modem_key_mgmt_cmp() triggers modem firmware memory management fault
I am running the Dev Academy Lesson 4 Exercise 2 - MQTT with TLS and getting the error:
    [00:00:00.650,085] <err> nrf_modem: Modem has crashed, reason 0x4, PC: 0xecb64
I see that is a modem firmware memory management fault. The first time I built and flashed the program, it worked fine. When I reset the system, I started seeing the error. I've erased the flash, done "west flash --recovery", and cycled power. All give the same result.
A bit of debugging shows the error gest triggered from within the call to modem_key_mgmt_cmp(). Specifically, the call to key_fetch(sec_tag, cred_type) returns -110; I suspect this underlying cause. If I comment out the code that calls modem_key_mgmt_exists() and modem_key_mgmt_cmp(), thus always writing the certificate to the modem, the application works fine.
I'm using a nRF9160 DK and SDK v2.6.1.
Rick
  • I can try a modem trace, but I don't think it will show anything. The memory fault occurs before I turn the modem online. The sequence that causes the error is:
    1. nrf_modem_lib_init()
    2. modem_key_mgmt_exists() - this returns true
    3. modem_key_mgmt_cmp() - this triggers the error
    4. modem_key_mgmt_write()
    5. lte_lc_connect_async()
    If I comment out steps 2-3, I do not get the memory fault error.
  • The logged error from the library is:
    This simple program reproduces the problem:
     * Copyright (c) 2018 Nordic Semiconductor ASA
    #include <stdio.h>
    #include <ncs_version.h>
    #include <zephyr/kernel.h>
    #include <zephyr/net/socket.h>
    #include <zephyr/net/mqtt.h>
    #include <dk_buttons_and_leds.h>
    #include <modem/nrf_modem_lib.h>
    #include <modem/lte_lc.h>
    #include "mqtt_connection.h"
    #include <modem/modem_key_mgmt.h>
    #include "certificate.h"
    LOG_MODULE_REGISTER(MemFaultKeyMgmt, LOG_LEVEL_INF);
    static int modem_configure(void)
    	int err;
    	LOG_INF("Initializing modem library");
    	err = nrf_modem_lib_init();
    	if (err) {
    		LOG_ERR("Failed to initialize the modem library, error: %d", err);
    		return err;
    	LOG_INF("Modem library initialized");
    	/* STEP 4.3 - Store the certificate in the modem while the modem is in offline mode  */
    	bool exists;
    	err = modem_key_mgmt_exists(CONFIG_MQTT_TLS_SEC_TAG,
    				    MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN,
    				    &exists);
    	if (err) {
    		LOG_ERR("Failed to check for certificates err %d\n", err);
    		return err;
    	if (exists) {
    		/* Let's compare the existing credential */
    		err = modem_key_mgmt_cmp(CONFIG_MQTT_TLS_SEC_TAG,
    					 CA_CERTIFICATE,
    					 strlen(CA_CERTIFICATE));
    		LOG_INF("%s\n", err ? "mismatch" : "match");
    		if (!err) {
    			return 0;
    	return err;
    	int err;
    	err = modem_configure();
    	if (err) {
    		LOG_ERR("Failed to configure the modem");
    		return 0;
    	// After some milliseconds, the modem library sends the memory management fault,
    	// <err> nrf_modem: Modem has crashed, reason 0x4, PC: 0xecb64
    	while (1) {
    		k_msleep(5);
    	/* This is never reached */
    	return 0;
  • Your issue is most likely related to a known bug. There will be a fix for this in future releases.
