nreset 0.18 disable
I have a customized PCB with nrf52840. Pin 0.18 is used as CS pin in SPI communication.
I want to disable the nreset function and I add this CONFIG_GPIO_AS_PINRESET=n in .conf file
When I click flash it still shows
[ ###### ] 0.000s | Program file - Checking image [ ##### ] 0.000s | Check image validity - Initialize device info [ ########## ] 0.000s | Check image validity - Check region 0 settings [ ############### ] 0.000s | Check image validity - block 1 of 2 [ #################### ] 0.006s | Check image validity - Finished [ ############# ] 0.000s | Program file - Programming [ ########## ] 0.000s | Programming image - block 1 of 1 [ #################### ] 0.000s | Programming image - Write successful [ #################### ] 0.248s | Program file - Done programming
[ ###### ] 0.000s | Verify file - Check image [ ##### ] 0.000s | Check image validity - Initialize device info [ ########## ] 0.000s | Check image validity - Check region 0 settings [ ############### ] 0.115s | Check image validity - block 1 of 2 [ #################### ] 0.006s | Check image validity - Finished [ ############# ] 0.000s | Verify file - Verifying [ ########## ] 0.000s | Verifying image - block 1 of 1 [ #################### ] 0.000s | Verifying image - Verify successful [ #################### ] 0.255s | Verify file - Done verifying
Enabling pin reset.
Applying pin reset.
I read across the platform and I found someone mentioned NCIR and some mentioned system_nrf52840.c but those answers are more than 1 years ago so I am not sure whether those are relevant.
I am using J-LINK for flash and printk though RTT.
What else I need to add after adding CONFIG_GPIO_AS_PINRESET=n ?
