how to use cURL with TLS implementation
Hello
I'm evaluating cURL with nrf9160DK,zephyrOS.
Finally, it goes well with cURL - http - however, it cant do with TLS - https -
Could you let me know how to implement TLS/SSL for using cURL ?
Does it require some config ?
Here is my snipet code. (non - TLS)
static size_t write_callback(void *contents, size_t size, size_t nmemb, void *userp) {
size_t realsize = size * nmemb;
char **response_ptr = (char **)userp; // Cast userp to the correct type
char *response = realloc(*response_ptr, strlen(*response_ptr) + realsize + 1);
if (response == NULL) {
LOG_ERR("Not enough memory to store response\n");
return 0; // If realloc fails, return 0 to stop curl
*response_ptr = response;
strncat(response, (char *)contents, realsize);
return realsize;
static void http_request_example(void) {
CURL *hnd;
CURLcode ret;
char *response = malloc(4096); // Allocate initial memory for the response
LOG_ERR("Memory allocation failed for response buffer");
return;
response[0] = '\0'; // Initialize the response buffer
LOG_INF("Starting HTTP request example");
// Initialize libcurl
hnd = curl_easy_init();
if (hnd) {
// Set the URL for the HTTP GET request
curl_easy_setopt(hnd, CURLOPT_URL, "">http://httpbin.org/get");
// Set the callback function for handling response data
curl_easy_setopt(hnd, CURLOPT_WRITEFUNCTION, write_callback);
curl_easy_setopt(hnd, CURLOPT_WRITEDATA, (void *)&response);
#if 1
curl_version_info_data *curl_info = curl_version_info(CURLVERSION_NOW);
if (curl_info->protocols) {
const char * const *proto;
for (proto = curl_info->protocols; *proto; ++proto) {
LOG_INF("Supported protocol: %s\n", *proto);
// Perform the request
ret = curl_easy_perform(hnd);
// Check if the request was successful
if (ret != CURLE_OK) {
LOG_ERR("curl_easy_perform() failed: %s", curl_easy_strerror(ret));
} else {
// Print the response
LOG_INF("Response: %s", response);
// Clean up and free the resources
curl_easy_cleanup(hnd);
free(response);
} else {
LOG_ERR("Failed to initialize curl");
  • Updated my code and however, still no work well.
    Return - http
    >>curl_easy_perform() failed: Unsupported protocol
    how to integrated SSL/TLS ?
    here is the snipet code
    static void https_request_example(void) {
    CURL *ch;
    CURLcode ret;
    return;
    LOG_INF("Starting HTTPS request example");
    /* Dynamically allocate memory for the PEM certificate */
    char *mypem = (char *)malloc(strlen(cert_pem) + 1);
    if (!mypem) {
    printf("malloc failed for PEM certificate\n");
    return CURLE_OUT_OF_MEMORY;
    strcpy(mypem, cert_pem);
    curl_global_init(CURL_GLOBAL_ALL);
    ch = curl_easy_init();
    if (ch) {
    curl_easy_setopt(ch, CURLOPT_SSLCERTTYPE, "PEM");
    curl_easy_setopt(ch, CURLOPT_SSL_VERIFYPEER, 1L);
    curl_easy_setopt(ch, CURLOPT_URL, "">https://www.example.com/");
    /* Install the function to modify the SSL context */
    curl_easy_setopt(ch, CURLOPT_SSL_CTX_FUNCTION, *sslctx_function);
    curl_easy_setopt(ch, CURLOPT_SSL_CTX_DATA, mypem);
    curl_easy_setopt(ch, CURLOPT_WRITEFUNCTION, write_callback);
    curl_easy_setopt(ch, CURLOPT_WRITEDATA, (void *)&response);
    #if 1
    ret = curl_easy_perform(ch);
    } else {
    curl_easy_cleanup(ch);
    free(response);
    } else {
    /* Clean up */
    curl_global_cleanup();
    free(mypem); /* Free dynamically allocated memory */
    free(response);
    return ret;
  • Hello
    Still not going well and I'm looking for solution.
    Any idea and advice would be highly appreciated.
    thx
    Michal is currently out of office and I have been assigned his ticket while he is out.
    s-shige said:
    That means this is not support ?
    Yes, there is currently no support for cURL and HTTPS in our nRF Connect SDK. The cURL library in our SDK was introduced for our Cellular: Modem shell sample.
    Øyvind
  • Hello
    Thank you for your update.
    I can confirm cURL (without TLS) is available.
    but, need "CONFIG_NET_SOCKETS_POSIX_NAMES=n" so, some hand craft to implement socket function with zepher API.
    Anyway, TLS(mbedTLS) is not supported for now, I understand.
    We have often request about this feature support from customers.
    so, I hope it will support shortly.
    thx
  • If you are able to provide a list of how many that asks about this, we can forward this as a feature request.
    Øyvind
  • Hello
    We have a few customers that using Nordic.
    That kind point of view regarding your chip product will be some volume of K, M numbers.
    thx
