download demo can't work
Hi
    I'm testing downloading a file from AWS S3 using ncs but it's not working well. I'm getting an error called -116 Connection timed out.
    I also used another client to connect and it was not able to connect. I used the IP and port from the logs.
    Can you give me some advice, thanks.
ncs: ncs2.7.0
sample: v2.7.0\nrf\samples\net\download    only build and download
board: nRF7002-DK
log
error position
    That is also using the amazon root CA, so there should not be a problem with the certificate chain.
    This worked on my end (please note: I have no ipv6 connectivity at my end):
    *** Using Zephyr OS v3.6.99-100befc70c74 ***
    Download client sample started
    Provisioning certificate
    CA certificate already exists, sec tag: 42
    Connecting to network
    [00:00:02.193,176] <inf> wifi_mgmt_ext: Connection requested
    IP Up
    Network connected
    [00:00:10.297,882] <dbg> download_client: set_state: state = 1
    [00:00:10.297,912] <inf> download_client: Downloading: https://minewsemi-s3-test.s3.amazonaws.com/1.png [0]
    Downloading https://minewsemi-s3-test.s3.amazonaws.com/1.png
    [00:00:10.298,309] <dbg> download_client: client_connect: Port not specified, using default: 443
    [00:00:10.298,431] <dbg> download_client: host_lookup: Failed to resolve hostname minewsemi-s3-test.s3.amazonaws.com on IPv6
    [00:00:10.369,781] <dbg> download_client: client_socket_connect: family: 1, type: 1, proto: 258
    [00:00:10.370,483] <inf> download_client: Setting up TLS credentials, sec tag count 1
    [00:00:10.370,574] <inf> download_client: Connecting to 52.217.235.201
    [00:00:10.370,605] <dbg> download_client: client_socket_connect: fd 14, addrlen 8, fam IPv4, port 443
    [00:00:12.954,345] <dbg> download_client: set_state: state = 2
    [00:00:12.954,498] <dbg> download_client: http_get_request_send: HTTP request
                                              47 45 54 20 2f 31 2e 70  6e 67 20 48 54 54 50 2f |GET /1.p ng HTTP/
                                              31 2e 31 0d 0a 48 6f 73  74 3a 20 6d 69 6e 65 77 |1.1..Hos t: minew
                                              73 65 6d 69 2d 73 33 2d  74 65 73 74 2e 73 33 2e |semi-s3- test.s3.
                                              61 6d 61 7a 6f 6e 61 77  73 2e 63 6f 6d 0d 0a 52 |amazonaw s.com..R
                                              61 6e 67 65 3a 20 62 79  74 65 73 3d 30 2d 34 30 |ange: by tes=0-40
                                              39 35 0d 0a 43 6f 6e 6e  65 63 74 69 6f 6e 3a 20 |95..Conn ection:
                                              6b 65 65 70 2d 61 6c 69  76 65 0d 0a 0d 0a       |keep-ali ve....
    [00:00:12.956,024] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:13.146,789] <dbg> download_client: handle_received: Read 439 bytes from socket
    [00:00:13.146,911] <dbg> download_client: http_header_parse: GET header size: 439
    --- 1 messages dropped ---
    [00:00:13.147,155] <dbg> download_client: http_header_parse: File size = 966
    [00:00:13.147,705] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:13.153,228] <dbg> download_client: handle_received: Read 966 bytes from socket
    [00:00:13.153,259] <inf> download_client: Downloaded 966/966 bytes (100%)
    [ 100% ] |==================================================| (966/966 bytes)[00:00:13.153,869] <inf> download_client: Download complete
    Download completed in 2856 ms @ 338 bytes per sec, total 966 bytes
    Bye
    [00:00:13.168,304] <dbg> download_client: set_state: state = 4
    [00:00:13.174,468] <dbg> download_client: set_state: state = 0
    Socket closed
    [00:00:13.174,499] <dbg> download_client: download_thread: Connection closed
    IP down
    Disconnected from network
    Håkon
    I do not see any issues with the default link:
    *** Booting nRF Connect SDK v2.7.0-5cb85570ca43 ***
    [00:00:04.733,184] <inf> wifi_mgmt_ext: Connection requested
    IP Up
    Network connected
    [00:00:15.706,146] <dbg> download_client: set_state: state = 1
    [00:00:15.706,176] <inf> download_client: Downloading: https://nrfconnectsdk.s3.eu-central-1.amazonaws.com/sample-img-100kb.png [0]
    Downloading https://nrfconnectsdk.s3.eu-central-1.amazonaws.com/sample-img-100kb.png
    [00:00:15.706,573] <dbg> download_client: client_connect: Port not specified, using default: 443
    [00:00:15.706,726] <dbg> download_client: host_lookup: Failed to resolve hostname nrfconnectsdk.s3.eu-central-1.amazonaws.com on IPv6
    [00:00:15.853,240] <dbg> download_client: client_socket_connect: family: 1, type: 1, proto: 258
    [00:00:15.853,942] <inf> download_client: Setting up TLS credentials, sec tag count 1
    [00:00:15.854,034] <inf> download_client: Connecting to 52.219.47.156
    [00:00:15.854,095] <dbg> download_client: client_socket_connect: fd 14, addrlen 8, fam IPv4, port 443
    [00:00:16.678,802] <dbg> download_client: set_state: state = 2
    [00:00:16.678,955] <dbg> download_client: http_get_request_send: HTTP request
                                              47 45 54 20 2f 73 61 6d  70 6c 65 2d 69 6d 67 2d |GET /sam ple-img-
                                              31 30 30 6b 62 2e 70 6e  67 20 48 54 54 50 2f 31 |100kb.pn g HTTP/1
                                              2e 31 0d 0a 48 6f 73 74  3a 20 6e 72 66 63 6f 6e |.1..Host : nrfcon
                                              6e 65 63 74 73 64 6b 2e  73 33 2e 65 75 2d 63 65 |nectsdk. s3.eu-ce
                                              6e 74 72 61 6c 2d 31 2e  61 6d 61 7a 6f 6e 61 77 |ntral-1. amazonaw
                                              73 2e 63 6f 6d 0d 0a 52  61 6e 67 65 3a 20 62 79 |s.com..R ange: by
                                              74 65 73 3d 30 2d 34 30  39 35 0d 0a 43 6f 6e 6e |tes=0-40 95..Conn
                                              65 63 74 69 6f 6e 3a 20  6b 65 65 70 2d 61 6c 69 |ection:  keep-ali
                                              76 65 0d 0a 0d 0a                                |ve....
    [00:00:16.680,450] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:16.772,094] <dbg> download_client: handle_received: Read 406 bytes from socket
    [00:00:16.772,369] <dbg> download_client: http_header_parse: GET header size: 406
    [00:00:16.772,613] <dbg> download_client: http_header_parse: File size = 102923
    [00:00:16.773,132] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:16.943,145] <dbg> download_client: handle_received: Read 4096 bytes from socket
    [00:00:16.943,145] <inf> download_client: Downloaded 4096/102923 bytes (3%)
    [   3% ] |=                                                 | (4096/102923 bytes)[00:00:16.943,908] <dbg> download_client: http_get_reqt
                                              74 65 73 3d 34 30 39 36  2d 38 31 39 31 0d 0a 43 |tes=4096 -8191..C
                                              6f 6e 6e 65 63 74 69 6f  6e 3a 20 6b 65 65 70 2d |onnectio n: keep-
                                              61 6c 69 76 65 0d 0a 0d  0a                      |alive... .
    [00:00:16.945,434] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:17.019,317] <dbg> download_client: handle_received: Read 409 bytes from socket
    --- 13 messages dropped ---
    [00:00:17.019,439] <dbg> download_client: http_header_parse: GET header size: 409
    [00:00:17.020,111] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:17.128,387] <dbg> download_client: handle_received: Read 1529 bytes from socket
    [00:00:17.128,417] <dbg> download_client: download_thread: Receiving up to 2567 bytes at 0x2000d22d...
    [00:00:17.190,124] <dbg> download_client: handle_received: Read 2567 bytes from socket
    --- 21 messages dropped ---
    [00:00:17.190,124] <inf> download_client: Downloaded 8192/102923 bytes (7%)
    [   7% ] |===              [00:00:17.190,887] <dbg> download_client: http_get_request_send: HTTP request
                                              74 65 73 3d 38 31 39 32  2d 31 32 32 38 37 0d 0a |tes=8192 -12287..
                                              43 6f 6e 6e 65 63 74 69  6f 6e 3a 20 6b 65 65 70 |Connecti on: keep
                                              2d 61 6c 69 76 65 0d 0a  0d 0a                   |-alive.. ..
    --- 52 messages dropped ---
    [00:00:17.192,382] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:17.269,165] <dbg> download_client: handle_received: Read 410 bytes from socket
    [00:00:17.269,287] <dbg> download_client: http_header_parse: GET header size: 410
       | (12288/102923 bytes)[00:00:17.445,190] <dbg> download_client: http_get_request_send: HTTP request
                                              74 65 73 3d 31 32 32 38  38 2d 31 36 33 38 33 0d |tes=1228 8-16383.
                                              0a 43 6f 6e 6e 65 63 74  69 6f 6e 3a 20 6b 65 65 |.Connect ion: kee
                                              70 2d 61 6c 69 76 65 0d  0a 0d 0a                |p-alive. ...
    [00:00:17.446,685] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:17.514,923] <dbg> download_client: handle_received: Read 411 bytes from socket
    [00:00:17.515,045] <dbg> download_client: http_header_parse: GET header size: 411
    [00:00:17.515,808] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:17.689,453] <dbg> download_client: handle_received: Read 4096 bytes from socket
    [00:00:17.689,483] <inf> download_client: Downloaded 16384/102923 bytes (15%)
    [  15% ] |--- 2 messages dropped ---
    =======                                         | (16384/102923 bytes)[00:00:17.690,490] <dbg> download_client: http_get_request_send: t
                                              74 65 73 3d 31 36 33 38  34 2d 32 30 34 37 39 0d |tes=1638 4-20479.
    [00:00:17.691,986] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    --- 22 messages dropped ---
    [00:00:17.773,956] <dbg> download_client: handle_received: Read 411 bytes from socket
    [00:00:17.774,078] <dbg> download_client: http_header_parse: GET header size: 411
    [00:00:17.774,749] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:17.941,619] <dbg> download_client: handle_received: Read 4096 bytes from socket
    [00:00:17.941,619] <inf> download_client: Downloaded 20480/102923 bytes (19%)
    [  19% ] |=--- 12 messages dropped ---
    =====                [00:00:18.019,683] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:18.130,096] <dbg> download_client: handle_received: Read 1526 bytes from socket
    [00:00:18.130,096] <dbg> download_client: download_thread: Receiving up to 2570 bytes at 0x2000d22a...
    [00:00:18.198,394] <dbg> download_client: handle_received: Read 2570 bytes from socket
    [00:00:18.198,425] <inf> download_client: Downloaded 24576/102923 bytes (23%)
    [  23% ] |===========                                       | (24576/102923 bytes)[00:00:18.199,279] <dbg> download_client: http_get_ret
                                              74 65 73 3d 32 34 35 37  36 2d 32 38 36 37 31 0d |tes=2457 6-28671.
    [00:00:18.200,775] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:18.278,656] <dbg> download_client: handle_received: Read 411 bytes from socket
    [00:00:18.278,778] <dbg> download_client: http_header_parse: GET header size: 411
    [00:00:18.279,510] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:18.281,585] <dbg> download_client: handle_received: Read 502 bytes from socket
    [00:00:18.281,616] <dbg> download_client: download_thread: Receiving up to 3594 bytes at 0x2000ce2a...
    [00:00:18.483,978] <dbg> download_client: handle_received: Read 3594 bytes from socket
    --- 9 messages dropped ---
    [00:00:18.484,008] <inf> download_client: Downloaded 28672/102923 bytes (27%)
    [  27% ] |=============                            | (28672/102923 bytes)[00:00:18.484,771] <dbg> download_client: http_get_request_sent
                                              74 65 73 3d 32 38 36 37  32 2d 33 32 37 36 37 0d |tes=2867 2-32767.
    [00:00:18.486,267] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:18.564,117] <dbg> download_client: handle_received: Read 411 bytes from socket
    --- 15 messages dropped ---
    [00:00:18.564,239] <dbg> download_client: http_header_parse: GET header size: 411
    [00:00:18.564,910] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:18.742,065] <dbg> download_client: handle_received: Read 4096 bytes from socket
    [00:00:18.742,095] <inf> download_client: Downloaded 32768/102923 bytes (31%)
    [  31% ] |=======--- 9 messages dropped ---
    ======               [00:00:18.744,384] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:18.828,765] <dbg> download_client: handle_received: Read 411 bytes from socket
    [00:00:18.828,887] <dbg> download_client: http_header_parse: GET header size: 411
    --- 57 messages dropped ---
    [00:00:19.019,958] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:19.091,033] <dbg> download_client: handle_received: Read 411 bytes from socket
    [00:00:19.091,156] <dbg> download_client: http_header_parse: GET header size: 411
    --- 6 messages dropped ---
    ==================                               | (40960/102923 bytes)[00:00:19.276,489] <dbg> download_client: http_get_request_send:t
                                              74 65 73 3d 34 30 39 36  30 2d 34 35 30 35 35 0d |tes=4096 0-45055.
    [00:00:19.279,022] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:19.353,912] <dbg> download_client: handle_received: Read 411 bytes from socket
    [00:00:19.354,187] <dbg> download_client: http_header_parse: GET header size: 411
    [00:00:19.354,888] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:19.537,017] <dbg> download_client: handle_received: Read 4096 bytes from socket
    [00:00:19.537,048] <inf> download_client: Downloaded 45056/102923 bytes (43%)
    [  43% ] |=====================                             | (45056/102923 bytes)[00:00:19.537,811] <dbg> download_client: http_get_ret
                                              74 65 73 3d 34 35 30 35  36 2d 34 39 31 35 31 0d |tes=4505 6-49151.
    [00:00:19.539,306] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:19.613,525] <dbg> download_client: handle_received: Read 411 bytes from socket
    [00:00:19.613,647] <dbg> download_client: http_header_parse: GET header size: 411
    [00:00:19.614,288] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:19.793,914] <dbg> download_client: handle_received: Read 4096 bytes from socket
    [00:00:19.793,914] <inf> download_client: Downloaded 49152/102923 bytes (47%)
    [  47% ] |==============--- 12 messages dropped ---
    =                    [00:00:19.878,204] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:20.051,788] <dbg> download_client: handle_received: Read 4096 bytes from socket
    [00:00:20.051,788] <inf> download_client: Downloaded 53248/102923 bytes (51%)
    [  51% ] |=========================                         | (53248/102923 bytes)[00:00:20.052,612] <dbg> download_client: http_get_ret
                                              74 65 73 3d 35 33 32 34  38 2d 35 37 33 34 33 0d |tes=5324 8-57343.
    [00:00:20.054,107] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:20.126,342] <dbg> download_client: handle_received: Read 411 bytes from socket
    [00:00:20.126,464] <dbg> download_client: http_header_parse: GET header size: 411
    [00:00:20.127,197] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:20.293,792] <dbg> download_client: handle_received: Read 4096 bytes from socket
    [00:00:20.293,792] <inf> download_client: Downloaded 57344/102923 bytes (55%)
    [  55% ] |==================    --- 5 messages dropped ---
                       | (57344/102923 bytes)[00:00:20.376,007] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x200.
    [00:00:20.542,236] <dbg> download_client: handle_received: Read 4096 bytes from socket
    [00:00:20.542,236] <inf> download_client: Downloaded 61440/102923 bytes (59%)
    [  59% ] |========================--- 6 messages dropped ---
    =====                [00:00:20.543,029] <dbg> download_client: http_get_request_send: HTTP request
                                              74 65 73 3d 36 31 34 34  30 2d 36 35 35 33 35 0d |tes=6144 0-65535.
    --- 20 messages dropped ---
    [00:00:20.544,525] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:20.623,046] <dbg> download_client: handle_received: Read 411 bytes from socket
    [00:00:20.623,168] <dbg> download_client: http_header_parse: GET header size: 411
    ===========--- 8 messages dropped ---
    =====                [00:00:20.873,748] <dbg> download_client: http_header_parse: HTTP response
                                              48 54 54 50 2f 31 2e 31  20 32 30 36 20 50 61 72 |HTTP/1.1  206 Par
                                              74 69 61 6c 20 43 6f 6e  74 65 6e 74 0d 0a 78 2d |tial Con tent..x-
                                              61 6d 7a 2d 69 64 2d 32  3a 20 39 78 75 51 50 75 |amz-id-2 : 9xuQPu
                                              76 43 38 69 52 50 6e 38  56 4f 54 36 49 79 2f 62 |vC8iRPn8 VOT6Iy/b
                                              55 4b 79 7a 38 33 46 54  4a 79 4f 56 59 53 51 6b |UKyz83FT JyOVYSQk
                                              71 43 41 70 75 71 54 34  70 34 36 34 35 75 36 34 |qCApuqT4 p4645u64
                                              58 43 65 39 72 2b 69 49  6a 44 47 51 55 72 34 57 |XCe9r+iI jDGQUr4W
                                              44 45 6f 79 51 3d 0d 0a  78 2d 61 6d 7a 2d 72 65 |DEoyQ=.. x-amz-re
                                              71 75 65 73 74 2d 69 64  3a 20 34 46 30 53 33 56 |quest-id : 4F0S3V
                                              47 31 51 42 50 5a 53 4d  46 32 0d 0a 44 61 74 65 |G1QBPZSM F2..Date
                                              3a 20 4d 6f 6e 2c 20 30  32 20 53 65 70 20 32 30 |: Mon, 0 2 Sep 20
                                              32 34 20 30 37 3a 35 32  3a 35 34 20 47 4d 54 0d |24 07:52 :54 GMT.
                                              0a 4c 61 73 74 2d 4d 6f  64 69 66 69 65 64 3a 20 |.Last-Mo dified:
                                              54 68 75 2c 20 31 30 20  4d 61 72 20 32 30 32 32 |Thu, 10  Mar 2022
                                              20 31 36 3a 30 30 3a 34  34 20 47 4d 54 0d 0a 45 | 16:00:4 4 GMT..E
                                              54 61 67 3a 20 22 33 33  61 30 35 36 33 61 62 31 |Tag: "33 a0563ab1
                                              32 64 33 35 33 39 63 61  35 36 63 36 65 32 39 30 |2d3539ca 56c6e290
                                              61 30 38 30 62 64 22 0d  0a 41 63 63 65 70 74 2d |a080bd". .Accept-
                                              52 61 6e 67 65 73 3a 20  62 79 74 65 73 0d 0a 43 |Ranges:  bytes..C
                                              6f 6e 74 65 6e 74 2d 52  61 6e 67 65 3a 20 62 79 |ontent-R ange: by
                                              74 65 73 20 36 35 35 33  36 2d 36 39 36 33 31 2f |tes 6553 6-69631/
                                              31 30 32 39 32 33 0d 0a  43 6f 6e 74 65 6e 74 2d |102923.. Content-
                                              54 79 70 65 3a 20 69 6d  61 67 65 2f 70 6e 67 0d |Type: im age/png.
                                              0a 53 65 72 76 65 72 3a  20 41 6d 61 7a 6f 6e 53 |.Server:  AmazonS
                                              33 0d 0a 43 6f 6e 74 65  6e 74 2d 4c 65 6e 67 74 |3..Conte nt-Lengt
                                              68 3a 20 34 30 39 36 0d  0a 0d 0a                |h: 4096. ...
    [00:00:20.874,359] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
     | (69632/102923 bytes)[00:00:21.041,717] <dbg> download_client: http_get_request_send: HTTP request
                                              74 65 73 3d 36 39 36 33  32 2d 37 33 37 32 37 0d |tes=6963 2-73727.
    --- 45 messages dropped ---
    [00:00:21.043,212] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:21.116,333] <dbg> download_client: handle_received: Read 411 bytes from socket
    [00:00:21.116,455] <dbg> download_client: http_header_parse: GET header size: 411
              | (73728/102923 bytes)[00:00:21.287,139] <dbg> download_client: http_get_request_send: HTTP request
                                              74 65 73 3d 37 33 37 32  38 2d 37 37 38 32 33 0d |tes=7372 8-77823.
    [00:00:21.288,635] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:21.359,985] <dbg> download_client: handle_received: Read 411 bytes from socket
    [00:00:21.360,107] <dbg> download_client: http_header_parse: GET header size: 411
    [00:00:21.532,623] <dbg> download_client: handle_received: Read 4096 bytes from socket
    [00:00:21.532,653] <inf> download_client: Downloaded 77824/102923 bytes (75%)
    [  75% ] |=====================================             | (77824/102923 bytes)[00:00:21.533,630] <dbg> download_client: http_get_ret
                                              74 65 73 3d 37 37 38 32  34 2d 38 31 39 31 39 0d |tes=7782 4-81919.
    [00:00:21.535,278] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:21.613,922] <dbg> download_client: handle_received: Read 411 bytes from socket
    [00:00:21.614,044] <dbg> download_client: http_header_parse: GET header size: 411
    [00:00:21.616,790] <dbg> download_client: handle_received: Read 503 bytes from socket
    [00:00:21.616,821] <dbg> download_client: download_thread: Receiving up to 3593 bytes at 0x2000ce2b...
    [00:00:21.856,475] <dbg> download_client: handle_received: Read 3593 bytes from socket
    --- 24 messages dropped ---
    [00:00:21.856,475] <inf> download_client: Downloaded 81920/102923 bytes (79%)
    [  79% ] |=================         | (81920/102923 bytes)[00:00:21.857,238] <dbg> download_client: http_get_request_send: HTTP request
                                              74 65 73 3d 38 31 39 32  30 2d 38 36 30 31 35 0d |tes=8192 0-86015.
    [00:00:21.858,734] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:21.941,589] <dbg> download_client: handle_received: Read 411 bytes from socket
    [00:00:21.941,711] <dbg> download_client: http_header_parse: GET header size: 411
    [00:00:21.942,382] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    --- 35 messages dropped ---
    [00:00:22.116,699] <dbg> download_client: handle_received: Read 4096 bytes from socket
    [00:00:22.116,729] <inf> download_client: Downloaded 86016/102923 bytes (83%)
    [  83% ] |===========    | (86016/102923 bytes)[00:00:22.117,614] <dbg> download_client: http_get_request_send: HTTP request
                                              74 65 73 3d 38 36 30 31  36 2d 39 30 31 31 31 0d |tes=8601 6-90111.
    [00:00:22.119,110] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:22.196,166] <dbg> download_client: handle_received: Read 411 bytes from socket
    [00:00:22.196,289] <dbg> download_client: http_header_parse: GET header size: 411
    [00:00:22.370,117] <dbg> download_client: handle_received: Read 3575 bytes from socket
    [00:00:22.370,147] <dbg> download_client: download_thread: Receiving up to 521 bytes at 0x2000da2b...
    [00:00:22.372,314] <dbg> download_client: handle_received: Read 521 bytes from socket
    --- 34 messages dropped ---
    [00:00:22.372,314] <inf> download_client: Downloaded 90112/102923 bytes (87%)
    [  87% ] |==================[00:00:22.374,755] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:22.464,019] <dbg> download_client: handle_received: Read 411 bytes from socket
    [00:00:22.464,141] <dbg> download_client: http_header_parse: GET header size: 411
    [00:00:22.464,813] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:22.573,394] <dbg> download_client: handle_received: Read 1527 bytes from socket
    [00:00:22.573,425] <dbg> download_client: download_thread: Receiving up to 2569 bytes at 0x2000d22b...
    [00:00:22.644,012] <dbg> download_client: handle_received: Read 2569 bytes from socket
    [00:00:22.644,042] <inf> download_client: Downloaded 94208/102923 bytes (91%)
    [  91% ] |==============--- 13 messages dropped ---
    =====================[00:00:22.727,539] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:22.892,272] <dbg> download_client: handle_received: Read 4096 bytes from socket
    [00:00:22.892,272] <inf> download_client: Downloaded 98304/102923 bytes (95%)
    [  95% ] |========================--- 7 messages dropped ---
    =====================[00:00:22.894,592] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:22.970,611] <dbg> download_client: handle_received: Read 412 bytes from socket
    [00:00:22.970,733] <dbg> download_client: http_header_parse: GET header size: 412
    == | (102400/102923 bytes)[00:00:23.141,906] <dbg> download_client: http_get_request_send: HTTP request
                                              74 65 73 3d 31 30 32 34  30 30 2d 31 30 32 39 32 |tes=1024 00-10292
                                              32 0d 0a 43 6f 6e 6e 65  63 74 69 6f 6e 3a 20 6b |2..Conne ction: k
                                              65 65 70 2d 61 6c 69 76  65 0d 0a 0d 0a          |eep-aliv e....
    [00:00:23.143,402] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:23.225,616] <dbg> download_client: handle_received: Read 412 bytes from socket
    [00:00:23.225,738] <dbg> download_client: http_header_parse: GET header size: 412
    [00:00:23.226,409] <dbg> download_client: download_thread: Receiving up to 4096 bytes at 0x2000cc34...
    [00:00:23.228,546] <dbg> download_client: handle_received: Read 523 bytes from socket
    [00:00:23.228,576] <inf> download_client: Downloaded 102923/102923 bytes (100%)
    [ 100% ] |==================================================| (102923/102923 bytes)[00:00:23.229,370] <inf> download_client: Download ce
    Download completed in 7523 ms @ 13681 bytes per sec, total 102923 bytes
    Bye
    [00:00:23.241,699] <dbg> download_client: set_state: state = 4
    [00:00:23.247,985] <dbg> download_client: set_state: state = 0
    Socket closed
    [00:00:23.248,046] <dbg> download_client: download_thread: Connection closed
    IP down
    Håkon
       Thanks for your test.
       So strange,I still have problems using the default URL test,only URL different.
    The IP it resolves to is not similar to the one's that I get:
    Non-authoritative answer:
    nrfconnectsdk.s3.eu-central-1.amazonaws.com	canonical name = s3-r-w.eu-central-1.amazonaws.com.
    Address: 3.5.139.219
    Address: 52.219.75.180
    Address: 3.5.139.196
    Address: 3.5.137.114
    Address: 3.5.135.58
    Address: 3.5.136.66
    Address: 3.5.134.152
    Address: 3.5.139.192
    Could you check by opening up a command prompt on your PC and running "nslookup nrfconnectsdk.s3.eu-central-1.amazonaws.com" to see if one of the IPs it resolves to is 208.77.47.172 ?
    I am not able to connect to this specific IP, so that might explain why the domain does not work when trying it on the nRF7002.
    Håkon
