d e2 d9 d0 dd, /bs
    952	389.489340	<LOCAL_IP>	8.8.8.8	DNS	77	Standard query 0x7c71 A <LESHAN_SERVER_HOST>
    953	389.619802	8.8.8.8	<LOCAL_IP>	DNS	93	Standard query response 0x7c71 A <LESHAN_SERVER_HOST> A <LESHAN_SERVER_IP>
    954	389.620718			AT	20	Sent AT Command: AT+CMEE?
    955	389.620718			AT	26	Rcvd AT Command: +CMEE: 0  OK
    956	389.621145			AT	21	Sent AT Command: AT+CMEE=1
    957	389.621145			AT	16	Rcvd AT Command: OK
    958	389.621603			AT	19	Sent AT Command: AT%CMNG
    959	389.661673			AT	16	Rcvd AT Command: OK
    960	389.662069			AT	21	Sent AT Command: AT+CMEE=0
    961	389.662100			AT	16	Rcvd AT Command: OK
    962	389.662680			AT	20	Sent AT Command: AT+CMEE?
    963	389.662680			AT	26	Rcvd AT Command: +CMEE: 0  OK
    964	389.663107			AT	21	Sent AT Command: AT+CMEE=1
    965	389.663107			AT	16	Rcvd AT Command: OK
    966	389.663717			AT	19	Sent AT Command: AT%CMNG
    967	389.704580			AT	21	Rcvd AT Command: Sensitive
    968	389.705038			AT	21	Sent AT Command: AT+CMEE=0
    969	389.705038			AT	16	Rcvd AT Command: OK
    970	389.705648			AT	20	Sent AT Command: AT+CFUN?
    971	389.705740			AT	26	Rcvd AT Command: +CFUN: 1  OK
    972	389.706198			AT	21	Sent AT Command: AT+CFUN=4
    973	389.707205			NAS-EPS	31	Detach request (Combined EPS/IMSI detach / switch-off)
    974	389.707327			LTE RRC UL_DCCH/NAS-EPS	48	ULInformationTransfer, Ciphered message
    975	389.799063			AT	23	Rcvd AT Command: +CEREG: 0
    976	389.896780			LTE RRC DL_DCCH	26	RRCConnectionRelease [cause=other]
    977	390.895803			AT	30	Rcvd AT Command: %CESQ: 62,3,11,1
    978	391.159750			AT	32	Rcvd AT Command: %CESQ: 255,0,255,0
    979	391.161428			AT	23	Rcvd AT Command: +CSCON: 0
    980	391.229055			AT	16	Rcvd AT Command: OK
    981	391.229513			AT	20	Sent AT Command: AT+CMEE?
    982	391.229513			AT	26	Rcvd AT Command: +CMEE: 0  OK
    983	391.229971			AT	21	Sent AT Command: AT+CMEE=1
    984	391.229971			AT	16	Rcvd AT Command: OK
    985	391.230429			AT	19	Sent AT Command: AT%CMNG
    986	391.265005			AT	16	Rcvd AT Command: OK
    987	391.265463			AT	21	Sent AT Command: AT+CMEE=0
    988	391.265463			AT	16	Rcvd AT Command: OK
    989	391.265921			AT	20	Sent AT Command: AT+CMEE?
    990	391.265921			AT	26	Rcvd AT Command: +CMEE: 0  OK
    991	391.266348			AT	21	Sent AT Command: AT+CMEE=1
    992	391.266378			AT	16	Rcvd AT Command: OK
    993	391.267019			AT	19	Sent AT Command: AT%CMNG
    994	391.319479			AT	16	Rcvd AT Command: OK
    995	391.319906			AT	21	Sent AT Command: AT+CMEE=0
    996	391.319906			AT	16	Rcvd AT Command: OK
    997	391.320333			AT	20	Sent AT Command: AT+CFUN?
    998	391.320394			AT	26	Rcvd AT Command: +CFUN: 4  OK
    999	391.320822			AT	21	Sent AT Command: AT+CEREG?
    1000	391.320913			AT	29	Rcvd AT Command: +CEREG: 5,0  OK
    1001	391.327352			AT	20	Sent AT Command: AT+CFUN?
    1002	391.327413			AT	26	Rcvd AT Command: +CFUN: 4  OK
    1003	391.327810			AT	22	Sent AT Command: AT+CEREG=5
    1004	391.327810			AT	16	Rcvd AT Command: OK
    1005	391.328360			AT	36	Sent AT Command: AT%XT3412=1,5000,1200000
    1006	391.328390			AT	16	Rcvd AT Command: OK
    1007	391.328756			AT	22	Sent AT Command: AT+CSCON=1
    1008	391.328787			AT	16	Rcvd AT Command: OK
    1009	391.329153			AT	21	Sent AT Command: AT+CFUN=1
    1010	391.360098			AT	16	Rcvd AT Command: OK
    1011	392.216604			LTE RRC DL_SCH	60	SystemInformationBlockType1
    1012	392.217153			LTE RRC DL_SCH	117	SystemInformation [ SIB2 SIB3 ]
    1013	392.217337			LTE RRC DL_SCH	117	SystemInformation [ SIB5 ]
    1014	392.219625			NAS-EPS	110	Attach request, PDN connectivity request
    1015	392.221395			AT	29	Rcvd AT Command: %CESQ: 57,2,4,0
    1016	392.221548			AT	43	Rcvd AT Command: +CEREG: 2,"CEA5","0688000B",7
    1017	392.222525			AT	22	Sent AT Command: AT%XTIME=1
    1018	392.222555			AT	16	Rcvd AT Command: OK
    1019	392.227560			LTE RRC UL_CCCH	30	RRCConnectionRequest
    1020	392.268820			LTE RRC DL_CCCH	71	RRCConnectionSetup
    1021	392.269796			LTE RRC UL_DCCH/NAS-EPS	129	RRCConnectionSetupComplete, Attach request, PDN connectivity request
    1022	392.271261			AT	23	Rcvd AT Command: +CSCON: 1
    1023	392.281790			AT	30	Rcvd AT Command: %CESQ: 59,2,10,1
    1024	392.516806			LTE RRC DL_DCCH/NAS-EPS	36	DLInformationTransfer
    1025	392.516958			IP	21	Bogus IP version (2)
    1026	392.516989			IP	24	Bogus IP version (0)
    1027	392.517141			LTE RRC UL_DCCH/NAS-EPS	45	ULInformationTransfer, Ciphered message
    1028	393.284811			AT	30	Rcvd AT Command: %CESQ: 59,2,15,2
    1029	393.624899			LTE RRC DL_DCCH	27	SecurityModeCommand
    1030	393.626364			LTE RRC UL_DCCH	26	SecurityModeComplete
    1031	393.717886			LTE RRC DL_DCCH	50	UECapabilityEnquiry
    1032	393.719778			LTE RRC UL_DCCH	136	UECapabilityInformation
    1033	393.833059			LTE RRC DL_DCCH/NAS-EPS	168	RRCConnectionReconfiguration, Ciphered message
    1034	393.833853			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    1035	393.834066			NAS-EPS	130	Attach accept, Activate default EPS bearer context request (PDN type IPv4 only allowed)
    1036	393.834677			NAS-EPS	23	Attach complete, Activate default EPS bearer context accept
    1037	393.834799			LTE RRC UL_DCCH/NAS-EPS	40	ULInformationTransfer, Ciphered message
    1038	393.876944			LTE RRC DL_DCCH	47	RRCConnectionReconfiguration
    1039	393.877249			LTE RRC UL_DCCH	26	RRCConnectionReconfigurationComplete
    1040	393.886862			AT	67	Rcvd AT Command: +CEREG: 5,"CEA5","0688000B",7,,,"11100000","11100000"
    1041	393.888021			AT	21	Sent AT Command: AT%CESQ=1
    1042	393.888021			AT	16	Rcvd AT Command: OK
    1043	393.888693			AT	23	Sent AT Command: AT%XMONITOR
    1044	393.891104			AT	129	Rcvd AT Command: %XMONITOR: 5,"Orange","Orange","26003","CEA5",7,20,"0688000B",19,6200,60,27,"","11100000","11100000","01011110"  OK
    1045	393.893881			LTE RRC DL_DCCH/NAS-EPS	64	DLInformationTransfer, Ciphered message
    1046	393.894003			NAS-EPS	53	EMM information
    1047	393.894339			AT	21	Sent AT Command: AT%XCBAND
    1048	393.894491			AT	44	Rcvd AT Command: %XTIME: ,"42010101533480","01"
    1049	393.894827			AT	29	Rcvd AT Command: %XCBAND: 20  OK
    1050	393.912863			LTE RRC DL_DCCH/NAS-EPS	64	DLInformationTransfer, Ciphered message
    1051	393.912985			NAS-EPS	53	EMM information
    1052	393.995047			AT	44	Rcvd AT Command: %XTIME: ,"42010101533480","01"
    1053	393.995779			AT	23	Sent AT Command: AT%XCBAND=?
    1054	393.995871			AT	67	Rcvd AT Command: %XCBAND: (1,2,3,4,5,8,12,13,18,19,20,25,26,28,66)  OK
    1055	393.996359			AT	23	Sent AT Command: AT+CGDCONT?
    1056	393.996481			AT	69	Rcvd AT Command: +CGDCONT: 0,"IP","iot.1nce.net","<LOCAL_IP>",0,0  OK
    1057	393.997824			AT	22	Sent AT Command: AT+CEMODE?
    1058	393.997854			AT	28	Rcvd AT Command: +CEMODE: 2  OK
    1059	393.998403			AT	20	Sent AT Command: AT+COPS?
    1060	393.998495			AT	38	Rcvd AT Command: +COPS: 0,2,"26003",7  OK
    1061	393.999319			AT	21	Sent AT Command: AT+CEREG?
    1062	393.999441			AT	73	Rcvd AT Command: +CEREG: 5,5,"CEA5","0688000B",7,,,"11100000","11100000"  OK
    1063	394.000448			AT	21	Sent AT Command: AT+CEREG?
    1064	394.000845			AT	73	Rcvd AT Command: +CEREG: 5,5,"CEA5","0688000B",7,,,"11100000","11100000"  OK
    1065	394.001944			AT	27	Sent AT Command: AT%XSYSTEMMODE?
    1066	394.001974			AT	39	Rcvd AT Command: %XSYSTEMMODE: 1,0,0,0  OK
    1067	394.002951			AT	27	Sent AT Command: AT%XSYSTEMMODE?
    1068	394.002981			AT	39	Rcvd AT Command: %XSYSTEMMODE: 1,0,0,0  OK
    1069	394.003866			AT	27	Sent AT Command: AT%XSYSTEMMODE?
    1070	394.003897			AT	39	Rcvd AT Command: %XSYSTEMMODE: 1,0,0,0  OK
    1071	394.004721			AT	23	Sent AT Command: AT+CGDCONT?
    1072	394.004843			AT	69	Rcvd AT Command: +CGDCONT: 0,"IP","iot.1nce.net","<LOCAL_IP>",0,0  OK
    1073	394.005758			AT	19	Sent AT Command: AT+CESQ
    1074	394.005789			AT	44	Rcvd AT Command: +CESQ: 99,99,255,255,14,60  OK
    1075	394.006765			AT	36	Sent AT Command: AT+CRSM=176,12258,0,0,10
    1076	394.025167			AT	53	Rcvd AT Command: +CRSM: 144,0,"98882208660645235687"  OK
    1077	394.025869			AT	19	Sent AT Command: AT+CIMI
    1078	394.025869			AT	33	Rcvd AT Command: 901405105432657  OK
    1079	394.026449			AT	19	Sent AT Command: AT+CGMR
    1080	394.026480			AT	35	Rcvd AT Command: mfw_nrf9160_1.3.6  OK
    1081	394.027304			AT	20	Sent AT Command: AT%XVBAT
    1082	394.027334			AT	30	Rcvd AT Command: %XVBAT: 3825  OK
    1083	394.027883			AT	19	Sent AT Command: AT+CGSN
    1084	394.027975			AT	33	Rcvd AT Command: 351358816873084  OK
    1085	394.892721	<LOCAL_IP>	<LESHAN_SERVER_IP>	DTLS	138	Client Hello
    1086	396.893545	<LOCAL_IP>	<LESHAN_SERVER_IP>	DTLS	138	Client Hello
    1087	400.894186	<LOCAL_IP>	<LESHAN_SERVER_IP>	DTLS	138	Client Hello
    Are both of these code snippets part of the same log from the server?
    Is log taken when everything was working as expected?
     Could you provide answers to these questions?
    Dejan
  • To answer the first question:
    These logs are the Wireshark logs that are generated by our device when it tries to communicate with a Leshan server that we decide to make unavailable. These are not Leshan logs. We are stopping the Leshan server in order to see how the board behaves, including what the Wireshark logs tell us.
    Second question:
    The problem we are trying to fix is that the board should be able to handle a scenario during which the registration update "gets stuck" for 4min7s. Because the request is pending for so long, we do not get a  LWM2M_RD_CLIENT_EVENT_REG_UPDATE_COMPLETE (which in turn is supposed to perform a watchdog kick) in time, which ends up with the watchdog causing an unnecessary reboot.
  • I cannot replicate this "stuck for 4min7s" issue.
    When I run nRF Connect SDK with unmodified lwm2m_client.c in zephyr/samples/net, build in native_sim, this is the behaviour:
    92 seconds of retries, then fallback to full registration.
    Here is the application log
    [00:00:00.510,000] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 1
    [00:00:00.510,000] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 6
    [00:00:00.510,000] <dbg> net_lwm2m_registry: lwm2m_engine_get: path:1/0/1/0, level 3, buf:0xeecfc19c, buflen:4
    [00:00:00.510,000] <dbg> net_lwm2m_registry: lwm2m_engine_get: path:1/0/0/0, level 3, buf:0xeecfc1de, buflen:2
    [00:00:00.510,000] <inf> net_lwm2m_rd_client: RD Client started with endpoint 'native_sim' with client lifetime 30 using server object 0
    [00:00:00.510,000] <dbg> net_lwm2m_message_handling: lwm2m_parse_peerinfo: Parse url: coap://192.0.2.2:5683
    [00:00:00.510,000] <inf> net_lwm2m_engine: Connected, sock id 0
    [00:00:00.510,000] <dbg> net_lwm2m_registry: lwm2m_engine_get: path:1/0/1/0, level 3, buf:0xeecfc14c, buflen:4
    [00:00:00.510,000] <dbg> net_lwm2m_rd_client: sm_send_registration: registration sent [192.0.2.2]
    [00:00:00.510,000] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 8
    [00:00:00.510,000] <dbg> net_lwm2m_client_app: socket_state: LWM2M_SOCKET_STATE_ONE_RESPONSE
    [00:00:00.600,000] <dbg> net_lwm2m_rd_client: do_registration_reply_cb: Registration callback (code:2.1)
    [00:00:00.600,000] <dbg> net_lwm2m_client_app: rd_client_event: Registration complete
    [00:00:00.600,000] <inf> net_lwm2m_rd_client: Registration Done (EP='HsVT6yWrkF')
    [00:00:00.600,000] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x808cd68 handled and removed
    [00:00:00.600,000] <dbg> net_lwm2m_client_app: socket_state: LWM2M_SOCKET_STATE_NO_DATA
    [00:00:00.600,000] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
    uart:~$ lwm2m update
    [00:00:20.530,000] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
    [00:00:20.530,000] <dbg> net_lwm2m_client_app: rd_client_event: Registration update
    [00:00:20.640,000] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 11
    [00:00:20.640,000] <dbg> net_lwm2m_registry: lwm2m_engine_get: path:1/0/1/0, level 3, buf:0xeecfc15c, buflen:4
    [00:00:20.640,000] <dbg> net_lwm2m_rd_client: sm_send_registration: registration sent [192.0.2.2]
    [00:00:20.640,000] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 12
    [00:00:20.640,000] <dbg> net_lwm2m_client_app: socket_state: LWM2M_SOCKET_STATE_ONE_RESPONSE
    [00:00:23.620,000] <dbg> net_lwm2m_client_app: socket_state: LWM2M_SOCKET_STATE_ONE_RESPONSE
    [00:00:29.540,000] <dbg> net_lwm2m_client_app: socket_state: LWM2M_SOCKET_STATE_ONE_RESPONSE
    [00:00:41.400,000] <dbg> net_lwm2m_client_app: socket_state: LWM2M_SOCKET_STATE_ONE_RESPONSE
    [00:01:05.100,000] <dbg> net_lwm2m_client_app: socket_state: LWM2M_SOCKET_STATE_ONE_RESPONSE
    [00:01:52.510,000] <wrn> net_lwm2m_rd_client: Registration Update Timeout
    [00:01:52.510,000] <dbg> net_lwm2m_client_app: rd_client_event: Registration timeout!
    [00:01:53.020,000] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 6
    [00:01:53.020,000] <dbg> net_lwm2m_registry: lwm2m_engine_get: path:1/0/1/0, level 3, buf:0xeecfc19c, buflen:4
    [00:01:53.020,000] <dbg> net_lwm2m_registry: lwm2m_engine_get: path:1/0/0/0, level 3, buf:0xeecfc1de, buflen:2
    [00:01:53.020,000] <inf> net_lwm2m_rd_client: RD Client started with endpoint 'native_sim' with client lifetime 30 using server object 0
    [00:01:53.020,000] <dbg> net_lwm2m_message_handling: lwm2m_parse_peerinfo: Parse url: coap://192.0.2.2:5683
    [00:01:53.020,000] <inf> net_lwm2m_engine: Connected, sock id 0
    [00:01:53.020,000] <dbg> net_lwm2m_registry: lwm2m_engine_get: path:1/0/1/0, level 3, buf:0xeecfc14c, buflen:4
    [00:01:53.020,000] <dbg> net_lwm2m_rd_client: sm_send_registration: registration sent [192.0.2.2]
    [00:01:53.020,000] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 8
    [00:01:53.020,000] <dbg> net_lwm2m_client_app: socket_state: LWM2M_SOCKET_STATE_ONE_RESPONSE
    [00:01:55.400,000] <dbg> net_lwm2m_client_app: socket_state: LWM2M_SOCKET_STATE_ONE_RESPONSE
    [00:02:00.120,000] <dbg> net_lwm2m_registry: lwm2m_engine_set: path:3303/0/5700, buf:0xf04ff1f8, len:8
    [00:02:00.140,000] <dbg> net_lwm2m_client_app: socket_state: LWM2M_SOCKET_STATE_ONE_RESPONSE
    [00:02:00.240,000] <dbg> net_lwm2m_rd_client: do_registration_reply_cb: Registration callback (code:2.1)
    [00:02:00.240,000] <dbg> net_lwm2m_client_app: rd_client_event: Registration complete
    [00:02:00.240,000] <inf> net_lwm2m_rd_client: Registration Done (EP='Qf5sCfKOzy')
    [00:02:00.240,000] <dbg> net_lwm2m_message_handling: lwm2m_udp_receive: reply 0x808cd68 handled and removed
    [00:02:00.240,000] <dbg> net_lwm2m_client_app: socket_state: LWM2M_SOCKET_STATE_NO_DATA
    [00:02:00.240,000] <dbg> net_lwm2m_rd_client: lwm2m_rd_client_service: State: 9
    uart:~$
    Notice that there is even the application event:
    Behaviour is pretty much the same when DTLS is used. It just re-starts the DTLS handshake before registration starts.
    So I don't think I have seen the real root cause that gets devices disconnected.
