nRF Connect SDK child image per-board configuration discards associated prj.conf in 2.6.1
When building a project using a custom board, as well as both the b0 and mcuboot bootloaders enabled, board-specific child image configuration causes the build system to ignore the project-specific configuration.
I'm using the following directory structure:
<wk> - Workspace directory
<wk>/<prj> - Project directory
<wk>/<prj>/prj.conf - Core project configuration
<wk>/<prj>/build - Builds
<wk>/<prj>/boards - Boards
<wk>/<prj>/boards/arm/<example>/ - a copy of the nrf5340dk configuration, renamed to something other than nrf5340dk to test if the build system handles custom boards differently than in-tree boards
<wk>/<prj>/child_image/b0/boards/<example>_cpuapp.conf
core project configuration includes the following:
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_SECURE_BOOT=y
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
The file <wk>/<prj>/child_image/b0/boards/<example>_cpuapp.conf must contain the contents of <wk>/nrf/samples/bootloader/prj.conf and <wk>/nrf/samples/bootloader/boards/nrf5340dk_nrf5340_cpuapp.conf or it will fail to build.
This relates to https://docs.nordicsemi.com/bundle/ncs-2.6.1/page/nrf/config_and_build/multi_image.html#permanent_configuration_changes_to_child_images
and  Compile ERROR "undefined reference to `sys_clock_cycle_get_32'" with custom board
  • This is bizarre.... I made a new workspace to test.  Quick answer is yours works and I have no idea why.
    You don't have a west.yml... so I created the following one:
    manifest:
      remotes:
        - name: ncs
          url-base: https://github.com/nrfconnect
      projects:
        - name: nrf
          import: true
          remote: ncs
          repo-path: sdk-nrf
          revision: v2.6.1
    Setup a fresh workspace with west update --narrow -o=--depth=1 to keep things small
    Build targeting nrf5340dk_nrf5340_cpuapp_ns worked and picked up things correctly.
    Merged configuration '<wk3>/peripheral_lbs_w_dfu/child_image/b0/prj.conf'
    Merged configuration '<wk3>/peripheral_lbs_w_dfu/child_image/b0/boards/nrf5340dk_nrf5340_cpuapp.conf'
    Merged configuration '<wk3>/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Merged configuration '<wk3>/peripheral_lbs_w_dfu/build/b0/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to '<wk3>/peripheral_lbs_w_dfu/build/b0/zephyr/.config'
    Trying with <wk3>/peripheral_lbs_w_dfu and custom_* works fine
    Trying with <wk3>/example/peripheral_lbs_w_dfu2 and custom_* works fine.
    So far I have no idea why there's a difference...
  • Copying my board files into your project in the new workspace picks things up correctly... I'm able to build for my board.
    It's gotta be something about the workspace itself.  I'm going to see if reconstructing things from scratch again helps...
  • This appears to be a caching issue with vscode.  I was able to get a workspace that was failing to pick prj.conf up to pick it up by changing the setting for Configuration to "prj.conf" instead of "Use build system default" when adding a build configuration.
    This was after cloning into a new workspace and everything.  The way vscode caches configuration it has detected is surprising.  Clearing out the automatically generated cmake arguments isn't always sufficient, and deleting a configuration file can break a build.  Seems like this is related to that.
  • That's strange. I don't recall seeing or hearing about this before. Do you notice any differences in the cached configuration when it fails versus when it works?
  • I'll clarify... the behavior implies I do not fully understand where things are being cached because the places I'm looking appear to be a symptom, not a cause.
    In vscode, if I've built and I try to adjust .conf files, I find extra cmake arguments populated under "edit build configuration" that I often need to clear out. Failing to do so causes the build to fail because the conf files have been intentionally removed.
    If there is another place where the cache is editable, I'm not aware of it.
    Saving the build config as a preset shows mismatches from expectation with both the failing and the updated workspace.
    <wk failing> is missing child_image/b0/prj.conf under b0_CONF_FILE
    <wk working> is missing boards/<example>.conf under CACHED_CONF_FILE
