NRF52H20 Connection issue
I have started working with the NRF52H20 by following the guidelines mentioned in the nRF Connect SDK Fundamentals course.
In Lesson1 Exercise2 I'm facing following issue
I am using a B-type data cable to connect the NRF52H20 board to the laptop via the J2 pin. In the Visual Studio Code, it initially shows that no device is connected and the LED5 on the board blinks continuously for every 500ms(approximately). Occasionally, the device connects, and the PC notifies me of this. In Visual Studio Code, the connected device then shows up my board details and the LED5 stays in on state.
However, sometimes during the building or flashing process, the device disconnects, and the previous state (blinking LED5 with no device detected) occurs again. This pattern repeats, and I haven't been able to identify the actual cause. Due to this issue, I haven't been able to proceed further.
I am trying to use the following example code: the directory path is as follows:
  • Create a new application.
  • Copy a sample.
  • Blink LED (PWM-based).
(1) Build configuration
(2) Device is connected
(3) In the below picture during the flash operation the device got disconnected
  • Hi Priyanka,
    For nRF52840DK the issue is resolved. I'm able to connect and flash the code.
    • The following are the changes that I have performed
                     SW9 Pin - Set at VDD
                     SW10 Pin - Set as OFF
    •  Please let me know the technical reason for above mentioned settings, as I'm not very sure about it.
    • But I'm unable to resolve the issue for nRF54H20DK, please let me know
    • Refer attached picture.
    According to your previous reply
    •  Faulty cable - Tried with other working cables and another PC
    • J-Link version - V7.94e
    • nRF Command Line Tools - nrf-command-line-tools-10.24.2-x64
    • sometimes when it does not show up in VSCode, do you still see your device in you PC - NO
    Hence, nRF54H20 is not connecting and nRF52840 is connected after performing few settings on hardware.
    Thank you.
    This is how it should be.
    Is this picture when the nRF54H20 is connected?
    Is it shown in the Connected Devices then?
    Could you show me what the 5 problems are in the problems window?
    -Priyanka
  • The attached picture is of nRF52840DK now I'm able to connect and flash the code.
    For the nRF54H20DK, no device details are found even when the device is connected. Give a solution for it.
