Help with LTE connection after loss of connection
We have noticed that several of our nRF9160 in production have problem with reconnecting to the LTE-M network after temporarily losing connection. We have tried reproducing this issue by deactivating the sim for about 10 seconds and then activating it again. After the default six retries it gives up and stop trying to reconnect to the network. the only way we can achieve a connection is if we do a sys_reboot() or a hard reboot with watchdog. Why is the reconnect attempts not enough? Why do we have to force a reboot? Attached are relevant logs.
  • Thank you
    Yes, we are using our own Leshan server.
    https://github.com/eclipse-leshan/leshan/issues/1166
    I read through this issue, and I did not really understand how we would have to modify our Californium.properties file to support CID.
  • That ticket is from a time long ago.
    During the development of RFC 9146 the MAC calculation has changed pretty late. That caused also the usage of a new Hello Extension ID.
    Unfortunately, the mbedtls team wasn't able to adapt and update the implementation in time, therefore to complicated workaround in that old issue.
    Today for Californium you only need to enable DTLS 1.2 CID with
    # DTLS connection ID length. <blank> disabled, 0 enables support without
    # active use of CID.
    DTLS.CONNECTION_ID_LENGTH=6
    But I'm not sure, what is required for Leshan to handle the address changes in other layers as well. Therefore you maybe open an ticket there.
  • Try:
      # DTLS update address using CID on newer records.
      # Default: true
      DTLS.UPDATE_ADDRESS_USING_CID_ON_NEWER_RECORDS=true
    I don't see that `DTLS.CONNECTION_ID_LENGTH` setting in our Leshan server, so maybe it supports it by default, if the client requests Connection-ID.
    With the current Leshan, I have not seen any problems with Connection-ID. Even that "UPDATE_ADDRESS" setting seem to be on by default.
    You can verify your configuration by running one client against https://leshan.eclipseprojects.io/ it supports DTLS CID and updates client IP when I do LwM2M Update.
  • Thank you. We will try this.
    Now, when the server responds to registration updates immediately, the device keeps running longer.
    However, we are consistently seeing that, after almost 50min, the board just restarts itself. See logs:
    [00:48:13.524,230] <inf> net_lwm2m_rd_client: Update Done
    [00:48:32.525,146] <dbg> app_lwm2m_client: rd_client_event: Registration update started
    [00:48:32.892,547] <inf> net_lwm2m_rd_client: Update callback (code:2.4)
    [00:48:32.892,608] <dbg> app_lwm2m_client: rd_client_event: Registration update complete
    [00:48:32.892,608] <dbg> app_lwm2m_client: watchdog_Kick: Watchdog feed ok!
    [00:48:32.892,700] <inf> net_lwm2m_rd_client: Update Done
    [00:48:51.892,669] <dbg> app_lwm2m_client: rd_client_event: Registration update started
    [00:48:52.323,059] <inf> net_lwm2m_rd_client: Update callback (code:2.4)
    [00:48:52.323,089] <dbg> app_lwm2m_client: rd_client_event: Registration update complete
    [00:48:52.323,120] <dbg> app_lwm2m_client: watchdog_Kick: Watchdog feed ok!
    [00:48:52.323,211] <inf> net_lwm2m_rd_client: Update Done
    [00:49:11.324,127] <dbg> app_lwm2m_client: rd_client_event: Registration update started
    [00:49:11.685,546] <inf> net_lwm2m_rd_client: Update callback (code:2.4)
    [00:49:11.685,577] <dbg> app_lwm2m_client: rd_client_event: Registration update complete
    [00:49:11.685,607] <dbg> app_lwm2m_client: watchdog_Kick: Watchdog feed ok!
    [00:49:11.685,699] <inf> net_lwm2m_rd_client: Update Done
    [00:49:30.685,607] <dbg> app_lwm2m_client: rd_client_event: Registration update started
    [00:49:31.045,043] <inf> net_lwm2m_rd_client: Update callback (code:2.4)
    [00:49:31.045,074] <dbg> app_lwm2m_client: rd_client_event: Registration update complete
    [00:49:31.045,104] <dbg> app_lwm2m_client: watchdog_Kick: Watchdog feed ok!
    [00:49:31.045,196] <inf> net_lwm2m_rd_client: Update Done
    uart:~$ *** Booting nRF Connect SDK v3.5.99-ncs1 ***
    I: Starting bootloader
    I: Primary image: magic=good, swap_type=0x2, copy_done=0x1, image_ok=0x1
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Boot source: none
    I: Image index: 0, Swap type: none
    I: Bootloader chainload address offset: 0x10000
    I: Jumping to the first image slot
    [00:00:00.255,310] <inf> app_lwm2m_client: Run LWM2M client
    [00:00:00.255,371] <dbg> app_lwm2m_client: watchdog_Init: Watchdog started: 0
    --- 14 messages dropped ---
    [00:00:00.495,605] <inf> app_lwm2m_client: Clearing PSK
    [00:00:00.526,641] <dbg> app_lwm2m_client: watchdog_Kick: Watchdog feed ok!
    [00:00:00.805,114] <err> net_lwm2m_registry: obj field 300 not found
    [00:00:00.805,297] <err> net_lwm2m_registry: obj field 300 not found
    [00:00:00.805,450] <err> net_lwm2m_registry: obj field 300 not found
    Could there be something outside of the lwm2m client or anything else that is causing a reboot after 50 min?
    Here is our prj.conf file:
    # General config
    CONFIG_ASSERT=y
    CONFIG_REBOOT=y
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_NATIVE=n
    CONFIG_NET_IPV6=n
    CONFIG_NET_IPV4=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_OFFLOAD=y
    # Sensors
    CONFIG_ADC=y
    CONFIG_SPI=y
    CONFIG_SPI_NRFX=y
    CONFIG_SENSOR=y
    CONFIG_I2C=y
    # LwM2M and IPSO
    CONFIG_LWM2M=y
    CONFIG_LWM2M_COAP_BLOCK_SIZE=1024
    CONFIG_LWM2M_COAP_MAX_MSG_SIZE=1280
    CONFIG_LWM2M_ENGINE_MAX_OBSERVER=40
    CONFIG_LWM2M_ENGINE_MAX_MESSAGES=40
    CONFIG_LWM2M_ENGINE_MAX_PENDING=40
    CONFIG_LWM2M_ENGINE_MAX_REPLIES=40
    CONFIG_LWM2M_ENGINE_STACK_SIZE=3072
    CONFIG_LWM2M_DNS_SUPPORT=y
    CONFIG_LWM2M_RW_JSON_SUPPORT=n
    CONFIG_LWM2M_CONN_MON_OBJ_SUPPORT=y
    CONFIG_LWM2M_CONN_MON_BEARER_MAX=2
    CONFIG_LWM2M_SERVER_DEFAULT_PMIN=0
    CONFIG_LWM2M_SERVER_DEFAULT_PMAX=0
    CONFIG_LWM2M_CLIENT_UTILS=y
    CONFIG_LWM2M_CLIENT_UTILS_FIRMWARE_UPDATE_OBJ_SUPPORT=y
    CONFIG_LWM2M_CLIENT_UTILS_LOCATION_OBJ_SUPPORT=n
    CONFIG_LWM2M_IPSO_SUPPORT=y
    CONFIG_COAP_INIT_ACK_TIMEOUT_MS=4000
    CONFIG_COAP_RANDOMIZE_ACK_TIMEOUT=n
    CONFIG_COAP_BACKOFF_PERCENT=100
    CONFIG_COAP_MAX_RETRANSMIT=4
    # UART
    # DTLS settings
    CONFIG_LWM2M_DTLS_SUPPORT=y
    # Modem key management
    CONFIG_MODEM_KEY_MGMT=y
    # Default app to debug logging
    CONFIG_LOG=y
    CONFIG_APP_LOG_LEVEL_DBG=y
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_APP_ENDPOINT_PREFIX="xxx-"
    # Support HEX style PSK values (double the size + NULL char)
    CONFIG_LWM2M_SECURITY_KEY_SIZE=33
    # extend CoAP retry timing to 10 seconds for LTE/LTE-M
    CONFIG_COAP_INIT_ACK_TIMEOUT_MS=10000
    # Enable CoAP extended option length
    CONFIG_COAP_EXTENDED_OPTIONS_LEN=y
    CONFIG_COAP_EXTENDED_OPTIONS_LEN_VALUE=40
    # Enable settings storage
    CONFIG_SETTINGS=y
    CONFIG_FCB=y
    CONFIG_SETTINGS_FCB=y
    CONFIG_FLASH_MAP=y
    CONFIG_STREAM_FLASH=y
    # LTE link control
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_LTE_NETWORK_MODE_LTE_M=y
    # Modem library
    CONFIG_NRF_MODEM_LIB=y
    # Modem info
    CONFIG_MODEM_INFO=y
    CONFIG_MODEM_INFO_ADD_DATE_TIME=n
    # Enable shell
    CONFIG_LWM2M_SHELL=y
    # Heap and stacks
    CONFIG_HEAP_MEM_POOL_SIZE=16384
    CONFIG_MAIN_STACK_SIZE=8192
    CONFIG_AT_MONITOR_HEAP_SIZE=512
    # Allow FOTA downloads using download-client
    CONFIG_DOWNLOAD_CLIENT=y
    CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
    CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024=y
    CONFIG_FOTA_DOWNLOAD=y
    # Application version
    CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="1.0.0"
    # Set LwM2M Server IP address here
    CONFIG_LWM2M_CLIENT_UTILS_SERVER="coap://qiotb.qlocx.com:5683"
    # Application Event Manager
    CONFIG_APP_EVENT_MANAGER=y
    # Date-Time library
    CONFIG_DATE_TIME=y
    CONFIG_DATE_TIME_UPDATE_INTERVAL_SECONDS=86400
    # Enable LwM2M Queue Mode
    CONFIG_LWM2M_QUEUE_MODE_ENABLED=y
    # Use DTLS Connection ID
    CONFIG_LWM2M_DTLS_CID=y
    CONFIG_LWM2M_RD_CLIENT_SUPPORT_BOOTSTRAP=y
    CONFIG_LWM2M_CLIENT_UTILS_BOOTSTRAP_TLS_TAG=100
    CONFIG_LWM2M_CLIENT_UTILS_SERVER_TLS_TAG=200
    # When DTLS CID is used, we can keep the socket open.
    # If the server is not supporting CID, CONFIG_LWM2M_RD_CLIENT_SUSPEND_SOCKET_AT_IDLE should
    # be used instead.
    CONFIG_LWM2M_RD_CLIENT_STOP_POLLING_AT_IDLE=y
    # Enable TLS session caching to prevent doing a full TLS handshake when recovering the session
    CONFIG_LWM2M_TLS_SESSION_CACHING=y
    # Sets the duration that the lwm2m engine will be polling for data after transmission before
    # the socket is closed.
    # Adjust so that we can detach from network in 30 seconds
    CONFIG_LWM2M_QUEUE_MODE_UPTIME=20
    # Set lifetime of 24 hours
    CONFIG_LWM2M_ENGINE_DEFAULT_LIFETIME=86400
    # This is same as DEFAULT_LIFETIME - QUEUE_MODE_UPTIME + 1
    CONFIG_LWM2M_SECONDS_TO_UPDATE_EARLY=86381
    # Configure PSM mode
    CONFIG_LTE_PSM_REQ=y
    # Request periodic TAU of 3600 seconds (60 minutes)
    CONFIG_LTE_PSM_REQ_RPTAU="00000110"
    # Set Requested Active Time (RAT) to 30 seconds. Preferably same as the
    # configured LWM2M_QUEUE_MODE_UPTIME. Due to NAT/firewall UDP connections are usually
    # closed within 30-60 seconds so there is in general no point in setting a longer
    # Queue mode uptime / LTE PSM active time.
    CONFIG_LTE_PSM_REQ_RAT="00001111"
    # Request eDRX mode
    CONFIG_LTE_EDRX_REQ=y
    # Requested eDRX cycle length for LTE-M and Nb-IoT
    # This should be fine-tuned for the network and the chosen server.
    # Lowest value is  the most responsive, but uses more energy during the active eDRX period.
    # Longer period may cause more CoAP packet drops on server requests.
    # "0000" is 5.12 s
    # "0001" is 10.24 s
    # "0010" is 20.48 s.
    CONFIG_LTE_EDRX_REQ_VALUE_LTE_M="0001"
    CONFIG_LTE_EDRX_REQ_VALUE_NBIOT="0000"
    # Request Paging time window of 1.28 seconds for LTE-M
    CONFIG_LTE_PTW_VALUE_LTE_M="0000"
    # Request Paging time window of 2.56 seconds for NB-IoT
    CONFIG_LTE_PTW_VALUE_NBIOT="0000"
    # Get notification before Tracking Area Update (TAU). Notification triggers registration
    # update and TAU will be sent with the update which decreases power consumption.
    CONFIG_LTE_LC_TAU_PRE_WARNING_NOTIFICATIONS=y
    CONFIG_PM_DEVICE=y
    CONFIG_TFM_LOG_LEVEL_SILENCE=y
    # Optimize powersaving by using tickless mode in LwM2M engine
    CONFIG_NET_SOCKETPAIR=y
    CONFIG_LWM2M_TICKLESS=y
    # Enable Release Assistance Indication
    #LwM2M v1.1 configure
    CONFIG_LWM2M_VERSION_1_1=y
    CONFIG_LWM2M_RW_OMA_TLV_SUPPORT=y
    CONFIG_LWM2M_COMPOSITE_PATH_LIST_SIZE=20
    #Enable SenML-JSON content format
    CONFIG_BASE64=y
    CONFIG_JSON_LIBRARY=y
    CONFIG_LWM2M_RW_SENML_JSON_SUPPORT=y
    #Enable SenML-CBOR content format
    CONFIG_LWM2M_RW_SENML_CBOR_SUPPORT=y
    CONFIG_LWM2M_RW_SENML_CBOR_RECORDS=55
    CONFIG_ZCBOR_CANONICAL=y
    # Enable below for modem trace
    # CONFIG_NRF_MODEM_LIB_TRACE=y
    # CONFIG_NRF_MODEM_LIB_TRACE_BACKEND_RTT=y
    # CONFIG_USE_SEGGER_RTT=y
    #CONFIG_NRF_MODEM_LIB_TRACE_LEVEL_LTE_AND_IP=y
    ################# WATCHDOG ################################
    CONFIG_WDT_LOG_LEVEL_DBG=y
    CONFIG_WATCHDOG=y
    CONFIG_WDT_DISABLE_AT_BOOT=y
    # CONFIG_LWM2M_RD_CLIENT_MAX_RETRIES=
  • > Try:
    >  # Default: true
    >  # DTLS.UPDATE_ADDRESS_USING_CID_ON_NEWER_RECORDS=true
    The more complete documentation is in the javadoc of DtlsConfig:
     * Update the ip-address from DTLS 1.2 CID records only for newer records
     * based on epoch/sequence_number.
     * @see <a href= "">www.rfc-editor.org/.../rfc9146.html
     *      target= "_blank">RFC 9146, Connection Identifiers for DTLS 1.2, 6.
     *      Peer Address Update</a>
    In general all CID record will update the address of the DTLS context. (If leshan is using that as well, is out of my scope). But assuming, that records may be received in inverse order, it may cause to update to a deprecated address. This setting therefore updates the address only for the newest record according the dtls record sequence number. In the very, very most cases it doesn't make a difference (because the record order doesn't change that frequently nor will the address change that fast), and it is already on per default.
    Therefore I recommend to ask the leshan project, how they set that up. For Californium on it's own, it's required, because the default there is for v3. "off".
