nRF5340 FOTA over BLE issue
Iam using nRF5340 DK and nRF Connect SDK V.2.6.1.
Iam following the link
FOTA over BLE
In this one until 5th step it worked fine and while doing 6th step it is showing error
Here Iam using peripheral lbs example
Then I add MCUboot and fota over bluetooth low energy to the application and add an extra print to the main to generate a new file for dfu
Then update the firmware using device manager app and it worked
Then I tried simultaneous updates for both cores
For this I added step 6 procedures
After adding the line CONFIG_UPDATEABLE_IMAGE_NUMBER=2 it is showing the errors
failed: "Missing partitions?"
87 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG)
 BUILD_ASSERT(FIXED_PARTITION_EXISTS(SLOT2_PARTITION) &&
CMake Warning at B:/Nordic/v2.6.1/nrf/cmake/partition_manager.cmake:79 (message):
CMake Warning at B:/Nordic/v2.6.1/nrf/modules/mcuboot/CMakeLists.txt:382 (message):
BT_MAX_CONN set more than once. Old value "16", new value "10".
CMake Warning at B:/Nordic/v2.6.1/nrf/subsys/bootloader/cmake/debug_keys.cmake:36 (message):
CMake Warning at B:/Nordic/v2.6.1/zephyr/CMakeLists.txt:1957 (message):
Kindly help me to find a solution for this
Thankyou
    Thanks for the reply
    2146.peripheral_lbs_1.zip
    After adding this also it is showing errors
    error: 'PM_MCUBOOT_PRIMARY_1_ID' undeclared (first use in this function); did you mean 'PM_MCUBOOT_PRIMARY_ID'?
    48 | #define FLASH_AREA_IMAGE_1_SLOTS PM_MCUBOOT_PRIMARY_1_ID, PM_MCUBOOT_SECONDARY_1_ID
    B:/Nordic/v2.6.1/bootloader/mcuboot/boot/zephyr/include/sysflash/pm_sysflash.h:55:29: note: in expansion of macro 'FLASH_AREA_IMAGE_1_SLOTS'
    55 | FLASH_AREA_IMAGE_1_SLOTS
    error: 'PM_MCUBOOT_SECONDARY_1_ID' undeclared (first use in this function); did you mean 'PM_MCUBOOT_SECONDARY_ID'?
    error: static assertion failed: "Missing partitions?"
    Thankyou the example code you given worked well.
    1) But when I update both cores in nRF connect device manager app it is only working by giving      "Confirm only" option, other options are not working. Why these options are not working?
    2) In my requirement I want to update both application core and network core . In the tutorial I have a concern that until 5th step only the application core is changing or both cores are changing?
    3) I want to implement FOTA in my custom nRF5340 BLE project. Can I follow the steps in the          tutorial, or do I need to add any additional files?
    Thankyou
    Simultaneous multi-image DFU on the nRF53 does not support reverting images (i.e. revert back to the original FW version if the image was not confirmed). Therefore, it should not make any difference if you mark the update for 'test' or 'confirm'.
    Both cores will be updated if you upload the dfu_application.zip.
    The tutorial also applies to custom boards.
