I have the structure for a Vesper VM3011 MEMS microphone:
struct vm3011_config
const struct device *i2c_dev;
uint16_t i2c_address;
gpio_pin_t data_pin;
gpio_pin_t clk_pin;
bool lr_pin_level;
#if defined(CONFIG_VM3011_INT)
const char *gpio_port;
gpio_pin_t dout_pin;
gpio_dt_flags_t dout_flags;
In the 'overlay' file, I define it as hardware:
&i2c1 {
clock-frequency = <I2C_BITRATE_FAST>;
vm3011: vm3011@60 {
compatible = "i2c-device";
label = "VM3011";
reg = <0x60>;
clk-pin = <41>;
data-pin = <27>;
dout-gpios = <&gpio0 25 GPIO_ACTIVE_HIGH>;
chosen {
zephyr,console = &cdc_acm_uart0;
zephyr,shell-uart = &cdc_acm_uart0;
nordic,pm-ext-flash = &mx25r64;
aliases {
mic0 = &i2c1;
When I retrieve the properties from the '.c' file in this way:
static const struct vm3011_config vm3011_cfg = {
.i2c_dev = DEVICE_DT_GET(DT_ALIAS(mic0)),
.i2c_address = DT_INST_REG_ADDR(0),
.data_pin = DT_INST_PROP(0, data_pin),
.clk_pin = DT_INST_PROP(0, clk_pin),
.lr_pin_level = DT_INST_PROP(0, lr_select),
//.gpio_port = DT_INST_GPIO_LABEL(0, dout_gpios),
.dout_pin = DT_INST_GPIO_PIN(0, dout_gpios),
.dout_flags = DT_INST_GPIO_FLAGS(0, dout_gpios),
I encounter several compilation errors, so I have to retrieve them like this:
.i2c_address = (uint16_t)DT_REG_ADDR(DT_ALIAS(mic0)),
.data_pin = 27,
.clk_pin = 41,
.lr_pin_level = true,
.gpio_port = "gpio0",
.dout_pin = 25,
.dout_flags = GPIO_ACTIVE_HIGH,
This compiles, but I don't like hardcoding values in such an absolute way.
I believe these are Zephyr deprecations, but I cannot find relevant documentation.
Can you help me understand what's going on?
sdk 2.6.1 toolchain 2.7.0
Thank you.
BABOS
