How to generate full thread stack trace to log on crash
Using Zephyr (cf2149caf2) / nrfSDKConnect on a nrf5340DK board.
I need to know how to get a direct stack trace (with file/line numbers if possible for a debug build).
Currently I only get this type of log output:
[00:51:03.271,972] <err> os: ***** BUS FAULT *****
[00:51:03.277,435] <err> os: Precise data bus error
[00:51:03.283,172] <err> os: BFAR Address: 0x0
[00:51:03.288,482] <err> os: r0/a1: 0x00000000 r1/a2: 0x00033050 r2/a3: 0x00000064
[00:51:03.297,210] <err> os: r3/a4: 0x00000000 r12/ip: 0x00000000 r14/lr: 0x000280cb
[00:51:03.305,877] <err> os: xpsr: 0x61000000
[00:51:03.311,126] <err> os: Faulting instruction address (r15/pc): 0x00030804
[00:51:03.319,030] <err> os: >>> ZEPHYR FATAL ERROR 25: Unknown error on CPU 0
[00:51:03.326,965] <err> os: Current thread: 0x20003990 (unknown)
Finding the function that is related to the instruction address using the build/zephyr/zephyr.map is simple enough, but generally not useful (eg here its in strcpy()...).
Is there a way to get the fault handler to dump the full stack for the active thread? This would be very useful in release code to generate a useful error report (where one can't just attach the debugger!)
(I can get a full core dump, but this is too large for easy recovery in a log, and doesn't give a stack unwind trace directly either)
I see other questions about this on the forum, but haven't seen an answer that provides the stack trace...
  • I compile with CONFIG_DEBUG=y, CONFIG_DEBUG_INFO=y, and I see the -Og in the gcc options.
    Normally the hardfault handler unwinds the last stack frame for you and gives you detail of the instruction causing fault.
    Do you mean that you see a full call stack? or just the instruction pointer for the function with the fault (which is not helpful if its strlen or sprintf!)
    I'm looking for something like:
    fault @ strlen, called by sprintf, called by my_code_fn, called by my_other_fn, called by task_my_thread.
    Even if the function names are not printed but only the addresses....
    btw, addr2line gave me nothing:
    C:\work\dev\if-device-nrf53>arm-none-eabi-addr2line -e cc1-med/build/zephyr/zephyr.elf -a 0x3fda3
    0x0003fda3
     But a find in the cc1-med/build/zephyr/zephyr.map works to find the function for the address.... just not so scriptable...
    No, the fault handler does not give the full call trace like gdb does. for getting a context function call trace, I start the debugger and set the breakpoint in the hardfault handler. If everything goes right and if the stack memory is not corrupted, then some of the IDE's debuggers show the call trace or setup GDB session if that is your preference.
    0x0003fda3
    Hmm, try to add "-f" option to attempt to get function names.
  • No, the fault handler does not give the full call trace like gdb does. for getting a context function call trace, I start the debugger and set the breakpoint in the hardfault handler. If everything goes right and if the stack memory is not corrupted, then some of the IDE's debuggers show the call trace or setup GDB session if that is your preference.
    Ok.
    Does this means there is definitively no way to get a call trace in the firmware itself?
  • Seems that way. There is this config CONFIG_EXCEPTION_STACK_TRACE but I tried to test this with the blinky sample but it does not give any additional functional call trace. I see that this config have additional handling on RISC5 and X86 based fault handling code, so probably it is missing handling on ARM Cortex cores.
    additional prj.conf I included to test this
    CONFIG_DEBUG_INFO=y
    CONFIG_EXCEPTION_STACK_TRACE=y
    CONFIG_ASSERT_ON_ERRORS=y
    CONFIG_ASSERT=y
    CONFIG_LOG=y
    CONFIG_RESET_ON_FATAL_ERROR=n
